Hola a todos,
he creado un termómetro con DS32231 y la temperatura comprobándola con varios termómetros marca 3º de de más ¿cómo podría corregir ese desfase? ¿Se puede hacer por código.
Adjunto foto del montaje y código
Un saludo.
#include <Adafruit_ST7735.h>
#include <Adafruit_GFX.h>
#include <Wire.h>
#include "Sodaq_DS3231.h"
#include <SPI.h>
#define TFT_CS 10
#define TFT_DC 9
#define TFT_RST 8
#define TFT_SCLK 13
#define TFT_MOSI 11
Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_MOSI, TFT_SCLK, TFT_RST);
float maxTemperature=0;
float minTemperature=200;
char charMinTemperature[10];
char charMaxTemperature[10];
char timeChar[100];
char dateChar[50];
char temperatureChar[10];
float temperature = 0;
float previousTemperature = 0;
String dateString;
int minuteNow=0;
int minutePrevious=0;
void setup ()
tft.initR(INITR_BLACKTAB);
tft.fillScreen(ST7735_BLACK);
Serial.begin(57600);
Wire.begin();
rtc.begin();
printText("TEMPERATURA", ST7735_GREEN,30,65,1); // Temperature Static Text
printText("MAX", ST7735_RED,18,130,1);
printText("MIN", ST7735_BLUE,95,130,1);
//setRTCTime();
uint32_t old_ts;
void loop ()
float temperature = rtc.getTemperature();
DateTime now = rtc.now(); //get the current date-time
uint32_t ts = now.getEpoch();
if (old_ts == 0 || old_ts != ts) {
old_ts = ts;
minuteNow = now.minute();
if(minuteNow!=minutePrevious)
dateString = getDayOfWeek(now.dayOfWeek())+", ";
dateString = dateString+String(now.date())+"/"+String(now.month());
dateString= dateString+"/"+ String(now.year());
minutePrevious = minuteNow;
String hours = String(now.hour());
if(now.minute()<10)
hours = hours+":0"+String(now.minute());
}else
hours = hours+":"+String(now.minute());
hours.toCharArray(timeChar,100);
tft.fillRect(10,0,160,65,ST7735_BLACK);
printText(timeChar, ST7735_WHITE,20,25,3);
dateString.toCharArray(dateChar,50);
printText(dateChar, ST7735_GREEN,8,5,1);
if(temperature != previousTemperature)
previousTemperature = temperature;
String temperatureString = String(temperature,1);
temperatureString.toCharArray(temperatureChar,10);
tft.fillRect(10,80,128,30,ST7735_BLACK);
printText(temperatureChar, ST7735_WHITE,10,80,3);
printText("o", ST7735_WHITE,90,75,2);
printText("C", ST7735_WHITE,105,80,3);
if(temperature>maxTemperature)
maxTemperature = temperature;
dtostrf(maxTemperature,5, 1, charMaxTemperature);
tft.fillRect(3,142,33,20,ST7735_BLACK);
printText(charMaxTemperature, ST7735_WHITE,3,145,1);
printText("o", ST7735_WHITE,35,140,1);
printText("C", ST7735_WHITE,41,145,1);
if(temperature < minTemperature)
minTemperature = temperature;
dtostrf(minTemperature,5, 1, charMinTemperature);
tft.fillRect(75,140,36,18,ST7735_BLACK);
printText(charMinTemperature, ST7735_WHITE,80,145,1);
printText("o", ST7735_WHITE,112,140,1);
printText("C", ST7735_WHITE,118,145,1);
void setRTCTime()
DateTime dt(2015, 8, 27, 9, 35, 30, 4); // Year, Month, Day, Hour, Minutes, Seconds, Day of Week
rtc.setDateTime(dt); //Adjust date-time as defined 'dt' above
}void printText(char *text, uint16_t color, int x, int y,int textSize)
tft.setCursor(x, y);
tft.setTextColor(color);
tft.setTextSize(textSize);
tft.setTextWrap(true);
tft.print(text);
String getDayOfWeek(int i)
switch(i)
case 1: return "Lunes";break;
case 2: return "martes";break;
case 3: return "Miercoles";break;
case 4: return "Jueves";break;
case 5: return "Viernes";break;
case 6: return "Sabado";break;
case 7: return "Domingo";break;
default: return "Viernes";break;
