Topic: Cant upload sketch (Read 810 times) previous topic - next topic
IdotArduino1
This is what i get when i press ''Copy error message''
Arduino: 1.8.10 (Windows 10), Board: "Arduino Nano, ATmega328P"
Sketch uses 1706 bytes (5%) of program storage space. Maximum is 30720 bytes.
Global variables use 228 bytes (11%) of dynamic memory, leaving 1820 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x21
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x21
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x21
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x21
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x21
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x21
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x21
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x21
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x21
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x21
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
groundFungus
Have you tried the instructions in the Troubleshooting Guide?
Budvar10
Try to switch to Nano with "Old Bootloader".
Arduino clone with ATmega1284P   http://forum.arduino.cc/index.php?topic=277260.0
IdotArduino1
Yes but it did not work
pert
Remove any connections to pins 0 and 1. These pins are used for communication with your computer, including uploads. Connecting anything to these pins can interfere with uploads.
Make sure you have the correct board selected from the Tools > Board menu.
Make sure you have selected the port of your Arduino board from the Tools > Port menu.
If you don't know which port is your Arduino, you can find it like this:
  • Unplug your Arduino board from the computer.
  • Tools > Port
  • Note the ports, if any, listed in the menu.
  • Close the Tools menu
  • Plug your Arduino board into the computer.
  • Tools > Port - The new port listed in the menu is your Arduino board.
