Topic: wireless sensor using nRF24l001 + ethernet shield  (Read 1 time) previous topic - next topic
itsnaga015
Dec 09, 2019, 08:29 am Last Edit: Dec 09, 2019, 08:34 am by itsnaga015
my project is about wireless sensor-based, I m using 3 nano Arduino and 1 uno Arduino board. considering node1, node 2, node 3 and base node, below I mentioned all the details.
node 1- nano arduino+nrf24l001+PIR motion sensor
node 2-nano arduino+nrf24l001+ultrasonic sensor
node3 -nano arduino+nrf24l001+flame sensor
base node -uno arduino+nrf24l001+lcd display+ ethernet shield
I succeeded in sending and receiving text messages through nrf24l001 wireless communication through pipes ., the problem I faced is how to display it through ethernet shield to HTML, below mentioned link is the code details for the base node and transmitter node.
https://drive.google.com/open?id=1qWMLheqx-Ks_I2Hz0Ee3OhYn1OIqMKfx
error is
https://drive.google.com/open?id=13jAkb03uJ09mc7LtDs7SB8Qfi2fHyqYE
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#include <Wire.h>
#include <Ethernet.h>
#include <RF24_config.h>
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
RF24 radio(7, 8); // CE, CSN
char Data1 = "";
char Data2[32] = "";
char Data3[32] = "";
char Data4[32] = "";
const uint64_t pipes[4] = { 0xF0F0F0F0E1LL, 0xF0F0F0F0E2LL, 0xF0F0F0F0E3LL, 0xF0F0F0F0E4LL };
//int LEDpir = 4;    // green
//int LEDultra = 2;  // red
//int BUZfire = A0; // Fire
byte mac[] = { 0x90, 0xA2, 0xDA, 0x0D, 0x85, 0xD9 };   //physical mac address
byte ip[] = { 192, 168, 137, 177 };                   // ip in lan
byte subnet[] = { 255, 255, 255, 0 };              //subnet mask
byte gateway[] = { 192, 168, 137, 1 };              // default gateway
EthernetServer server(80);                       //server port
  lcd.begin(16, 2);
  digitalWrite(10,HIGH);
  radio.begin();
  radio.setDataRate(RF24_250KBPS);
  radio.openReadingPipe(1, pipes[1]);
  radio.openReadingPipe(2, pipes[2]);
  radio.openReadingPipe(3, pipes[3]);
  radio.startListening();
  Ethernet.begin(mac,ip,gateway,subnet);     // initialize Ethernet device
  server.begin();                                // start to listen for clients
  if (radio.available())
    char text1[32] = "";
    radio.read(&text1, sizeof(text1));
        Serial.println(text1);
        Data1=text1;
   EthernetClient client = server.available();    // look for the client
// send a standard http response header
client.println("Connnection: close");
client.println();
This portion is the webpage which will be
sent to client web browser one can use html , javascript
and another web markup language to make particular layout
client.println("<!DOCTYPE html>");      //web page is made using html
client.println("<html>");
client.println("<head>");
client.println("<title>Ethernet Tutorial</title>");
client.println("<meta http-equiv=\"refresh\" content=\"3\">");
The above line is used to refresh the page in every 1 second
This will be sent to the browser as the following HTML code:
<meta http-equiv="refresh" content="1">
content = 1 sec i.e assign time for refresh
client.println("</head>");
client.println("<body>");
client.println("<h1>Sensor network</h1>");
client.println("<h2>Monitoring</h2>");
client.println("<body bgcolor=#354166 text=white>"); client.println("</body>");
client.println("<table border=1 cellpadding=10 bgcolor=blue>");
client.println("<tr><th>Node Number</th><th>---------Status----------</th></tr>");
     client.println("<tr><th>");
          client.println(1);
          client.println("</th><th>");
          client.println(Data1);
          client.println("</th></tr>");
          client.println(2);
          client.println(Data2);
          client.println(3);
          client.println(Data3);
          client.println("</table>");
          client.println("<br />");
          client.println("</html>");
    delay(1);         // giving time to receive the data
The following line is important because it will stop the client
and look for the new connection in the next iteration i.e
client.stop();
Thank you
Ranjith
Robin2
Two or three hours spent thinking and reading documentation solves most programming problems.
itsnaga015
sorry, it's not an error. I'm not getting the text msg at the HTML status bar, but I received it at the serial monitor through nrf24l01. Click below link for details
Robin2
Can't you just post the text or whatever it is here?
If it is am image see this  Simple Image Posting Guide
Assuming your base node can correctly receive the data from the other nodes then the problem has nothing to do with the nRF24s and I suggest that you just write a simple test / learning program to send some typical (but static) data via the Ethernet shield.
By the way I know a bit about nRF24s but I have no experience with an Ethernet shield.
...R
itsnaga015
@robin2 thank you so much for guiding me, I succeeded in displaying the data at webserver through ethernet shield, the thing is data displayed rollout continues and it's random at webserver. have any solution for this??
I have attached the details.
thank you
Robin2
Please make your image visible in your Post - I gave you the link to the simple instructions.
Please also post your program code in your Post so we don't have to download it. Many readers use tablets and cannot download files. Also please use the code button </> when posting the code.
...R
itsnaga015
#6
Dec 17, 2019, 07:21 am Last Edit: Dec 17, 2019, 07:28 am by itsnaga015
above showed is the displayed output at webserver, sensor data which is sent by node1,node2,node3 to the master via nrf24l001 and displayed to web server through ethernet shield.
