Topic: Error: pin 2-6 (Read 749 times) previous topic - next topic
AWaterman
I have the arduino IDE set up, and have successfully used it to program one duemilanova. I have a second duemilanova (for the mark 2 of my project, mark 1 being in field test), but what I get from it via the serial monitor is error: pin 2-6 (and occasionally 2-5 and 2-8. I have nothing connected to the board beside the USB port. The software I attempted to upload was the stuff which I uploaded for the other duemilanova. I have also attempted to load example sketches, like analogInput from dojo dave.
The physical indications - power led on, rx led flashes briefly, tx led flashes in time with the error messages.
Also the IDE locks up during the "upload". The lock-up can be fixed by pulling the usb cable out, or by two three hits of the reset button on the arduino. OS is XP sp3.
Points I observe.
The IDE does not give me a board choice of duemilanova. I use diecimila. I think that was the choice I had before.
This duemilanova was bought some time after the previous (working) one.
I have moved disks around on this PC, and, on inserting the USB cable, I had to find the drivers again, but I did, in the expected place.
The port number of the USB moved from 6 to 7, but I did have a disk drive connected on a USB port, and it was not present before.
The project is a guide device for a blind man. I hope this makes it worthy of useful advice.
Thanks in advance
cmiyc
Quote
This doesn't make any sense.
Quote
What version of the IDE are you running?
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
AWaterman
IDE version, as far as I can determine, 0012 alpha.
AWaterman
All good. Updated IDE to 0022. Bought a new board (nano), so elected Nano. Works fine
Tried previous board, selecting Duemilanove with atmega328 - loads fine.
So I suspect the original board I had, where everything worked, was a Duemilanove with atmega 128, whereas, the board I had trouble with was the 328.
Thanks for your help.
