Topic: optimization 2 (Read 111 times) previous topic - next topic
ludocraft
Hello
after a request on a previous post to know how to optimize
Write_Max7219(1, B00000000)
Write_Max7219(2, B00000000)
Write_Max7219(3, B00000000)
Write_Max7219(4, B00000000)
Write_Max7219(5, B00000000)
Write_Max7219(6, B00000000)
Write_Max7219(7, B00000000)
Write_Max7219(8, B00000000)
in
for (int f =1; f <8; f++){
Write_Max7219(f, 0);
i want to try to optimize
Write_Max7219(1, B10101010)
Write_Max7219(2, B01010101)
Write_Max7219(3, B10101010)
Write_Max7219(4, B01010101)
Write_Max7219(5, B10101010)
Write_Max7219(6, B01010101)
Write_Max7219(7, B10101010)
Write_Max7219(8, B01010101)
can you tell me if it's possible
optimize all its with the for command
the lines 1 , 3 , 5 , 7
and 2 ,  4 , 6 , 8
bring them together
in 2 command for different
i am un gros noob
ludocraft
no one to help me ??; (
i am un gros noob
TheMemberFormerlyKnownAsAWOL
for (int f =1; f <8; f++){Oops
Please don't PM technical questions - post them on the forum, then everyone benefits/suffers equally
Blackfin
One way:
byte
    var = 0b10101010;
for( int i=1; i<9; i++ )
    Write_Max7219( i, var );
    var ^= 0b11111111;
}//for
and 2 ,  4 , 6 , 8
bring them together
Yes. Simple arithmetic.
gfvalvo
@ludocraft, you posted this bump only 30 Minutes after your original post. Are you freaking kidding?
No technical questions via PM. They will be ignored. Post your questions in the forum so that all may learn.
Paul_KD7HB
I don't think you have ever told us your goal for optimization.
Are wanting to minimize the size of you source code text file?
Are you wanting to minimize the number of compiled instructions?
Are you wanting to increase the speed of execution of your program?
Are you wanting to minimize the memory size of your compiled program?
Just curious.
Paul
ludocraft
yes reduce the size of the text and reduce the size of the memory
i am un gros noob
