Topic: Binary Intervalometer (Read 8820 times) previous topic - next topic
physic.dude
#15
Jul 06, 2011, 12:11 am Last Edit: Jul 06, 2011, 12:14 am by physics-dude Reason: 1
What aperture were you at?
In the first segment of the video I was at f/3.5 at 18mm
The second segment was at f/5.6 at 200mm
The third segment was at f/5.0 at 65mm
And the final sunset segment was at f/22 at 32mm
I have never experienced flickering from the aperture as is settles in place, although I can see why this would happen. I don't think I have ever experienced this is because my camera, the D3100, being entry level (and becoming a little under-featured for me) has a slow burst rate of 3 frames per second. Since the entire mechanism is considerably slow this would allow some time for the aperture blades to settle before the sensor gets exposed.
If your camera has a quiet mode, I suggest that you try taking time lapses with that and see if the flickering improves. This may include a delay between closing the aperture and opining the shutter.
Kaouthia
Yes, perhaps it is a case of "budget is better" for this particular application.  That's one problem with these entry level cameras.  They have just enough features to entice you in, but if you get serious about it, you rapidly outgrow them and you end up with a second body that you can't sell and will probably never use again, heh.
Watching the video again, I can see a little flicker in the f/22 sequence, but not much, certainly not as much as I've experienced with some lenses, so still very impressive. It might be the slower framerate that's making it less obvious too.
The problem with quite mode is that I'm using an external intervalometer to control the exposure (shutter speed) for bulb ramping.  So, using quiet mode and having that delay throws all the calculations off, and getting the timing ms perfect to cover that initial delay can be tricky. :)
But, even using the built in interval timer, using either the quiet mode or the delay feature which locks up the mirror before the shot, flicker can (and often does) happen.  Try some other lenses, it might be that the lens & body combo you're using is particularly well suited to this kind of task, so you haven't noticed it yet.  I have a Sigma 10-20mm f/4-5.6, which is an absolutely fantastic lens, but doing beach cloud scenes it flickers like crazy once you get down to f/8-f/16 and you're playing it back at 24fps - Fortunately I have the B+W 10 stop ND filter, some rather sexy Schneider 4x5.65" ND filters and the Z-Pro holder so I can shoot it wide open (where the Sigma performs beautifully) and still lose up to 20 stops of light if need be (very nice for those long exposures with the sun in the shot).
This is one I shot on the Sigma that wasn't too bad (although Youtube's compression gives it horrible moirĂ© and artifacting issues).  http://www.youtube.com/watch?v=jVZL9Wv9CwM&hd=1
With the M42 lenses, there's no workarounds needed.  I put them on my D200 & D300s bodies using an M42->Nikon adapter with a diopter to retain infinity focus, and the aperture never changes (because the camera isn't setting it each time it takes a shot, it's controlled on the lens itself and stays constant throughout).  Because most of them are 30-40 years old or more, and quality control was pretty much absent from their production, they can have some great character too. :)
John
physic.dude
@Kaouthia,
Another thing that could be lessoning this flickering in my case is the fact that I was using long espousers of 8 seconds for the night shots. This would average out the initial wrong-doing of the aperture.
physic.dude
I almost forgot, you people want a schematic don't you.
Here you go. (In main post too.)
http://www.flickr.com/photos/50241702@N04/5943905339/sizes/l/in/photostream/
a.d
This looks good - I though about doing binary but just stuck with the normal pot method for the time being. It seems to work well for you, and the board looks very clean as well! Nice.
novice
PhysicDude,
the layout, code, and write-up are all really well done - very functional and easily understood.
I'm impressed.
physic.dude
Thanks for the replies everyone!  :smiley-mr-green:
On my late trip to New York, I spent some time capturing over 6 full hours of time lapse footage. Ending up with a total of 5,563 images, all of which were taken by this awesome little device.
Have a look at the final result.
http://youtu.be/rqjRefAv3Us
And for a short, unedited time lapse segment from (almost) street level of the south side of times square.
http://youtu.be/Lb1O9HaTtYA
liuzengqiang
Awesome videos! Did security check the device?
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
physic.dude
Nope. They didn't even hold it in or run it back through the x-ray.  :smiley-mr-green:
