Topic: Two different sketch, the same code, libraries and HW: different results... (Read 586 times) previous topic - next topic
Brig
I can't understand the reason... the first goes, the second has problem with Wire.endTransmission();...
but, except the sketch name (and directory), the use the same thing... (also the same inclusion)
firts code:
Code: [Select]
System sys = System(LCD_ROW, LCD_COLUMN, KEYPAD_ROW, KEYPAD_COLUMN);
char key = '\0';
boolean colon = false;
uint8_t second = 0;
void setup(){
  Wire.begin();
  sys.begin();
  sock.begin();
second code
Code: [Select]
char key = '\0';
uint8_t second = 0;
void setup(){
  Wire.begin();
  sys.begin();
  sock.begin();
libraries: (Sockets creates an instance of itself alone (as Wire))
System.cpp
Code: [Select]
System::System(uint8_t lcdRow, uint8_t lcdColumn, uint8_t keypadRow, uint8_t keypadColumn){
_lcdRow = lcdRow;
_lcdColumn = lcdColumn;
_keypadRow = keypadRow;
_keypadColumn = keypadColumn;
_backlight = false;
void System::begin(){
// SEE PAGE 45/46 FOR INITIALIZATION SPECIFICATION!
// according to datasheet, we need at least 40ms after power rises above 2.7V
// before sending commands. Arduino can turn on way befer 4.5V so we'll wait 50
delayMicroseconds(50000);
// Now we pull both RS and R/W low to begin commands
expanderWrite((_backlight ? LCD_BACKLIGHT : LCD_NOBACKLIGHT)); // reset expanderand turn backlight off (Bit 8 =1)
  //put the LCD into 4 bit mode
// this is according to the hitachi HD44780 datasheet
// figure 24, pg 46
// we start in 8bit mode, try to set 4 bit mode
write4bits(0x03);
delayMicroseconds(4500); // wait min 4.1ms
// second try
write4bits(0x03);
// third go!
write4bits(0x03);
delayMicroseconds(150);
// finally, set to 4-bit interface
write4bits(0x02);
// set # lines, font size, etc.
send(LCD_FUNCTIONSET | LCD_4BITMODE | LCD_1LINE | LCD_5x8DOTS | LCD_2LINE);
// turn the display on with no cursor or blinking default
send(LCD_DISPLAYCONTROL | LCD_DISPLAYON | LCD_CURSOROFF | LCD_BLINKOFF);
// clear it off
clearLcd();
// Initialize to default text direction (for roman languages); set the entry mode
send(LCD_ENTRYMODESET | LCD_ENTRYLEFT | LCD_ENTRYSHIFTDECREMENT);
send(LCD_RETURNHOME);  // set cursor position to zero
delayMicroseconds(2000);  // this command takes a long time!
lcdBacklight(true);
_currentLcdRow = _secondsWithoutInput = 0;
refreshClock();
_lastSecond = getSecond();
void System::send(uint8_t value, uint8_t mode) {
write4bits((value>>4) | mode);
write4bits((value & 0x0F) | mode);
void System::write(uint8_t value) {
write4bits((value>>4) | Rs);
write4bits((value & 0x0F) | Rs);
void System::write4bits(uint8_t value) {
expanderWrite(value);
pulseEnable(value);
void System::expanderWrite(uint8_t data){
Wire.beginTransmission(LCD_ADDRESS);
Wire.send((int)(data) | (_backlight ? LCD_BACKLIGHT : LCD_NOBACKLIGHT));
void System::pulseEnable(uint8_t _data){
expanderWrite(_data | En); // En high
delayMicroseconds(1); // enable pulse must be >450ns
expanderWrite(_data & ~En); // En low
delayMicroseconds(50); // commands need > 37us to settle
Sockets.cpp
Code: [Select]
Sockets::Sockets(){
_totSocket = -1;
_ls.day = LS_MAX_DAY;
_ls.minutes = LS_MAX_MINUTES;
void Sockets::begin(){
if(!isMemoryCorrect())
formatMemory();
bool Sockets::isMemoryCorrect(){
return eepromReadData(POSITION_STATUS_MEMORY) == CORRECT_MEMORY;
void Sockets::formatMemory(){
eepromWriteData(POSITION_STATUS_MEMORY, CORRECT_MEMORY);
eepromWriteData(POSITION_STATUS_MEMORY + 1, 0);// versione del programma "0"
eepromWriteData(POSITION_STATUS_MEMORY + 2, 0);// ultimo programma usato "0"
void Sockets::eepromConnectPage(int page){
Wire.beginTransmission((int) EEPROM_ADDRESS);
Wire.send((byte)((page) >> 8));
Wire.send((byte)((page) & 0xFF));
byte Sockets::eepromReadData(int page){
eepromConnectPage(page);
Wire.requestFrom((int) EEPROM_ADDRESS, sizeof(byte));
return Wire.receive();
With some Serial.print I've established that (only) in the second sketch it's wait the firts Wire.endTransmission();...
the first sketch, instead, works almost normally ... (do not turn the light on the LCD.... though, trying other sketches (which were correctly) reflected the same problem ... so I think it is due to a link ...)
but... for the "Wire.endTransmission();" some idea?
