Topic: Custom SAMD51 Board (Add pins in variant files) Issue (Read 3600 times) previous topic - next topic
MartinL
Hi S1buell,
As westfw stated: where the entries appear in the g_APinDescription array is important.
In your "variant.cpp" file, by inserting an additional line for PB04 at position 20:
Code: [Select]
{ PORTB,  4, PIO_ANALOG, PIN_ATTR_ANALOG, ADC_Channel6, NOT_ON_PWM, NOT_ON_TIMER, EXTERNAL_INT_4 }, //Added this line, Line 20
...effectively shunts all the subsequent entries down by 1, so your entry at position 37 is now at 38. However your "variant.h" file still defines A6 as position 37:
Code: [Select]
#define PIN_A6               (37ul) //added this line A5 is pin 37
Does it work if you comment out additional entry for position 20?
I'm unable to test port pin PB04 myself, as unfortunately neither my custom or Adafruit M4 boards breakout this pin.
S1buell
@MartinL, thanks for you help!
Here is what i changed and the full code:
1. Minnor changes
Code: [Select]
#define PINS_COUNT           (37u) // from 36u
#define NUM_ANALOG_INPUTS    (7u) //was 6u
2. Changed this to it can point to 37 instead of just p+14 (would be correct if it was ate position 21)
Code: [Select]
#define analogInputToDigitalPin(p)  ((p < 6u) ? (p) + 14u : ( (p == 7u) ? 37u : -1)) //((p < 7u) ? (p) + 14u : -1)
3. Added pinA06
Code: [Select]
#define PIN_A6               (37ul) //added this line A6 is pin 37
static const uint8_t A6  = PIN_A6;
4. Added line 37 in g_APinDescription
Code: [Select]
 { PORTB,  4, PIO_ANALOG, PIN_ATTR_ANALOG, ADC_Channel6, NOT_ON_PWM, NOT_ON_TIMER, EXTERNAL_INT_4 }, //Added this line, Line 37
With all those changes, i can still read all my analog pins until A5, but stil cant read A6. =/ It is located in PB04 of 64pin SAMD51J21 (http://ww1.microchip.com/downloads/en/DeviceDoc/60001507E.pdf)
Variant.h
Code: [Select]
#ifndef _VARIANT_SAMD51_THING_PLUS_
#define _VARIANT_SAMD51_THING_PLUS_
// The definitions here needs a SAMD core >=1.6.10
#define ARDUINO_SAMD_VARIANT_COMPLIANCE 10610
 *        Definitions
/** Frequency of the board main oscillator */
#define VARIANT_MAINOSC (32768ul)
/** Master clock frequency */
#define VARIANT_MCK  (120000000ul)
#define VARIANT_GCLK0_FREQ (120000000UL)
#define VARIANT_GCLK1_FREQ (48000000UL)
#define VARIANT_GCLK2_FREQ (100000000UL)
 *        Headers
#include "WVariant.h"
#ifdef __cplusplus
#include "SERCOM.h"
#include "Uart.h"
#endif // __cplusplus
#ifdef __cplusplus
extern "C"
 *        Pins
// Number of pins defined in PinDescription array
#define NUM_DIGITAL_PINS     (20u)
#define NUM_ANALOG_OUTPUTS   (1u)
#define digitalPinToPort(P)        ( &(PORT->Group[g_APinDescription[P].ulPort]) )
#define digitalPinToBitMask(P)     ( 1 << g_APinDescription[P].ulPin )
//#define analogInPinToBit(P)        ( )
#define portOutputRegister(port)   ( &(port->OUT.reg) )
#define portInputRegister(port)    ( &(port->IN.reg) )
#define portModeRegister(port)     ( &(port->DIR.reg) )
#define digitalPinHasPWM(P)        ( g_APinDescription[P].ulPWMChannel != NOT_ON_PWM || g_APinDescription[P].ulTCChannel != NOT_ON_TIMER )
 * digitalPinToTimer(..) is AVR-specific and is not defined for SAMD
 * architecture. If you need to check if a pin supports PWM you must
 * use digitalPinHasPWM(..).
