Topic: Arduino IDE uploads to board, but cannot open serial monitor for one sketch (Read 583 times) previous topic - next topic
nbelakovski
Normally everything works fine, but with the sketch below, I can upload it to Arduino Uno just fine, but when I click on serial monitor, I get the error:
Serial port '/dev/ttyACM0' not found. Did you select the right one from...
Here's the sketch, which reads data from a GPS device, and then stores the highest altitude it sees in an array. When it sees a higher altitude, it moves everything in the array over by 1, so it can keep track of the 10 highest altitudes registered. Then it just prints the altitude array.
Code: [Select]
#include "TinyGPS.h"
#include <NewSoftSerial.h>
TinyGPS gps;
NewSoftSerial nss(2,4,true);
int maxaltitude[10] = {0};
int testalt = 0;
char byteGPS;
int i = 0;
int j = 0;
  nss.begin(4800);
  pinMode(13,OUTPUT);
  if (nss.available())
    digitalWrite(13, HIGH);
    byteGPS = nss.read();
      if (gps.encode(byteGPS))
        testalt = gps.f_altitude();
  if (testalt > maxaltitude[0])
    i = 9;
    while (i > 0)
      maxaltitude[i] = maxaltitude[i-1];
      i--;
    maxaltitude[0] = testalt;
  Serial.println("New altitude string:");
  j = 0;
  while (j < 9)
    Serial.println(maxaltitude[j]);
    j++;
On this code, it works fine: (this code just reads data from the GPS device and prints it to the screen)
Code: [Select]
char bytegps;
  nss.begin(4800);
    bytegps = nss.read();
    Serial.print(bytegps);
Is it an issue with my code or is there something else going on? Thanks in advance.
