Topic: HELP!! I'm New to the whole arduino thing. (Read 7478 times) previous topic - next topic
marquita188
Jun 27, 2011, 06:17 am Last Edit: Jun 27, 2011, 05:17 pm by marquita188 Reason: 1
can somebody help me out? i trying to build a fully motion automatic cat door opener. i don't have $400 for a pre-built one plus $50 for 4 collars. i want the door to slide up&down or from side to side. one of my cats don't like to use the door, but it does a great job at keeping smell and flies away. but i don't much about programing codes, to arduino, pir, servos etc.
with the following parts:
Ideal Pet Products 58000 medium cat door
1 arduino Duemilanove microcontroller
1 Sensor Shield add-on card for Arduino Duemilanove board
2 Infrared PIR Motion sensor modules
1 Digital Servo
some jumpers
fkeel
not sure what your question is, but assuming you are asking on some feedback to the parts you plan on using:
petmate medium cat door
whatever that is... I assume it'll do the job
Quote
spot on.
Quote
these are handy, but not really necesary. I have one of those and find that I dont really use it. if you want to save money, dont buy this. you dont need it. (if you do buy it, it does make things a bit easyer for beginners)
Quote
I have no experience with PIR sensors - however depending on the brand they can be a bit complex. I would advice to get something like a twig by seedstudio
http://www.seeedstudio.com/depot/twig-pir-motion-sensor-p-802.html
I have very good experience with the active IR sensors that Phidgits sells (like this one: http://www.seeedstudio.com/depot/twig-pir-motion-sensor-p-802.html) however, while they are very easy to use, they may go haywhire in sunlight.
Quote
1 Digital Servo
yep. but. how will the servo move the door? its sometimes not that easy getting the motion which you want out of a motor.
If I where you, I would take apart an old CD drive. You might be able to use its edject mechanism to build a sliding door.
Quote
some jumpers
Yep. And a breadboard.
Hope this is of some help. if not feel free to ask specific questions. Also post links to the products you are considering. A servo can mean all kind of things and so can a PIR module. If we know specifically what you are considering, then we can give you real advice.
Cheers
p.
(oh and look into RFID. You might not want to use IR, but an RFID chip to activate the door. That way you can prevent squirrels or snow or leaves from activating your door.)
http://embodimentlabs.tumblr.com/
http://paulstrohmeier.info/
AWOL
Quote
What about non-psychic felines?   :smiley-yell:
marquita188
Quote
Ideal Pet Products Kat Door 58000
http://idealpetproduct.com/shop/item.asp?itemid=93&catid=10
Quote
these are handy, but not really necessary. I have one of those and find that I don't really use it. if you want to save money, don't buy this. you don't need it. (if you do buy it, it does make things a bit easier for beginners)
oh, OK. i won't buy it then.
Quote
ok, so you think a twigs would work better than Parallax PIR Sensors? and how do you connect these to the arduino?
Quote
If I where you, I would take apart an old CD drive. You might be able to use its eject mechanism to build a sliding door.
OK, how would you use the CD drive? i have a bunch of these laying around.
Quote
Cheers
p.
Arduino Breadboard Jumper Cable Wire Kit APPROX 65
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=160602015515&ssPageName=STRK:MESINDXX:IT
PIR Body Motion sensor module Pyroelectric Infrared X2
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=310311671815&ssPageName=STRK:MESINDXX:IT
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=270769100923&ssPageName=STRK:MESINDXX:IT
S9257 Digital Servo For RC 450 Helicopter High Speed
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=120737621319&ssPageName=STRK:MESINDXX:IT
ATmega 328 microcontroller (Arduino Duemilanove clone)
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=280682100975&ssPageName=STRK:MESINDXX:IT
how do you program the arduino to do what you want it to do? do i need a PC to use it?
ok, i forgot to tell you that the door is for the litter box, not outside. because my cats stay indoors.
Quote
not helpful :~
Grumpy_Mike
fkeel
grumpy_mike: 1
marquita: 0
:-D
I'll be back with a usefull post a little later in the day ok?
marquita188
#6
Jun 27, 2011, 09:40 pm Last Edit: Jun 27, 2011, 09:49 pm by marquita188 Reason: 1
Quote
not helpful
No but funny.
not funny either!!! :0
grumpy_mike: 1
marquita: 0
:-D
WOW really? :smiley-roll:
thanks.
http://www.youtube.com/watch?v=_p0jbRGWx4s
guano_jim
A servo might be overkill for an application like this. If you've never done anything like this before you might look at controlling a simple DC motor with an h-bridge so you can reverse the direction of the motor.