 * https://github.com/arduino/Arduino/issues/1833
// #define digitalPinToTimer(P)
// LEDs
#define PIN_LED_13           (13u)
#define PIN_LED_RXL          (25u)
#define PIN_LED_TXL          (26u)
#define PIN_LED              PIN_LED_13
#define PIN_LED2             PIN_LED_RXL
#define PIN_LED3             PIN_LED_TXL
#define LED_BUILTIN          PIN_LED_13
 * Analog pins
#define PIN_A0               (14ul)
#define PIN_A1               (PIN_A0 + 1)
#define PIN_A2               (PIN_A0 + 2)
#define PIN_A3               (PIN_A0 + 3)
#define PIN_A4               (PIN_A0 + 4)
#define PIN_A5               (PIN_A0 + 5)
#define PIN_DAC0             (14ul)
#define PIN_DAC1             PIN_A1
static const uint8_t A0  = PIN_A0;
static const uint8_t A1  = PIN_A1;
static const uint8_t A2  = PIN_A2;
static const uint8_t A3  = PIN_A3;
static const uint8_t A4  = PIN_A4;
static const uint8_t A5  = PIN_A5;
static const uint8_t DAC0 = PIN_DAC0;
static const uint8_t DAC1 = PIN_DAC1;
#define ADC_RESOLUTION 12
// Other pins
#define PIN_ATN              (30ul)
static const uint8_t ATN = PIN_ATN;
 * Serial interfaces
// Serial1
#define PIN_SERIAL1_RX       (0ul)
#define PIN_SERIAL1_TX       (1ul)
#define PAD_SERIAL1_RX       SERCOM_RX_PAD_1
#define PAD_SERIAL1_TX       UART_TX_PAD_0
 * SPI Interfaces
#define SPI_INTERFACES_COUNT 2
#define PIN_SPI_MISO         (22u)
#define PIN_SPI_MOSI         (23u)
#define PIN_SPI_SCK          (24u)
#define PERIPH_SPI           sercom4
#define PAD_SPI_TX           SPI_PAD_0_SCK_1
#define PAD_SPI_RX           SERCOM_RX_PAD_3
static const uint8_t SS  = 9 ; // SERCOM4 last PAD is present on d9 but HW SS isn't used. Set here only for reference.
static const uint8_t MOSI = PIN_SPI_MOSI ;
static const uint8_t MISO = PIN_SPI_MISO ;
static const uint8_t SCK  = PIN_SPI_SCK ;
#define PIN_SPI1_MISO         (35u)
#define PIN_SPI1_MOSI         (36u)
#define PIN_SPI1_SCK          (33u)
#define PERIPH_SPI1           sercom0
#define PAD_SPI1_TX           SPI_PAD_0_SCK_1
#define PAD_SPI1_RX           SERCOM_RX_PAD_3
static const uint8_t FLASH_SS = 34 ; // SERCOM0 last PAD is present on 34 but HW SS isn't used. Set here only for reference.
