Topic: Button and LED (Read 315 times) previous topic - next topic
Ankee56
Without the buttons my circuit just one side works ok, when i put the button the circuit "play alone" the game
This is the code:
bool willTheBallGoTowardsPlayerTwo = true;
bool isInputAllowed = true;
const int playerOne = 12;
const int goalPlayerOne = 13;
const int buttonPlayerOne = 3;
const int playerTwo = 5;
const int goalPlayerTwo = 4;
const int buttonPlayerTwo = 2;
int scoreOfPlayerOne = 0;
int scoreOfPlayerTwo = 0;
const unsigned long initialMillisecondsPerLED = 500;
const unsigned long initialDeltaMillisecondsPerLED = 50;
unsigned long millisecondsPerLED = initialMillisecondsPerLED;
unsigned long deltaMillisecondsPerLED = initialDeltaMillisecondsPerLED;
unsigned long currentMillis = 0;
unsigned long previousMillis = 0;
int currentPosition = playerOne;        //Player one starts the game.
int previousPosition = playerOne + 1;
int deltaPosition = 0;
int buttonStatePlayerOne = 0;
int lastButtonStatePlayerOne = 0;
int buttonStatePlayerTwo = 0;
int lastButtonStatePlayerTwo = 0;
  pinMode(4, 1);
  pinMode(5, 1);
  pinMode(6, 1);
  pinMode(7, 1);
  pinMode(8, 1);
  pinMode(9, 1);
  pinMode(10, 1);
  pinMode(11, 1);
  pinMode(12, 1);
  pinMode(13, 1);
  /*Connect pins 4 to 13 to 220ohm(or higher) resistors, connect the LEDs' longer legs(+) to the resistors,
    connect the other legs(-) of the LEDs' to ground.
    I recommend red LEDs for 4 and 13(Goals), yellow LEDs for 5 and 12(Players), green LEDs for other pins(Field).
  pinMode(2, 0);    //Pushbuttons for players. Pin 2 is for player two. Pin 3 is for player one.
  pinMode(3, 0);    //Connect pushbuttons following the instructions on this page: https://www.arduino.cc/en/Tutorial/DigitalReadSerial
    ListenForInput();
    currentMillis = millis();
    if (currentMillis - previousMillis >= millisecondsPerLED)  //If you don't understand this, see: https://www.arduino.cc/en/Tutorial/BlinkWithoutDelay
        CheckGoalConditions();
        DetermineNextPosition();
        MoveBallToNextPosition();
void ListenForInput()    //If you don't understand this method, see: https://www.arduino.cc/en/Tutorial/StateChangeDetection
    buttonStatePlayerOne = digitalRead(buttonPlayerOne);
    buttonStatePlayerTwo = digitalRead(buttonPlayerTwo);
    if (buttonStatePlayerOne != lastButtonStatePlayerOne && isInputAllowed)
        if (buttonStatePlayerOne == 1)
            if (currentPosition == playerOne)
                ToggleBallDirection();
                IncreaseSpeed();
                ScoreForPlayer(2);
        lastButtonStatePlayerOne = buttonStatePlayerOne;
if (buttonStatePlayerTwo != lastButtonStatePlayerTwo && isInputAllowed)
        if (buttonStatePlayerTwo == 1)
            if (currentPosition == playerTwo)
                IncreaseSpeed();
                ScoreForPlayer(1);
        lastButtonStatePlayerTwo = buttonStatePlayerTwo;
void ToggleBallDirection()
    willTheBallGoTowardsPlayerTwo = !willTheBallGoTowardsPlayerTwo;
    isInputAllowed = false;   //Only one direction change per frame is allowed for consistent gameplay.
void IncreaseSpeed()
    millisecondsPerLED -= deltaMillisecondsPerLED;
    if (deltaMillisecondsPerLED > 5)  //Because of this, it takes a little more time to reach to an insane speed. Adjust or remove this if rounds become too long.
        deltaMillisecondsPerLED -= 5;
void MoveBallToNextPosition()      //Moves the ball one spot.
