Topic: Cannot compile SD examples on Nano 33 Ble Sense (Read 540 times) previous topic - next topic
stangogh
I'm trying to compile the SD examples for the Nano 33 Ble Sense, but it fails with an error: "Multiple Libraries were found for SPI.h"
When I compile the CardInfo sketch, and select the Nano 33 Ble Sense as the board, I get the following error:
Quote
In file included from /Users/danoved/Library/Arduino15/packages/arduino/hardware/mbed/1.1.3/cores/arduino/mbed/platform/mbed_error.h:28:0,
                 from /Users/danoved/Library/Arduino15/packages/arduino/hardware/mbed/1.1.3/cores/arduino/mbed/rtos/Queue.h:28,
                 from /Users/danoved/Library/Arduino15/packages/arduino/hardware/mbed/1.1.3/cores/arduino/mbed/rtos/Mail.h:28,
                 from /Users/danoved/Library/Arduino15/packages/arduino/hardware/mbed/1.1.3/cores/arduino/mbed/rtos/rtos.h:33,
                 from /Users/danoved/Library/Arduino15/packages/arduino/hardware/mbed/1.1.3/cores/arduino/mbed/mbed.h:23,
                 from /Users/danoved/Library/Arduino15/packages/arduino/hardware/mbed/1.1.3/cores/arduino/Arduino.h:32,
                 from sketch/CardInfo.ino.cpp:1:
/Users/danoved/Library/Arduino15/packages/arduino/hardware/mbed/1.1.3/cores/arduino/mbed/platform/mbed_retarget.h:62:18: error: expected unqualified-id before numeric constant
 #define O_RDONLY 0        ///< Open for reading
/Applications/Arduino 3.app/Contents/Java/libraries/SD/src/utility/SdFat.h:55:15: note: in expansion of macro 'O_RDONLY'
 uint8_t const O_RDONLY = O_READ;
/Users/danoved/Library/Arduino15/packages/arduino/hardware/mbed/1.1.3/cores/arduino/mbed/platform/mbed_retarget.h:63:18: error: expected unqualified-id before numeric constant
 #define O_WRONLY 1        ///< Open for writing
/Applications/Arduino 3.app/Contents/Java/libraries/SD/src/utility/SdFat.h:59:15: note: in expansion of macro 'O_WRONLY'
 uint8_t const O_WRONLY = O_WRITE;
/Users/danoved/Library/Arduino15/packages/arduino/hardware/mbed/1.1.3/cores/arduino/mbed/platform/mbed_retarget.h:64:18: error: expected unqualified-id before numeric constant
 #define O_RDWR   2        ///< Open for reading and writing
/Applications/Arduino 3.app/Contents/Java/libraries/SD/src/utility/SdFat.h:61:15: note: in expansion of macro 'O_RDWR'
 uint8_t const O_RDWR = (O_READ | O_WRITE);
/Users/danoved/Library/Arduino15/packages/arduino/hardware/mbed/1.1.3/cores/arduino/mbed/platform/mbed_retarget.h:72:22: note: in expansion of macro 'O_RDONLY'
 #define O_ACCMODE   (O_RDONLY|O_WRONLY|O_RDWR)
/Applications/Arduino 3.app/Contents/Java/libraries/SD/src/utility/SdFat.h:63:15: note: in expansion of macro 'O_ACCMODE'
 uint8_t const O_ACCMODE = (O_READ | O_WRITE);
/Users/danoved/Library/Arduino15/packages/arduino/hardware/mbed/1.1.3/cores/arduino/mbed/platform/mbed_retarget.h:62:18: error: expected ')' before numeric constant
/Users/danoved/Library/Arduino15/packages/arduino/hardware/mbed/1.1.3/cores/arduino/mbed/platform/mbed_retarget.h:66:20: error: expected unqualified-id before numeric constant
 #define O_APPEND   0x0008 ///< Set file offset to end of file prior to each write
/Applications/Arduino 3.app/Contents/Java/libraries/SD/src/utility/SdFat.h:65:15: note: in expansion of macro 'O_APPEND'
 uint8_t const O_APPEND = 0X04;
/Users/danoved/Library/Arduino15/packages/arduino/hardware/mbed/1.1.3/cores/arduino/mbed/platform/mbed_retarget.h:67:20: error: expected unqualified-id before numeric constant
 #define O_CREAT    0x0200 ///< Create file if it does not exist
/Applications/Arduino 3.app/Contents/Java/libraries/SD/src/utility/SdFat.h:69:15: note: in expansion of macro 'O_CREAT'
 uint8_t const O_CREAT = 0X10;
/Users/danoved/Library/Arduino15/packages/arduino/hardware/mbed/1.1.3/cores/arduino/mbed/platform/mbed_retarget.h:69:20: error: expected unqualified-id before numeric constant
 #define O_EXCL     0x0800 ///< Fail if file exists
/Applications/Arduino 3.app/Contents/Java/libraries/SD/src/utility/SdFat.h:71:15: note: in expansion of macro 'O_EXCL'
 uint8_t const O_EXCL = 0X20;
/Users/danoved/Library/Arduino15/packages/arduino/hardware/mbed/1.1.3/cores/arduino/mbed/platform/mbed_retarget.h:68:20: error: expected unqualified-id before numeric constant
 #define O_TRUNC    0x0400 ///< Truncate file to zero length
/Applications/Arduino 3.app/Contents/Java/libraries/SD/src/utility/SdFat.h:73:15: note: in expansion of macro 'O_TRUNC'
 uint8_t const O_TRUNC = 0X40;
Multiple libraries were found for "SPI.h"
 Used: /Users/danoved/Library/Arduino15/packages/arduino/hardware/mbed/1.1.3/libraries/SPI
Multiple libraries were found for "SD.h"
 Used: /Applications/Arduino
exit status 1
Error compiling for board Arduino Nano 33 BLE.
This error doesnt occur if I select ArduinoMKR1000 as the board.
An SD card would be ideal with the nano sense because you can use it to store all of the sensor data.
stangogh
Scratch that!  Updating to the latest version of the SD library fixed the issue :)
pert
Thanks for taking the time to post an update @stangogh. I'm glad to hear you got the SD library working with your Nano 33 BLE. Enjoy!