static const uint8_t FLASH_MOSI = PIN_SPI1_MOSI ;
static const uint8_t FLASH_MISO = PIN_SPI1_MISO ;
static const uint8_t FLASH_SCK  = PIN_SPI1_SCK ;
 * Wire Interfaces
#define WIRE_INTERFACES_COUNT 1
#define PIN_WIRE_SDA         (20u)
#define PIN_WIRE_SCL         (21u)
#define PERIPH_WIRE          sercom3
#define WIRE_IT_HANDLER      SERCOM3_Handler
#define WIRE_IT_HANDLER_0    SERCOM3_0_Handler
#define WIRE_IT_HANDLER_1    SERCOM3_1_Handler
#define WIRE_IT_HANDLER_2    SERCOM3_2_Handler
#define WIRE_IT_HANDLER_3    SERCOM3_3_Handler
static const uint8_t SDA = PIN_WIRE_SDA;
static const uint8_t SCL = PIN_WIRE_SCL;
 * USB
#define PIN_USB_HOST_ENABLE (27ul)
#define PIN_USB_DM          (28ul)
#define PIN_USB_DP          (29ul)
 * I2S Interfaces
#define I2S_INTERFACES_COUNT 1
#define I2S_DEVICE          0
#define I2S_CLOCK_GENERATOR 3
#define PIN_I2S_SDO          (11u)
#define PIN_I2S_SDI          (12u)
#define PIN_I2S_SCK          PIN_SERIAL1_TX
#define PIN_I2S_FS           (10u)
#define PIN_I2S_MCK          PIN_SERIAL1_RX
//QSPI Pins
//#define PIN_QSPI_SCK    (34u)
//#define PIN_QSPI_CS     (35u)
//#define PIN_QSPI_IO0    (36u)
//#define PIN_QSPI_IO1    (37u)
//#define PIN_QSPI_IO2    (38u)
//#define PIN_QSPI_IO3    (39u)
//TODO: meaningful value for this
//#define VARIANT_QSPI_BAUD_DEFAULT 5000000
#ifdef __cplusplus
#endif
 *        Arduino objects - C++ only
#ifdef __cplusplus
 * ===== SERCOM DEFINITION
extern SERCOM sercom0;
extern SERCOM sercom1;
extern SERCOM sercom2;
extern SERCOM sercom3;
extern SERCOM sercom4;
extern SERCOM sercom5;
extern Uart Serial1;
#endif
// These serial port names are intended to allow libraries and architecture-neutral
// sketches to automatically default to the correct port name for a particular type
// of use.  For example, a GPS module would normally connect to SERIAL_PORT_HARDWARE_OPEN,
// the first hardware serial port whose RX/TX pins are not dedicated to another use.
// SERIAL_PORT_MONITOR        Port which normally prints to the Arduino Serial Monitor
// SERIAL_PORT_USBVIRTUAL     Port which is USB virtual serial
// SERIAL_PORT_LINUXBRIDGE    Port which connects to a Linux system via Bridge library
// SERIAL_PORT_HARDWARE       Hardware serial port, physical RX & TX pins.
// SERIAL_PORT_HARDWARE_OPEN  Hardware serial ports which are open for use.  Their RX & TX
//                            pins are NOT connected to anything by default.
#define SERIAL_PORT_USBVIRTUAL      Serial
#define SERIAL_PORT_MONITOR         Serial
// Serial has no physical pins broken out, so it's not listed as HARDWARE port
#define SERIAL_PORT_HARDWARE        Serial1
#define SERIAL_PORT_HARDWARE_OPEN   Serial1
