Topic: ATMEGA328p Power 3.3v boost? (Read 189 times) previous topic - next topic
carlosserious
I currently have a circuit I'm working on that runs on a 'barebones' arduino. I want to power it with a 3.3v input, like 3 aa batteries(I know it's 4.5, close enough), as it drains below 2.7v, the circuit will cut off.
Is it worth adding a boost module to get more life out of the batteries and establish a consistent 3.3v operation?
srnet
If its a bare bones Arduino set the BOD level to 1.8V.
http://www.50dollarsat.info/
http://www.loratracker.uk/
ShermanP
I don't think a boost regulator makes sense.  By the time the AAs are down to .9V each, they will be pretty close to being fully discharged.  And if you add a regulator, you will inevitably lose some efficiency - maybe 10-15%.  It's not at all certain that adding the regulator would increase battery life.  It might reduce it.
DrAzzy
#3
Jan 22, 2020, 08:30 pm Last Edit: Jan 22, 2020, 08:30 pm by DrAzzy
Agree. If you use sleep to reduce power consumption, it definitely will, because the quiescent current of the regulator will continue no matter what (this is even true of a linear regulator, where the quiescent current is much lower than a boost regulator; it's easy to forget just how low the current drawn by a sleeping microcontroller can be).
ATTinyCore for x4/x5/x61/x7/x8/x41/1634/828/x313 megaTinyCore for the megaavr ATtinies - Board Manager:
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts, mosfets, awesome prototyping board in my store http://tindie.com/stores/DrAzzy
