Hey all,
Thanks for taking the time to respond!
My apologies for not stating that I intend to use this as a multi-purpose voltmeter. I'm just using the 5v as a known good, stable reference to calibrate my readings. Having decent range would be desirable.
DVDdoug,
I printed out the raw ADC values. Varying slightly at 30-31. As I mentioned before, I took the resistors out of the circuit and my arduino read a AA battery accurately at 1.25 volts. The inaccuracies start with the addition of resistors.
I've measured the 5v and AREF on the Arduino, they're ~4.80 and 1.1 +/- .02 volts. Started out using an Uno, which it's ADC values did -not- reflect the accurate voltage of a AA battery, but the Leonardo I'm using did.
6v6gt,
I was under the assumption that the "10k or less" was measured from R2 to analog input? I suppose this is where my elementary understanding of basic circuits is failing me. I'll give that a shot, but is there any other way to get more range out of this? I was hoping to measure up to at least 50vdc if that's feasible.
Idahowalker,
I attempted a 44nF capacitor from R2 to ground. Would that be enough? It didn't really change the reading for me at all, except it slightly delayed returning to 0.00 volts when I removed the 5v lead.
I'll try soldering everything together later on tonight.