#endif /* _VARIANT_FEATHER_M4_ */
S1buell
Variant.cpp
Code: [Select]
#include "variant.h"
 * Pins descriptions
//TCC0 IOSET 6
//TCC1 IOSET 1
//TC0 IOSET 1
//TC1 IOSET 1
//TC2 IOSET 2
//TC3 IOSET 1
//TC4 IOSET 1
const PinDescription g_APinDescription[]=
  // 0..13 - Digital pins
  // 0/1 - SERCOM/UART (Serial1)
  { PORTA, 13, PIO_SERCOM, PIN_ATTR_PWM_G, No_ADC_Channel, TC2_CH1, NOT_ON_TIMER, EXTERNAL_INT_13 }, // RX: SERCOM2/PAD[1]
  { PORTA, 12, PIO_SERCOM, PIN_ATTR_PWM_G, No_ADC_Channel, TC2_CH0, NOT_ON_TIMER, EXTERNAL_INT_12 }, // TX: SERCOM2/PAD[2]
  // 2..12
  // Digital
  { NOT_A_PORT, 0,  PIO_NOT_A_PIN, PIN_ATTR_NONE, No_ADC_Channel, NOT_ON_PWM, NOT_ON_TIMER, EXTERNAL_INT_NONE },
  { PORTA, 6, PIO_DIGITAL, PIN_ATTR_PWM_E, No_ADC_Channel, TC1_CH0, TC1_CH0, EXTERNAL_INT_6 },
  { PORTA,  15, PIO_TIMER_ALT, PIN_ATTR_PWM_F, No_ADC_Channel, TCC2_CH1, TC3_CH1, EXTERNAL_INT_2  },
  { PORTA,  20, PIO_TIMER_ALT, PIN_ATTR_PWM_F, No_ADC_Channel, TCC0_CH0, TC7_CH0, EXTERNAL_INT_4 },
  { PORTA,  7,  PIO_DIGITAL, PIN_ATTR_DIGITAL, No_ADC_Channel, NOT_ON_PWM, NOT_ON_TIMER, EXTERNAL_INT_NONE }, //pin 9
  { PORTA,  18, PIO_TIMER_ALT, PIN_ATTR_PWM_F, No_ADC_Channel, TCC1_CH2, TC3_CH0, EXTERNAL_INT_2 },
  { PORTA,  16, PIO_TIMER_ALT, PIN_ATTR_PWM_G, No_ADC_Channel, TCC1_CH0, NOT_ON_TIMER, EXTERNAL_INT_0 },
  { PORTA,  19, PIO_TIMER_ALT, PIN_ATTR_PWM_F, No_ADC_Channel, TCC1_CH3, TC3_CH1, EXTERNAL_INT_3 },
  // 13 (LED)
  { PORTA, 17, PIO_DIGITAL, PIN_ATTR_PWM_G, No_ADC_Channel, TCC0_CH3, TC4_CH1, EXTERNAL_INT_1 }, // TCC2/WO[1]
  // 14..19 - Analog pins
  { PORTA,  2, PIO_ANALOG, PIN_ATTR_ANALOG, ADC_Channel0, NOT_ON_PWM, NOT_ON_TIMER, EXTERNAL_INT_2 },
  { PORTB,  8, PIO_ANALOG, (PIN_ATTR_ANALOG|PIN_ATTR_PWM_E), ADC_Channel2, TC4_CH0, TC4_CH0, EXTERNAL_INT_8 },
  { PORTB,  9, PIO_ANALOG, (PIN_ATTR_ANALOG|PIN_ATTR_PWM_E), ADC_Channel3, TC4_CH1, TC4_CH1, EXTERNAL_INT_9 },
  { PORTA,  4, PIO_ANALOG, (PIN_ATTR_ANALOG|PIN_ATTR_PWM_E), ADC_Channel4, TC0_CH0, TC0_CH0, EXTERNAL_INT_6 },
  { PORTA,  5, PIO_ANALOG, PIN_ATTR_ANALOG, ADC_Channel5, NOT_ON_PWM, NOT_ON_TIMER, EXTERNAL_INT_5 },
  { PORTB,  2, PIO_ANALOG, (PIN_ATTR_ANALOG|PIN_ATTR_PWM_E), ADC_Channel14, TC6_CH0, TC6_CH0, EXTERNAL_INT_2 },
  // 20..21 I2C pins (SDA/SCL)
  { PORTA, 22, PIO_SERCOM, PIN_ATTR_PWM_G, No_ADC_Channel, TC4_CH0, TC4_CH0, EXTERNAL_INT_6 }, // SDA: SERCOM3/PAD[0]
  { PORTA, 23, PIO_SERCOM, PIN_ATTR_PWM_G, No_ADC_Channel, TC4_CH1, TC4_CH1, EXTERNAL_INT_7 }, // SCL: SERCOM3/PAD[1]
  // 22..24 - SPI pins (MISO,MOSI,SCK)
  { PORTB, 11, PIO_SERCOM_ALT, PIN_ATTR_DIGITAL, No_ADC_Channel, NOT_ON_PWM, NOT_ON_TIMER, EXTERNAL_INT_11 }, // MISO: SERCOM4/PAD[3]
