#include <string.h>
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "esp_event_loop.h"
#include "esp_event.h"
#include "esp_log.h"
#include "esp_eth.h"
#include "esp_wifi.h"
#include "esp_wifi_internal.h"
#include "nvs_flash.h"
#ifdef CONFIG_PHY_LAN8720
#include "eth_phy/phy_lan8720.h"
#define DEFAULT_ETHERNET_PHY_CONFIG phy_lan8720_default_ethernet_config
#endif
#ifdef CONFIG_PHY_TLK110
#include "eth_phy/phy_tlk110.h"
#define DEFAULT_ETHERNET_PHY_CONFIG phy_tlk110_default_ethernet_config
#endif
#ifdef CONFIG_PHY_IP101
#include "eth_phy/phy_ip101.h"
#define DEFAULT_ETHERNET_PHY_CONFIG phy_ip101_default_ethernet_config
#endif
static const char* TAG = "eth2wifi_demo";
#define PIN_PHY_POWER CONFIG_PHY_POWER_PIN
#define PIN_SMI_MDC CONFIG_PHY_SMI_MDC_PIN
#define PIN_SMI_MDIO CONFIG_PHY_SMI_MDIO_PIN
typedef struct {
void* buffer;
uint16_t len;
void* eb;
} tcpip_adapter_eth_input_t;
static bool mac_is_set = false;
static xQueueHandle eth_queue_handle;
static bool wifi_is_connected = false;
static bool ethernet_is_connected = false;
static uint8_t eth_mac[6];
#ifdef CONFIG_PHY_USE_POWER_PIN
/* This replaces the default PHY power on/off function with one that
also uses a GPIO for power on/off.
If this GPIO is not connected on your device (and PHY is always powered), you can use the default PHY-specific power
on/off function rather than overriding with this one.
static void phy_device_power_enable_via_gpio(bool enable)
assert(DEFAULT_ETHERNET_PHY_CONFIG.phy_power_enable);
if (!enable) {
/* Do the PHY-specific power_enable(false) function before powering down */
DEFAULT_ETHERNET_PHY_CONFIG.phy_power_enable(false);
gpio_pad_select_gpio(PIN_PHY_POWER);
gpio_set_direction(PIN_PHY_POWER, GPIO_MODE_OUTPUT);
if (enable == true) {
gpio_set_level(PIN_PHY_POWER, 1);
ESP_LOGD(TAG, "phy_device_power_enable(TRUE)");
gpio_set_level(PIN_PHY_POWER, 0);
ESP_LOGD(TAG, "power_enable(FALSE)");
// Allow the power up/down to take effect, min 300us
vTaskDelay(1);
if (enable) {
/* Run the PHY-specific power on operations now the PHY has power */
DEFAULT_ETHERNET_PHY_CONFIG.phy_power_enable(true);
#endif
static void ethernet2wifi_mac_status_set(bool status)
mac_is_set = status;
static bool ethernet2wifi_mac_status_get(void)
return mac_is_set;
static void eth_gpio_config_rmii(void)
// RMII data pins are fixed:
// TXD0 = GPIO19
// TXD1 = GPIO22
// TX_EN = GPIO21
// RXD0 = GPIO25
// RXD1 = GPIO26
// CLK == GPIO0
phy_rmii_configure_data_interface_pins();
// MDC is GPIO 23, MDIO is GPIO 18
phy_rmii_smi_configure_pins(PIN_SMI_MDC, PIN_SMI_MDIO);
static esp_err_t tcpip_adapter_eth_input_sta_output(void* buffer, uint16_t len, void* eb)
tcpip_adapter_eth_input_t msg;
msg.buffer = buffer;
msg.len = len;
msg.eb = eb;
if (xQueueSend(eth_queue_handle, &msg, portMAX_DELAY) != pdTRUE) {
return ESP_FAIL;
return ESP_OK;
static void eth_task(void* pvParameter)
for (; {
if (xQueueReceive(eth_queue_handle, &msg, (portTickType)portMAX_DELAY) == pdTRUE) {
if (msg.len > 0) {
if (!ethernet2wifi_mac_status_get()) {
memcpy(eth_mac, (uint8_t*)msg.buffer + 6, sizeof(eth_mac));
ESP_ERROR_CHECK(esp_wifi_start());
#ifdef CONFIG_ETH_TO_STATION_MODE
esp_wifi_set_mac(WIFI_IF_STA, eth_mac);
esp_wifi_connect();
#else
esp_wifi_set_mac(WIFI_IF_AP, eth_mac);
#endif
ethernet2wifi_mac_status_set(true);
if (wifi_is_connected) {
esp_wifi_internal_tx(ESP_IF_WIFI_STA, msg.buffer, msg.len - 4);
#else
esp_wifi_internal_tx(ESP_IF_WIFI_AP, msg.buffer, msg.len - 4);
#endif
