Topic: Freetronics Eleven vs Genuine Arduino (Read 9717 times) previous topic - next topic
KingBigness
I would love to get started in Arduino but unfortunately the only way I can get them to where I live (Sydney) is in the mail. I have seen that the local JayCar stocks Freetronics Eleven and I was wondering if you guys like these boards. I don't normally like buying something that tries to be like something else, and says it is better without stating why.
Also if you guys know anywhere in Sydney you can buy Arduino boards I would be very greatful
Thank you
graynomad
I have a Freetronics 2010 and it's just fine. Never done anything it shouldn't and always done what it should :)
Most of the Arduino boards around are clones, I wouldn't worry about it especially from a well-known supplier (which Freetronics are).
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
CrossRoads
That looks like a great board, I would have started arduino-ing with a twenty-ten if it had been available in the US at the time.
Drop some wirewrap sockets in the holes, add a couple shift registers or something, be good to go!
You will not go wrong with that board. Its all the same components, layed out a little differently, with better (IMO) frequency source, and the mini usb connector in place of the big blocky square one that is not is use on many components anymore.
It took me a little while but eventually I just made my own designs using a duemilanove to program blank '328 chips and drop them in my circuit.
You can see the '328, crystal, 22 pf caps, and power supply 100nF caps in the lower left corner.
This application does not need USB serial  (does use UART's TTL serial to transmit to another built up card tho), power is from external 5V supply.
anders2009
I have no experience with the Freetronics Eleven, but I have tried other clones (Seeeduino and Freeduino) without problems. I would even hold the Seeeduino to be slightly better than the original.
If it says 100% compatible you can probably expect it to be.
Good luck!
tim7
That Freetronics board looks rather good.  Does anybody know if they're available in Europe?
bubulindo
I haven't tried Freetronics yet, although I've been tempted by Etherten and I have the same problem as you. I can only get it in the mail. ;)
As for your question...
I got this from the website:
Quote
As well as the standard Arduino Uno features found here, the Eleven has the following improvements and updates:
Prototyping area
For those projects where you don't need the extra size or expense of a shield, the Eleven has its own standard prototyping area taking up a quarter of the board. Great for quick sensor and IC projects. There's extra power pads underneath for neat connections.
LEDs visible on the edge
Wondered what your Arduino was doing? We've carefully placed a nice blue Power LED, plus colour coded RX, TX and D13 LEDs on the right edge of the board so you can see what's going on.
Dual crystals
We've provided proper crystals for both the primary MCU and the communications MCU, rather than using a ceramic resonator.
Mini-USB Connector
No more short circuits of the large USB connector against your shields. Our standard Mini-USB connector is firmly mounted and we've included a cable too.
Overlay guide where you need it
When you're soldering your project, it's good to know what you're connecting to! All of our boards and shields have a thorough pinout and guide printed on the bottom as well as the top, so when you're soldering underneath there's no need to flip the board over constantly.
Top spec MCU
Every Eleven has the higher specification ATmega328P Microcontroller.
D13 pin works for everything
The digital I/O pin 13 functionality has been fixed, the D13 indicator LED no longer loads up this pin when you use it as an input.
Mounting holes and power jack
We've included a fourth mounting hole in the bottom left, there's no more wobbly board troubles if you're fitting it to a case.
Helpful markings for the Power Jack size, polarity and voltage are right there on the board when you need them. Auto-power switching and self-resetting fuse protection are standard.
It's all in the same place
The power jack, headers and ICSP are all in exactly the same location as Arduino standard boards. The Eleven is perfectly compatible with all Arduino shields, projects and sketches.
I agree with all this except the point where the Arduino doesn't use the ATmega328p.
Satisfied?
This... is a hobby.
mtronic
lipoly.de stocks the www.freetronics.com products (Eleven, EtherTen, etc)
http://www.lipoly.de/index.php?main_page=index&cPath=880_2651
Cheers,
Marc
robtillaart
Thanks Marc for the link!
The P&P is even cheaper than some shops in the Netherlands  ....
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
lemming
Quote
Try Littlebird Electronics:  http://littlebirdelectronics.com/collections/arduino