  { PORTB, 12, PIO_SERCOM, PIN_ATTR_DIGITAL, No_ADC_Channel, NOT_ON_PWM, NOT_ON_TIMER, EXTERNAL_INT_12 }, // MOSI: SERCOM4/PAD[0]
  { PORTB, 13, PIO_SERCOM, PIN_ATTR_DIGITAL, No_ADC_Channel, NOT_ON_PWM, NOT_ON_TIMER, EXTERNAL_INT_13 }, // SCK: SERCOM4/PAD[1]
  // 25..26 - RX/TX LEDS  -- unused
  // 27..29 - USB
  { NOT_A_PORT, 0, PIO_NOT_A_PIN, PIN_ATTR_NONE, No_ADC_Channel, NOT_ON_PWM, NOT_ON_TIMER, EXTERNAL_INT_NONE }, // USB Host enable DOES NOT EXIST ON THIS BOARD
  { PORTA, 24, PIO_COM, PIN_ATTR_NONE, No_ADC_Channel, NOT_ON_PWM, NOT_ON_TIMER, EXTERNAL_INT_NONE }, // USB/DM
  { PORTA, 27, PIO_COM, PIN_ATTR_NONE, No_ADC_Channel, NOT_ON_PWM, NOT_ON_TIMER, EXTERNAL_INT_NONE }, // USB/DP
  // 30 (AREF)
  { PORTA, 3, PIO_ANALOG, PIN_ATTR_ANALOG, No_ADC_Channel, NOT_ON_PWM, NOT_ON_TIMER, EXTERNAL_INT_NONE }, // DAC/VREFP
  // 31..32 - Alternate use of A0/A4 (DAC output)
  { PORTA,  2, PIO_ANALOG, PIN_ATTR_ANALOG, DAC_Channel0, NOT_ON_PWM, NOT_ON_TIMER, EXTERNAL_INT_NONE }, // DAC/VOUT0
  { PORTA,  5, PIO_ANALOG, PIN_ATTR_ANALOG, DAC_Channel1, NOT_ON_PWM, NOT_ON_TIMER, EXTERNAL_INT_NONE }, // DAC/VOUT1
  // 33..36 SPI for Flash (SCK, CS, MISO, MOSI)
  { PORTA, 9, PIO_COM, PIN_ATTR_NONE, No_ADC_Channel, NOT_ON_PWM, NOT_ON_TIMER, EXTERNAL_INT_NONE }, //SCK
  { PORTA, 10, PIO_COM, PIN_ATTR_NONE, No_ADC_Channel, NOT_ON_PWM, NOT_ON_TIMER, EXTERNAL_INT_NONE }, //CS
  { PORTA, 11, PIO_COM, PIN_ATTR_NONE, No_ADC_Channel, NOT_ON_PWM, NOT_ON_TIMER, EXTERNAL_INT_NONE }, //MISO
  { PORTA, 8, PIO_COM, PIN_ATTR_NONE, No_ADC_Channel, NOT_ON_PWM, NOT_ON_TIMER, EXTERNAL_INT_NONE }, //MOSIZ
const void* g_apTCInstances[TCC_INST_NUM+TC_INST_NUM]={ TCC0, TCC1, TCC2, TCC3, TCC4, TC0, TC1, TC2, TC3, TC4, TC5 } ;
const uint32_t GCLK_CLKCTRL_IDs[TCC_INST_NUM+TC_INST_NUM] = { TCC0_GCLK_ID, TCC1_GCLK_ID, TCC2_GCLK_ID, TCC3_GCLK_ID, TCC4_GCLK_ID, TC0_GCLK_ID, TC1_GCLK_ID, TC2_GCLK_ID, TC3_GCLK_ID, TC4_GCLK_ID, TC5_GCLK_ID } ;
// Multi-serial objects instantiation
SERCOM sercom0( SERCOM0 ) ;
SERCOM sercom1( SERCOM1 ) ;
SERCOM sercom2( SERCOM2 ) ;
SERCOM sercom3( SERCOM3 ) ;
SERCOM sercom4( SERCOM4 ) ;
SERCOM sercom5( SERCOM5 ) ;
Uart Serial1( &sercom2, PIN_SERIAL1_RX, PIN_SERIAL1_TX, PAD_SERIAL1_RX, PAD_SERIAL1_TX ) ;
void SERCOM2_0_Handler()
  Serial1.IrqHandler();
void SERCOM2_1_Handler()
void SERCOM2_2_Handler()
void SERCOM2_3_Handler()
MartinL
Hi S1buell,
Position 37 requires the PIN_ATTR_ANALOG_ALT attribute:
Code: [Select]
{ PORTB, 4, PIO_ANALOG, PIN_ATTR_ANALOG_ALT, ADC_Channel6, NOT_ON_PWM, NOT_ON_TIMER, EXTERNAL_INT_4 }, // ADC1/AIN[6]
It's the same as the PB04 port pin in Adafruit's Grand Central Metro M4 "variant.cpp" file:
Code: [Select]
S1buell
Hello MartinL!
