Topic: Multiple libraries ...... (Read 472 times) previous topic - next topic
dpineau
HI,
I make a new installation in folder Arduino_portable_3
I add  folder "portable" next to arduino.exe
I compile, result:
error: WiFiManager.h: No such file or directory
OK, so I add the WiFiManager lib in sketchbook->libraries
I compile, result:
Multiple libraries were found for "WiFiManager.h"
How it is possible to have multiple if I install just one?
Daniel.
ballscrewbob
There are "stock" libraries too and it may also be warning you about those.
If you sketch compiles and works then don't worry as they are usually just warnings.
Bob.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google (who would have thunk it ! ) or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
dpineau
What do you mean by "stock" libraries
Daniel
ballscrewbob
Ones that are included with the IDE itself would be considered "stock" or part of the install itself regardless of portable or other install methods.
They come WITH the IDE.
Bob.
sterretje
Bob.
Before installing the library in question by OP, he/she had the problem that was not found.
Puzzles me too.
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
ballscrewbob
Unless there were multiple variants in the same lib ?
But I don't think it would / should read them all if it was only compiling for a single architecture ?
dpineau
Do you mean that the problem comes from the library itself?
RudolfAtRTC
An amusing or annoying discussion on the same topic: several libraries ...
Please always mention first: It is a weakness of the Arduino IDE and must / can be ignored until the IDE is finally repaired.
dpineau
avandalen
#9
Jan 07, 2020, 09:30 am Last Edit: Jan 07, 2020, 09:33 am by avandalen
I also have this problem and have a very simple example that shows the Arduino bug.
There is just one library Streaming installed here, on:
D:\Albert\Documents\Arduino\libraries
I searched well on my PC and there is nowhere a second Streaming lib present.
This is the very simple sketch:
Code: [Select]
#include <Streaming.h>
{ m
I
The error Multiple libraries were found for "Streaming.h" is shown
If I delete the m, the result is: compiling done, no further messages
sterretje
@avandalen
Using Arduino IDE 1.8.5, I tried to reproduce the behaviour, but I do not get the "multiple libraries" warning with the code you provided.
Note: I do not have additional board packages (e.g. for esp stuff) installed