Servos can be very accurate, but also very expensive, and there's a little learning curve on the programming side. Controlling a hobby motor might be an easier start.
You might also need to think about a gear system so you can get enough torque out of a small motor to lift a pet door.
AWOL
Quote
I get Futaba 3003 much cheaper than I could buy a DC motor, gearbox and H bridge.
fkeel
a twig has three connectors. one goes to +5v one goes to an analog input and one goes to ground. The twigs, just like the phidget sensors and various other "bricks" are built so they can work with an arduino with as little hassle as possible.
The sensor you linked to on ebay requires 4.5V input and an output of 0 to 3v. Arduino outputs either 3.3v or 5v, and its input is designed to recieve voltage between 0 and 5 volt
So you can use that sensor, however you will have to create your own circuit if you want it to work as well as a phidgets sensor or a twig. These already have the additional circuit built in.
(I might be wrong with details, but you get the generall picture.)
Quote
Well, I often find it a bit tricky translating the motion of a servo to linear motion. Linear servos exist, but are quite expensive. You could also use a mechanical solution like in the video you posted.
I was thinking this: You know how CD-Drives cen slide the tray in and out?
Well basically that can be your door. Open the chassis of the cd-drive. In it you will find several small motors. One of them is sort of skinny and long (though this may be different between brands) and is connected to a drive system which opens and closes the CD Drive on the click of a button. Find yourself a motor shiled (google - there are tons) and connect the red and black leads which go to the motor you are interested to it. (I dont know what voltage they require - I would probably just try it with the Arduino set to 3.3V)
Alternatly you could also try to hack the pushbotton which activates the motor.
Then again, if you are not that into tinkering with electronics, maybe the mechanical motion translation is simpler for you. I dont know. I personally would start with the CD-Drive, and try to work from there.
Quote
Quote
you need to program it. the way to go about this is to go through code examples and find code which does sort of what you want it to do. Then learn how to tweak it. Eventually learn how to write your won code. The Arduino website has tons of ressources.
Quote
You need a computer to program it. However, once that is set up, you can use the Arduino as a standalone device.
Quote
If it is indoors I would consider this sensor:
http://www.phidgets.com/products.php?category=2&product_id=1103
it activates at proximity of 10cm and gives a simple on or off symbol. Should be very easy to use.
Alternatly consider:
http://www.phidgets.com/products.php?category=2&product_id=3520
in combination with
http://www.phidgets.com/products.php?product_id=1101
this will get you an analog reading between 0 and 1024 which lets you be a bit more flexible.
phidgets also has a linear servo, but its rediculously expensive:
http://www.phidgets.com/products.php?category=22&product_id=3540
OK gotta run.
good luck
(btw. the sensors I recommended are for indoors use only. sunlight does not become them.)
marquita188
#10
Jun 28, 2011, 12:50 am Last Edit: Jun 28, 2011, 01:37 am by marquita188 Reason: 1
can you give me step by step i just don't see what you are talking about.
http://hackedgadgets.com/2009/11/24/cd-rom-door-lock/
http://vimeo.com/7504447
fkeel
#11
Jun 28, 2011, 03:45 am Last Edit: Jun 28, 2011, 04:04 am by fkeel Reason: 1
what I am saying is:
*if* you want a sliding door, you can either buy a 90$ motor, or use a sliding mechanism which you already have.
Your hard drive slides open and close. thats the door opening and closing. so you replace the cd-tray with a "door" and mount it in your wall. You find the electricity leads going to your motor, and connect them to a arduino motor-shield.
That way you save yourself a lot of money, and possibly time as well.
Open up your cd-drive and take a look. I dont have time to write you a step by step.
It all depends upon how experimental it is, and what your preferred approach is. Maybe my Idea doesnt work for you. Its just a suggestion.
cheers
p.
Edit: Yeah. You get the idea. You can do exactly what they did in that video, just instead of an iron rod, you will be moving the door for your cat.
But its just a suggestion. There are many ways to do it.
marquita188
cheers
p.
yeah, but the motor on my CD drive don't look anything like that. it don't have red & black wires, or any wires coming out of it, just those ribbon things.
fkeel
post a picture. maybe I or someone else here can figure it out.
marquita188
http://smg.photobucket.com/albums/v628/MARQUITA188/cd/
