Topic: Serial communication problem with Mega 2560 (Read 1 time) previous topic - next topic
epicguy
Right.
Something has happened to my Arduino board (got it in march-april this year), which makes me unable to communicate with it via USB.
I can't upload sketches or update the firmware.
I've tried the all the regular stuff that's recommended in the forum to get it working.
The TX/RX leds never light up, not even when booting, but the 'L' led is always dimly lit.
I've tried it with Windows, OS X and Ubuntu, so it's not a OS specific problem.
This is what I get when I try to upload a sketch:
Code: [Select]
/usr/share/arduino/hardware/tools/avrdude -C/usr/share/arduino/hardware/tools/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P/dev/ttyACM0 -b115200 -D -Uflash:w:/tmp/build2222393668295502507.tmp/Blink.cpp.hex:i
avrdude: Version 5.10, compiled on Jun 29 2010 at 03:44:14
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "/usr/share/arduino/hardware/tools/avrdude.conf"
         User configuration file is "/home/chris/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/ttyACM0
         Using Programmer              : stk500v2
         Overriding Baud Rate          : 115200
avrdude: Send: . [1b] . [01] . [00] . [01] . [0e] . [01] . [14]
avrdude: ser_recv(): programmer is not responding
avrdude: stk500_2_ReceiveMessage(): timeout
If I try to re-flash the board with dfu-programmer I get the following:
Code: [Select]
dfu-programmer at90usb82 erase
dfu-programmer: no device present.
Strange thing is that the board is recognized in Windows as Arduino Mega 2560, and in Linux the dmesg output is (in OS X I get a popup telling me a new network interface has been connected or something like that):
Code: [Select]
[64347.976064] usb 2-2: new full speed USB device using uhci_hcd and address 24
[64348.178966] cdc_acm 2-2:1.0: ttyACM0: USB ACM device
spycatcher2k
Can you post a link where you purchased the arduino please - are you sure it has a at90usb82 - it may have an ftdi chip - if you don't have a link then post a close up picture of the small chip close to the USB Chip.
Drew.
Mrs Drew
http://www.uk-pcb.co.uk - UK PCB Fab Company
I will design & code for you, but I will also charge you (PM me)
If you don't like my answers, realize : I'm not being cheeky, I'm Just trying to prompt you to use your own brain/google etc.
epicguy
I only have a pretty crappy iPhone camera, but the label on the chip below the USB port is:
ATMEL
MEGA8U2
1013       TH
9F4286-2
spycatcher2k
Its the correct chip!!
Have a <b>CLOSE</b> look at the chip and surrounding components for missaligned components or dry looking solder joints.
If there is, fix that if you can.
But as its under a year old (assuming its official)
Best to return it for exchange for a new one. If its a clone - Contact the supplier and see what they are willing to do.
Drew.
Mrs Drew
