Topic: Problem with NRF24L01 low current on some pins ! help ! [SOLVED] (Read 348 times) previous topic - next topic
firashelou
Good catch Groundfungus
+1
raschemmel thanks for trying to help and thanks for everyone :)
Aiming for the unreachable !
my social website https://www.asserter.net
raschemmel
Quote
I have used the NRF24L01 many times but I never noticed this issue because I have been
automatically adding electrolytic caps to my power lines since I started in electronics 40
years ago so I would never have tried to use it before going through this routine ritual
when setting up the breadboard. I typically use 10uF for the Reset pin and 47uF or
greater for power rails. (100uF is a good round number that is usually enough). You
can never have too much capacitance on your power rails.
firashelou
So you suggest the best choice is to use 100uF between VCC and GND ?
firashelou