esp_eth_free_rx_buf(msg.buffer);
static void initialise_wifi(void)
wifi_init_config_t cfg = WIFI_INIT_CONFIG_DEFAULT();
ESP_ERROR_CHECK(esp_wifi_init_internal(&cfg));
ESP_ERROR_CHECK(esp_wifi_set_storage(WIFI_STORAGE_RAM));
wifi_config_t wifi_config = {
.sta = {
.ssid = CONFIG_DEMO_SSID,
.password = CONFIG_DEMO_PASSWORD,
ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_STA));
ESP_ERROR_CHECK(esp_wifi_set_config(ESP_IF_WIFI_STA, &wifi_config));
#else
.ap = {
.ssid_len = strlen(CONFIG_DEMO_SSID),
.max_connection = 1,
ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_AP));
ESP_ERROR_CHECK(esp_wifi_set_config(ESP_IF_WIFI_AP, &wifi_config));
#endif
static void initialise_ethernet(void)
eth_config_t config = DEFAULT_ETHERNET_PHY_CONFIG;
/* Set the PHY address in the example configuration */
config.phy_addr = CONFIG_PHY_ADDRESS;
config.gpio_config = eth_gpio_config_rmii;
config.tcpip_input = tcpip_adapter_eth_input_sta_output;
config.promiscuous_enable = true;
/* Replace the default 'power enable' function with an example-specific
one that toggles a power GPIO. */
config.phy_power_enable = phy_device_power_enable_via_gpio;
#endif
esp_eth_init(&config);
esp_eth_enable();
static esp_err_t tcpip_adapter_sta_input_eth_output(void* buffer, uint16_t len, void* eb)
if (ethernet_is_connected) {
esp_eth_tx(buffer, len);
esp_wifi_internal_free_rx_buffer(eb);
return ESP_OK;
static esp_err_t tcpip_adapter_ap_input_eth_output(void* buffer, uint16_t len, void* eb)
return ESP_OK;
static esp_err_t event_handler(void* ctx, system_event_t* event)
switch (event->event_id) {
case SYSTEM_EVENT_STA_START:
printf("SYSTEM_EVENT_STA_START\r\n");
case SYSTEM_EVENT_STA_CONNECTED:
printf("SYSTEM_EVENT_STA_CONNECTED\r\n");
wifi_is_connected = true;
esp_wifi_internal_reg_rxcb(ESP_IF_WIFI_STA, (wifi_rxcb_t)tcpip_adapter_sta_input_eth_output);
case SYSTEM_EVENT_STA_GOT_IP:
printf("SYSTEM_EVENT_STA_GOT_IP\r\n");
case SYSTEM_EVENT_STA_DISCONNECTED:
printf("SlYSTEM_EVENT_STA_DISCONNECTED\r\n");
esp_wifi_internal_reg_rxcb(ESP_IF_WIFI_STA, NULL);
esp_wifi_connect();
case SYSTEM_EVENT_AP_STACONNECTED:
printf("SYSTEM_EVENT_AP_STACONNECTED\r\n");
esp_wifi_internal_reg_rxcb(ESP_IF_WIFI_AP, (wifi_rxcb_t)tcpip_adapter_ap_input_eth_output);
case SYSTEM_EVENT_AP_STADISCONNECTED:
printf("SYSTEM_EVENT_AP_STADISCONNECTED\r\n");
esp_wifi_internal_reg_rxcb(ESP_IF_WIFI_AP, NULL);
case SYSTEM_EVENT_ETH_CONNECTED:
printf("SYSTEM_EVENT_ETH_CONNECTED\r\n");
ethernet_is_connected = true;
case SYSTEM_EVENT_ETH_DISCONNECTED:
printf("SYSTEM_EVENT_ETH_DISCONNECTED\r\n");
ethernet2wifi_mac_status_set(false);
default:
return ESP_OK;
void app_main()
esp_err_t ret = nvs_flash_init();
if (ret == ESP_ERR_NVS_NO_FREE_PAGES || ret == ESP_ERR_NVS_NEW_VERSION_FOUND) {
ESP_ERROR_CHECK( nvs_flash_erase() );
ESP_ERROR_CHECK( ret );
tcpip_adapter_init();
eth_queue_handle = xQueueCreate(CONFIG_DMA_RX_BUF_NUM, sizeof(tcpip_adapter_eth_input_t));
xTaskCreate(eth_task, "eth_task", 2048, NULL, (tskIDLE_PRIORITY + 2), NULL);
esp_event_loop_init(event_handler, NULL);
initialise_ethernet();
initialise_wifi();
I am using the above program ...(or) first uploaded program....in my ESP32 first act as station and connected to my router (or) my ethernet, after connect it will display the connected ip address and then same esp32 act as AP mode ..in my mobile shows the sssid i will connect it...after connect it shows no internet connection....i need internet connection on my mobile