I really apreciate your help! With this i could read PB04, PB05, PB30, PB31. Thank you very much for your support!
I'm currently trying to read PB00 and PB01, and without success.
I've tried using the following combinations:
Code: [Select]
PIN_ATTR_ANALOG_ALT
Code: [Select]
(PIN_ATTR_ANALOG_ALT|PIN_ATTR_PWM_E)
Code: [Select]
PIN_ATTR_ANALOG
Maybe it has something to do with the code bellow, but not so shure...
Code: [Select]
#define PINS_COUNT           (42u)
#define NUM_DIGITAL_PINS     (22u)
#define NUM_ANALOG_INPUTS    (10u)
#define analogInputToDigitalPin(p)  ((p < 6u) ? (p) + 14u : ((p < 10u) ? (p) + 37u : -1)) //((p < 7u) ? (p) + 14u : -1)
Code: [Select]
  // %%%%%%%%%%%%%%%%%%%%%%%      ADDED LINES BELLOW      %%%%%%%%%%%%%%%%%%%%%%%%%%%
  // 37..40 - Analog pins
  { PORTB,  5, PIO_ANALOG, PIN_ATTR_ANALOG_ALT, ADC_Channel7, NOT_ON_PWM, NOT_ON_TIMER, EXTERNAL_INT_5 }, //A6 - OK
  { PORTB,  4, PIO_ANALOG, PIN_ATTR_ANALOG_ALT, ADC_Channel6, NOT_ON_PWM, NOT_ON_TIMER, EXTERNAL_INT_4 }, // A7 - OK
  { PORTB,  0, PIO_ANALOG, (PIN_ATTR_ANALOG_ALT|PIN_ATTR_PWM_E), ADC_Channel3, TC7_CH0, TC7_CH0, EXTERNAL_INT_0 }, // A8
  { PORTB,  1, PIO_ANALOG, (PIN_ATTR_ANALOG_ALT|PIN_ATTR_PWM_E), ADC_Channel4, TC7_CH1, TC7_CH1, EXTERNAL_INT_1 }, // A9
  // 41..42 - Digital pins
  { PORTB,  30, PIO_DIGITAL, (PIN_ATTR_DIGITAL), No_ADC_Channel, TCC4_CH0, TC0_CH0, EXTERNAL_INT_14 }, // D41
  { PORTB,  31, PIO_DIGITAL, (PIN_ATTR_DIGITAL), No_ADC_Channel, TCC4_CH1, TC0_CH1, EXTERNAL_INT_15 }, // D42
MartinL
Hi S1buell,
Port pins PB00 and PB01 are on ADC0/AIN[12] and ADC0/AIN[13] respectively. This information is taken from the SAMD51 Datasheet's "I/O Multiplexing and Considerations" table.
Therefore it should be possible to set up an analog pin for PB00:
Code: [Select]
{ PORTB, 0, PIO_ANALOG, PIN_ATTR_ANALOG, ADC_Channel12, NOT_ON_PWM, NOT_ON_TIMER, EXTERNAL_INT_0 }, // ADC0/AIN[12]
and for PB01:
Code: [Select]
{ PORTB, 1, PIO_ANALOG, PIN_ATTR_ANALOG, ADC_Channel13, NOT_ON_PWM, NOT_ON_TIMER, EXTERNAL_INT_1 }, // ADC0/AIN[13]
