Topic: Ethernet shield not found (Read 2191 times) previous topic - next topic
PLZR
Hello everyone,
 I try as best I can to understand why my ethernet shield is not recognized by my arduino UNO ...
 Currently I am using the basic IDE examples.  But at each initialization I have:
« Ethernet shield was not found.  Sorry, can't run without hardware.  :( »
 Do you have an idea?  I have absolutely nothing connected on the shield (Pin In / out), the shield is well pressed on the UNO, and connected to my home ethernet switch.  All the LEDs seem to flash correctly anyway.
 It is a shield w5100 from SUNFOUNDER, new, first use
Any help?
spycatcher2k
I see this type of post all too often.
WHAT library are you using? WHAT code are you using? What did SUNFOUNDER say when you contected them about their shield?
No-one can guess what code or library you are using!
Mrs Drew
UK Based PCB Manufacturing - PM for details
I will design & code for you, but I will also charge you (PM me)
Use Google or search this site BEFORE asking!
PLZR
Thanks for your answer but I solved by myself my problem yesterday evening... I finally reduced the length of the shield legs by few milimeters and now everything is working fine ! :)
