Topic: WS2812B Status Display - Serial Control (Read 1 time) previous topic - next topic
stefan_schmidi
Hello
I have written following code for my Status Display!
I can control every single led via Serial command:
sr 0 // static red on led "0"
sg 1 // static green on led "1"
bb 5 // blinking blue on led "5"
br 6 // blinking red on led "6"
bg 7 // blinking red on led "7"
off 5 // set led 5 to BLACK...and so on...
Led are synchronized in Blinking mode.
My Problem is, that the first LED begins to flickering, when i switch on one of the other LED!
All other functions and LEDs are ok - please can somebody test my CODE, to understand my problem!
thanks in advance  :)
In the WS2812FX.h library i have changed following:
/* each segment uses 36 bytes of SRAM memory, so if you're application fails because of
  insufficient memory, decreasing MAX_NUM_SEGMENTS may help */
#define MAX_NUM_SEGMENTS  16
#define NUM_COLORS        3 /* number of colors per segment */
#define MAX_CUSTOM_MODES  4
#define SEGMENT          _segments[_segment_index]
#define SEGMENT_RUNTIME  _segment_runtimes[_segment_index]
#define SEGMENT_LENGTH   1
Code: [Select]
 Status_Display V5.0
  CHANGELOG
  2019-12-02 Version 5.0 (by XXX)
#define REDUCED_MODES // sketch too big for Arduino Leonardo flash, so invoke reduced modes
#include <WS2812FX.h>
#define LED_COUNT 16
#define LED_PIN 5
#define MAX_NUM_CHARS 16 // maximum number of characters read from the Serial Monitor
WS2812FX ws2812fx = WS2812FX(LED_COUNT, LED_PIN, NEO_GRB + NEO_KHZ800);
char cmd[MAX_NUM_CHARS];       // char[] to store incoming serial commands
boolean cmd_complete = false;  // whether the command string is complete
  ws2812fx.init();
  ws2812fx.setBrightness(20);
  ws2812fx.setSpeed(1000);
  ws2812fx.setColor(0x000000);
  ws2812fx.setMode(FX_MODE_STATIC);
  ws2812fx.start();
  //printUsage();
  ws2812fx.service();
  recvChar(); // read serial comm
  if(cmd_complete) {
    process_command();
 * Checks received command and calls corresponding functions.
void process_command() {
  if (strncmp(cmd,"sr ",3) == 0) {      //Set "sr" Static Red to LED Number "a"
    uint8_t a = (uint8_t)atoi(cmd + 3);
    ws2812fx.setSegment((a), (a), (a), FX_MODE_STATIC, RED,  1000, false);
    Serial.print(F("ROT LEUCHTEN Led: "));
    Serial.println((a));
  if (strncmp(cmd,"sg ",3) == 0) {
    uint8_t b = (uint8_t)atoi(cmd + 3);
    ws2812fx.setSegment((b), (b), (b), FX_MODE_STATIC, GREEN,  1000, false);
   Serial.print(F("GRÜN LEUCHTEN Led: "));
    Serial.println((b));
  if (strncmp(cmd,"sb ",3) == 0) {
    uint8_t c = (uint8_t)atoi(cmd + 3);
    ws2812fx.setSegment((c), (c), (c), FX_MODE_STATIC, BLUE,  1000, false);
    Serial.print(F("BLAU LEUCHTEN Led: "));
    Serial.println((c));
  if (strncmp(cmd,"sl ",3) == 0) {
    uint8_t d = (uint8_t)atoi(cmd + 3);
    ws2812fx.setSegment((d), (d), (d), FX_MODE_STATIC, YELLOW, 1000, false);
    Serial.print(F("GELB LEUCHTEN Led: "));
    Serial.println((d));
  if (strncmp(cmd,"br ",3) == 0) {
    uint8_t e = (uint8_t)atoi(cmd + 3);
    ws2812fx.setSegment((e), (e), (e), FX_MODE_BLINK, RED,  1000, false);
    Serial.print(F("ROT BLINKEN Led: "));
    Serial.println((e));
  if (strncmp(cmd,"bg ",3) == 0) {
    uint8_t f = (uint8_t)atoi(cmd + 3);
    ws2812fx.setSegment((f), (f), (f), FX_MODE_BLINK, GREEN,  1000, false);
    Serial.print(F("GRÜN BLINKEN Led: "));
    Serial.println((f));
  if (strncmp(cmd,"bb ",3) == 0) {
    uint8_t g = (uint8_t)atoi(cmd + 3);
    ws2812fx.setSegment((g), (g), (g), FX_MODE_BLINK, BLUE,  1000, false);
    Serial.print(F("BLAU BLINKEN Led: "));
    Serial.println((g));
  else if (strncmp(cmd,"off ",4) == 0) {
    uint8_t h = (uint8_t)atoi(cmd + 4);
    ws2812fx.setSegment((h), (h), (h), FX_MODE_STATIC, BLACK,  1000, false);
    Serial.print(F("Clear Led: "));
    Serial.println((h));
  cmd[0] = '\0';         // reset the commandstring
  cmd_complete = false;  // reset command complete
 * Reads new input from serial to cmd string. Command is completed on \n
void recvChar(void) {
  static byte index = 0;
  while (Serial.available() > 0 && cmd_complete == false) {
    char rc = Serial.read();
    if (rc != '\n') {
      if(index < MAX_NUM_CHARS) cmd[index++] = rc;
      cmd[index] = '\0'; // terminate the string
      index = 0;
      cmd_complete = true;
      Serial.print("received '"); Serial.print(cmd); Serial.println("'");
Grumpy_Mike
#1
Dec 03, 2019, 10:34 pm Last Edit: Dec 03, 2019, 10:35 pm by Grumpy_Mike
Quote
That sounds like a power supply problem.
Can you tell us how this is wired up and powered?
What is this reduced modes library and provide a link to it?
Please read the how to use this forum sticky post for what to supply when asking a question on this forum.
