Topic: Arduino 1.8.12 released (Read 13877 times) previous topic - next topic
pert
After instalation, I could not launch because it could not load "keywords.txt".
Even after re-installing Arduino or using the previous version it did not work at all!
Please post the full and exact error message you're getting.
Mrs_TSe
HELP! What does this mean?
Arduino: 1.8.11 (Windows Store 1.8.28.0) (Windows 10), Board: "Arduino Uno"
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.28.0_x86__mdqgnx93n4wtt\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.28.0_x86__mdqgnx93n4wtt\hardware -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.28.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.28.0_x86__mdqgnx93n4wtt\hardware\tools\avr -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.28.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\256tsejalbo\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10811 -build-path C:\Users\256TSE~1\AppData\Local\Temp\arduino_build_416855 -warnings=default -build-cache C:\Users\256TSE~1\AppData\Local\Temp\arduino_cache_689997 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.28.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.28.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.28.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino5.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.28.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.28.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.28.0_x86__mdqgnx93n4wtt\hardware\tools\avr -verbose C:\Users\256tsejalbo\Documents\IPES STEAM\IPES STEAM Toolkit\Temp F_Display\Temp_F_Display\Temp_F_Display.ino
loading hardware from C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.28.0_x86__mdqgnx93n4wtt\hardware: following possible symlink C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.28.0_x86__mdqgnx93n4wtt\hardware: Access is denied.
Error compiling for board Arduino Uno.
pert
Code: [Select]
This sort of error could be caused by your antivirus software. Try TEMPORARILY disabling your antivirus for a single compilation to see if the problem goes away, then turn the antivirus back on. If the problem doesn't occur with the antivirus off you will need to adjust the settings of your antivirus to whitelist the appropriate file, folder, or process so it doesn't interfere with compilation.
peter_krajcik
Hi, I still can't use it on macOS Catalina 10.15.3. Serial port is not recognized. Is it supported? If so, how to fix it? Thank you.
CORRECTION: It works. Excuse me for my incorrect post. The problem was a microUSB connector on two boards I tested with my prototype. When I replaced it with the third board, serial port appeared.
Luciani
On Raspberry Pi 4b 2Gb Arduino IDE 1.8.11 Linux ARM, on Raspbian Buster updated.
This error:
I Uninstall with sudo ./uninstall.sh but the problem keep. How to solve or is a bug, No firewall, no antivirus, Raspbian buster just installed from noobs lite and updated. If i put the link to json my chromium can show me.
Any clue?
pert
This error:
I can reproduce the bug and have submitted a bug report:
https://github.com/arduino/Arduino/issues/9719
The workaround is to use Arduino IDE 1.8.10. You can download it here:
https://www.arduino.cc/en/Main/OldSoftwareReleases
redha273
hello guys, i want ask how to register product code, because i new to begin arduino, thanks guys
ballscrewbob
@redha273
The registration code scheme for boards was dropped so you do not need to register.
There was a back story to it but that is irrelevant.
Enjoy your Arduino adventures.
Bob.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google (who would have thunk it ! ) or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
RubiRubsn
#23
Feb 06, 2020, 04:05 pm Last Edit: Feb 06, 2020, 04:30 pm by RubiRubsn
after I updated the IDE to 1.8.11
my IDE is crashing when I want to use it on a secondary Monitor.
Im on OSX 10.15.2.
can anyone help me ?
-Ruben
p.s. sry for my bad english ^^
gr33nzon378
Hello everyone, I also have a problem with my Arduino Genio card ... I tried everything, I looked for the problem in the error message to install in the library but nothing to do! Can you help me? Here is the program...
                                                             Arduino : 1.8.10 (Mac OS X), Carte : "Arduino Uno"
                                      fork/exec /Users/Famille/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++: no such file or directory
                                    Erreur de compilation pour la carte Arduino Uno
Please answer me as soon as possible!!!!
pert
This error indicates something has gone wrong with your Arduino AVR Boards installation. The solution is to remove the installed packages. Be aware this will remove any boards you have installed via Boards Manager:
  • (In the Arduino IDE) File > Preferences
  • In the Arduino IDE, click the link on the line following "More preferences can be edited directly in the file". This will open the Arduino15 (or similar name depending on OS) folder.
  • Delete all files and folders under the Arduino15 folder except for preferences.txt. Please be very careful when deleting things from your computer. When in doubt, back up!
  • Restart the Arduino IDE
Verify that you can now use your board before reinstalling any packages via Boards Manager.
leexande
Pert,
Thanks for your support.
After the installation of Arduino IDE 1.8.11 in Win 10, when I try to open the Arduino IDE  it shows a Pop-up Message:
Problem loading kewords
Could not load keywords.txt,
please re-install Arduino.
It gets the same problem after the installation/re-installation using the download from arduino site and also windows app.
pert
Please do this:
  • Start File Explorer (AKA Windows Explorer).
  • Open the Arduino IDE's installation folder (usually C:\Program Files (x86)\Arduino)
  • In the folder listing of the Arduino IDE installation folder, hold the Shift key while clicking the right hand button on the mouse.
  • Click "Open PowerShell window here" (or "Open command window here" if using Windows 7). PowerShell (or cmd if using Windows 7) will now open with the current directory set to the Arduino IDE installation folder.
  • Type ./arduino_debug
  • Press Enter. Debug output should now be printed to the PowerShell window as the Arduino IDE starts (or fails to start).
  • Wait for the Arduino IDE to finish starting, or failing to start.
  • Switch back to the PowerShell window if the Arduino IDE window took the focus.
  • Right click on the title bar of the PowerShell window.
