Topic: problem with build project (Read 391 times) previous topic - next topic
farting_tuna
So I am currently working on an Arduino project. I have built it and coded it. The potentiometer is working fine and the readings I am expecting to get I get. But whenever these values are displayed in the serial monitor the response I am expecting does not happen. I was hoping for some advice/tips.
I am putting the code below, and a picture of my build. The goal is that after the button is pressed, based of potentiometer readings different lights and tones will be on.
my code:
const int piezo = 8;
const int pot = A0;
const int switchPin = 2;
const int redLED = 3;
const int yellowLED = 4;
const int greenLED = 5;
int potVal;
int switchState;
int notes[] = {262,294,330};
  //labeled all parts with corresponding pin
  // put your setup code here, to run once
pinMode(redLED, OUTPUT);
pinMode(yellowLED, OUTPUT);
pinMode(greenLED, OUTPUT);
pinMode(switchPin, INPUT);
pinMode(pot, INPUT);
pinMode(piezo, OUTPUT);
  //set each part as an input or an output
 int potVal = analogRead(A0);
  switchState = digitalRead(2);
  //reading the value of the switch on or off to then let the rest of the circuit function of this
 if(switchState == LOW)
    //button not pressed
  potVal = 0;
else if(switchState == HIGH)
 //button is pressed
 Serial.print("potVal: ");
 Serial.println(potVal);
 //let me see value of potentiometer i hope
// after this comes the lighting and tone code but right now its not working
 if (potVal = 0)
 digitalWrite(3, LOW);
 digitalWrite(4, LOW);
 digitalWrite(5, LOW);
 noTone(8);
 else if(potVal <= 330 && potVal >= 1)
 digitalWrite(3, HIGH);
 tone(8, notes[1]);
 else if(potVal <= 660 && potVal >= 331)
 digitalWrite(4, HIGH);
 tone(8, notes[2]);
else if(potVal <= 1023 && potVal >= 661)
digitalWrite(5, HIGH);
tone(8, notes[3]);
ballscrewbob
Please
READ THIS POST to help you get the best out of the forum.
SIMPLE TROUBLESHOOTING.
These steps may also save you some unnecessary time and effort in the forum.
  • Always provide as much detail as possible to your issue it may be important.
  • If applicable provide your SKETCH inside CODE TAGS ( </> ) or a CREATE share link.
  • If applicable provide a schematic even if hand drawn.
  • How to insert a picture into your post
  • If applicable provide a proper LINK to the hardware / sensors etc. you are using.
COMMON ISSUES
    It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google (who would have thunk it ! ) or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