    previousPosition = currentPosition;
    digitalWrite(previousPosition, 0);
    currentPosition = currentPosition + deltaPosition;
    digitalWrite(currentPosition, 1);
void DetermineNextPosition()
    if (willTheBallGoTowardsPlayerTwo)
        deltaPosition = -1;
        deltaPosition = 1;
void CheckGoalConditions()
    if (currentPosition == goalPlayerTwo)
        ScoreForPlayer(1);
    else if (currentPosition == goalPlayerOne)
        ScoreForPlayer(2);
void ScoreForPlayer(int playerWhoScored)
    FlashAllLEDs(1, 0);
    if (playerWhoScored == 1)
        scoreOfPlayerOne++;
        ShowScores(1);
    else if (playerWhoScored == 2)
        scoreOfPlayerTwo++;
        ShowScores(2);
    CheckEndGame();
void CheckEndGame()
    if (scoreOfPlayerOne == 3)
        EndGameCeremonyFor(1);
    if (scoreOfPlayerTwo == 3)
        EndGameCeremonyFor(2);
void ShowScores(int playerCurrentlyScored)
    if (playerCurrentlyScored == 1)
        digitalWrite(playerOne, 1);
    else if (playerCurrentlyScored == 2)
        digitalWrite(playerTwo, 1);
        currentPosition = playerTwo;
        willTheBallGoTowardsPlayerTwo = false;
for (int i = 0; i < scoreOfPlayerOne; i++) //We use the six LEDs in the middle to show score. Each player has three green LEDs to show score. This is why three goals win the game :)
        digitalWrite((11 - i), 1);
    for (int i = 0; i < scoreOfPlayerTwo; i++)
        digitalWrite((6 + i), 1);
    delay(3000);                //Are three seconds enough for players to process the score?
    ResetValuesForNextRound();
void ResetValuesForNextRound()
    FlashAllLEDs(1, 0);
    millisecondsPerLED = initialMillisecondsPerLED;            //Sets speed to initial value at the beginning of each round.
    deltaMillisecondsPerLED = initialDeltaMillisecondsPerLED;  //Sets delta speed to initial value at the beginning of each round.
void EndGameCeremonyFor(int winner)
    FlashAllLEDs(50, winner);
    TurnOffAllLEDsForPlayer(0);
void TurnOnAllLEDsForPlayer(int player)
    if (player != 1)          //When this method is called with (2), only these pins(player two's) will turn on
        digitalWrite(4, 1);
        digitalWrite(5, 1);
        digitalWrite(6, 1);
        digitalWrite(7, 1);
        digitalWrite(8, 1);
    if (player != 2)          //When this method is called with (1), only these pins(player one's) will turn on
        digitalWrite(9, 1);
        digitalWrite(10, 1);
        digitalWrite(11, 1);
        digitalWrite(12, 1);
        digitalWrite(13, 1);
void TurnOffAllLEDsForPlayer(int player)
    if (player != 1)          //When this method is called with (2), only these pins(player two's) will turn off
        digitalWrite(4, 0);
        digitalWrite(5, 0);
        digitalWrite(6, 0);
        digitalWrite(7, 0);
        digitalWrite(8, 0);
    if (player != 2)          //When this method is called with (1), only these pins(player one's) will turn off
        digitalWrite(9, 0);
        digitalWrite(10, 0);
        digitalWrite(11, 0);
        digitalWrite(12, 0);
        digitalWrite(13, 0);
void FlashAllLEDs(int blinkCount, int player) //Second parameter(int player) is for when you want to flash only one player's LEDs. Use 1 for player one, use 2 for player two.
    for (int i = 0; i < blinkCount; i++)
        TurnOnAllLEDsForPlayer(player);
        delay(35);
        TurnOffAllLEDsForPlayer(player);
        delay(35);
Any help?
IoT_hobbyist
Did you use pull-up or pull-down resistor? If not, see this post https://forum.arduino.cc/index.php?topic=643756.0
Grumpy_Mike
Quote
You are going to have to explain one hell of a lot about your project than this if you want anything but guesses.
What is it running on? ( type of Arduino )
What is it connected to and how?
What is the schematic you wired things up to?
