Topic: Unable to install Arduino Create plugin for Raspberry Pi 4 (Read 1 time) previous topic - next topic
Tankfuzz
Hello! I hope I'm asking this in the right place :/
I have a few sketches on Arduino Create that I would like to upload directly to my Arduino Mega, which is connected via USB to my Pi 4. According to Arudino, I have to download and install a plugin to allow me to upload directly from Arduino Create to the board.
I can and upzip the Linux 64bit ver of Arduino Create Agent, but once I try to run the ArduinoCreateAgent-1.1linux.x64.run file via Terminal, the terminal opens momentarily and then closes.
The only error message I could see is "ELF - Not found".
Is it not possible to install the plugin?
Thank you!
ieee488
Any reason you don't want to connect the Mega to your PC and do it that way?
I use Linux Mint and Arduino Create works.
Tankfuzz
I am currently doing this for an internship, so I have to use the Pi in the end. My work computer has no admin access so I have to use Arduino Create too.
ieee488
Ask the Raspberry Pi people.
It works on Linux Mint so nothing wrong with the Arduino Create.
Poki
Raspberry Pi running Raspbian needs 32-bit executables. Do not use 64-bit executables. If the executable is described as "Linux" but not "Linux ARM" then it almost always for Intel/AMD CPUs so will not work on Raspberry Pi CPUs (all ARM).
Try the "Linux ARM 32 bits" version of the Arduino IDE on the Pi4 . Do not install the IDE using apt or apt-get. See the following for downloads and instructions.
https://www.arduino.cc/en/Main/Software
https://www.arduino.cc/en/Guide/Linux