 The output which I get in webserver scrolls out continuously(it is not stable in assigned place ) when sensors detect. Is there any solutions to display at a particular row and column.
below I mention code for master node
Thank you
Ranjith
#include <SPI.h>// Add  'SPI' library
#include <Ethernet.h>// Add 'Ethernet' library
#include <RF24.h>
byte ip[] = { 192, 168, 1, 175 };                   // ip in lan
byte gateway[] = { 192, 168, 1, 176 };
int led=2;
char text2[32] = "";
char text3[32] = "";
RF24 radio(7, 8);
const uint64_t pipes[4] = {0xF0F0F0F0E1LL,0xF0F0F0F0E2LL,0xF0F0F0F0E3LL,0xF0F0F0F0E4LL};
  radio.begin();
 //radio.setPALevel(RF24_PA_MAX);
  radio.openReadingPipe(1,pipes[1]);
  radio.openReadingPipe(2,pipes[2]);
  radio.openReadingPipe(3,pipes[3]);
  Serial.begin(9600);// Initialize Serial communication at 9600 baudrate
  // start the Ethernet connection and the server:
  Ethernet.begin(mac, ip);
  server.begin();
  //Serial.print("server is at ");// Displays 'server is at'
  //Serial.println(Ethernet.localIP());// Displays server IP address
 pinMode(led,OUTPUT);
 //PIR TEXT
  //ULTRA TEXT
    radio.read(&text2, sizeof(text2));
    Serial.println(text2);
   //FLAME TEXT
    radio.read(&text3, sizeof(text3));
    Serial.println(text3);
  EthernetClient client = server.available();//Assign incoming client to 'client'
if (client)
Serial.println("Web Client connected ");
String request = client.readStringUntil('\r');
client.println("Content-type:text/html");
client.println("Connection: close");
client.println("Refresh:1");
client.println();
client.println("<!DOCTYPE html><html>");
client.println("<head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">");
client.println("<link rel=\"icon\" href=\"data:,\">");
client.println("<style>body { text-align: center; font-family: \"Arial\", Arial;}");
client.println("table { border-collapse: collapse; width:40%; margin-left:auto; margin-right:auto;border-spacing: 2px;background-color: white;border: 4px solid green; }");
client.println("th { padding: 20px; background-color:blue ; color: white; }");
client.println("tr { border: 3px solid blue; padding: 1px; }");
client.println("tr:hover { background-color:yellow; }");
client.println("td { border:2px; padding: 8px; }");
client.println(".text { color:blue; font-weight: bold; background-color: #bcbcbc; padding: 1px; }");
client.println("</style></head><body><h1> WIRELESS SENSOR NETWORK </h1>");
client.println("<table><tr><th>NODE</th><th>STATUS</th></tr>");
client.println("<tr><td>1</td><td><span class=\"text\">");
client.println(text1);
//client.println(" *C</span></td></tr>");
client.println("<tr><td>2</td><td><span class=\"text\">");
client.println(text2);
//client.println(" *F</span></td></tr>");
client.println("<tr><td>3</td><td><span class=\"text\">");
client.println(text3);
//client.println(" %</span></td></tr>");
client.println("</body></html>");
client.stop();
client.println();
Robin2
As there seems to be no code in your program to set the content of the variable text1 to "No object found at (node2)" I can only assume that that message is what is being received by the nRF24
What are your Serial.print() statements showing?
...R
itsnaga015
#8
Dec 17, 2019, 11:59 am Last Edit: Dec 17, 2019, 12:51 pm by itsnaga015
yeah, the Serial monitor (master) displays the text what I transmitted at node 1, node2, node3 via nrf24l001.
This is the output obtained at the serial monitor.
in webserver, the output displays but not in a particular column or row.
like
node1- motion detected at node1 or No motion
node2- Object detected at node2 or No Object
node3-Fire detected at node3 or no Fire
 I Assigned it correctly, but don't know what went wrong. Any solution ??
Robin2
like
I'm confused. if the program is correctly receiving the data from the slaves I don't understand what problem you have.
And, for the future, please don't post pictures of text. Just copy and paste the text - it is much easier to read.
...R
itsnaga015
#10
Dec 17, 2019, 04:25 pm Last Edit: Dec 17, 2019, 05:25 pm by itsnaga015
@robin2 : i m new and learner  :) ,i  have problem in webserver, the output displays but not in a particular column or row.
As i mentioned earlier
In webserver it should print in particular row and column
Node                        STATUS
1-           motion detected at node1/No motion
2-           Object detected at node2 / No Object
3-            Fire detected at node3 / no Fire
I Assigned it correctly, or what went wrong . Any solution ??
Robin2
This sounds like a web programming problem rather than an Arduino problem. There are thousands of web pages with tutorials about web programming. I find w3schools very useful.
Can you post an example of how you want the output to appear.
...R
itsnaga015
#12
Dec 17, 2019, 05:50 pm Last Edit: Dec 17, 2019, 06:02 pm by itsnaga015
Example like  above, and status as per i get output in Arduino below i mentioned the details.
Node                        STATUS
Robin2
Node                        STATUS
If the things are just in the wrong order all you need to do is change the order in which the variables text1, text2 and text3 are displayed.
...R
itsnaga015
@robin2, hope you understood ?? or still, u didn't get what I facing. I wrote coding to display text it in webserver the thing is I get a random output like
Actually it as to display like this
Node                        STATUS
it displays randomly
Node                        STATUS
1-           NO motion detected at node1
3-           motion detected at node 1
random repeats,etc....
Node                        STATUS
1-           No object at node 2
3-           No object at node2