  • Click Edit > Select All. This will select all the text in the PowerShell window.
  • Press Ctrl + c. This will copy the contents of the PowerShell window to the clipboard.
  • In this Arduino forum thread, click on the reply field.
  • Click the </> button on the forum toolbar. This will add the forum's code tags markup to your reply, making it easier for us to read.
  • Press Ctrl + V. This will paste the output between the code tags.
  • Move the cursor outside of the code tags before you add any additional text to your reply.
  • Click the "Post" button.
Hopefully that will give us some information we can use to help you with the problem.
jtcours
#28
Feb 10, 2020, 06:31 am Last Edit: Feb 10, 2020, 06:55 am by jtcours Reason: Added info from crash report.
I'm also seeing SIGABRT from Arduino 1.8.11 on a dual-screened Mac. I'm extending the desktop (not mirroring), with macOS Catalina 10.15.3 and Java 1.8.0_102.
From /var/log/system.log:
Quote
Feb  9 20:19:28 zephyr com.apple.xpc.launchd[1] (cc.arduino.Arduino.18980[12902]): Service exited due to SIGABRT
Feb  9 21:02:39 zephyr com.apple.xpc.launchd[1] (cc.arduino.Arduino.18980[13352]): Service exited due to SIGABRT
Feb  9 21:04:14 zephyr com.apple.xpc.launchd[1] (com.apple.xpc.launchd.oneshot.0x1000001a.Arduino[27021]): Service exited due to SIGABRT
Sadly, there doesn't seem to be a lot of info there. The abort seems to occur when the Arduino software tries to open a new window on the external monitor.
Maybe this info from the crash report will be helpful:
Code: [Select]
Date/Time:             2020-02-09 21:04:14.278 -0800
OS Version:            Mac OS X 10.15.3 (19D76)
Report Version:        12
Anonymous UUID:        CF37A47B-E000-2C7F-3B88-C469EB1A00D8
Sleep/Wake UUID:       F0468D71-7D75-4004-9946-503F42AE9656
Time Awake Since Boot: 230000 seconds
Time Since Wake:       93000 seconds
System Integrity Protection: enabled
Crashed Thread:        17  Java: Java2D Queue Flusher
Exception Type:        EXC_BAD_INSTRUCTION (SIGABRT)
Exception Codes:       0x0000000000000001, 0x0000000000000000
Exception Note:        EXC_CORPSE_NOTIFY
Application Specific Information:
-[NSOpenGLContext setView:] must be called from the main thread.
Thread 17 Crashed:: Java: Java2D Queue Flusher
0   libsystem_kernel.dylib        0x00007fff66f047fa __pthread_kill + 10
1   libsystem_pthread.dylib        0x00007fff66fc1bc1 pthread_kill + 432
2   libsystem_c.dylib              0x00007fff66e8ba1c abort + 120
3   libjvm.dylib                  0x000000010f8482c6 os::abort(bool) (.cold.1) + 125
4   libjvm.dylib                  0x000000010f664fab os::abort(bool) + 33
5   libjvm.dylib                  0x000000010f7fe2f9 VMError::report_and_die() + 2301
6   libjvm.dylib                  0x000000010f259fe3 report_vm_error(char const*, int, char const*, char const*) + 93
7   libjvm.dylib                  0x000000010f66a9f8 os::get_sender_for_C_frame(frame*) + 76
8   libjvm.dylib                  0x000000010f25b234 print_native_stack(outputStream*, frame, Thread*, char*, int) + 336
9   libjvm.dylib                  0x000000010f7fd153 VMError::report(outputStream*) + 2617
10  libjvm.dylib                  0x000000010f7fddd7 VMError::report_and_die() + 987
11  libjvm.dylib                  0x000000010f66ae07 JVM_handle_bsd_signal + 802
12  libjvm.dylib                  0x000000010f66795f signalHandler(int, __siginfo*, void*) + 88
13  libsystem_platform.dylib      0x00007fff66fb642d _sigtramp + 29
14  ???                            000000000000000000 0 + 0
15  libawt_lwawt.dylib            0x0000000115373281 CGLSD_MakeCurrentToScratch + 93
16  libawt_lwawt.dylib            0x00000001153733d8 OGLSD_MakeOGLContextCurrent + 166
17  libawt_lwawt.dylib            0x0000000115390e66 OGLContext_SetSurfaces + 188
18  libawt_lwawt.dylib            0x00000001153956c3 Java_sun_java2d_opengl_OGLRenderQueue_flushBuffer + 1775
19  ???                            0x0000000119b5ffad 0 + 4726325165
20  ???                            0x0000000119b382bd 0 + 4726162109
21  ???                            0x0000000119b382bd 0 + 4726162109
22  ???                            0x0000000119b382bd 0 + 4726162109
23  ???                            0x0000000119b30671 0 + 4726130289
24  libjvm.dylib                  0x000000010f3f3c23 JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*) + 2243
25  libjvm.dylib                  0x000000010f3f2462 JavaCalls::call_virtual(JavaValue*, KlassHandle, Symbol*, Symbol*, JavaCallArguments*, Thread*) + 626
26  libjvm.dylib                  0x000000010f3f26af JavaCalls::call_virtual(JavaValue*, Handle, KlassHandle, Symbol*, Symbol*, Thread*) + 111
27  libjvm.dylib                  0x000000010f48c2ed thread_entry(JavaThread*, Thread*) + 177
28  libjvm.dylib                  0x000000010f7a33b3 JavaThread::thread_main_inner() + 373
29  libjvm.dylib                  0x000000010f7a314f JavaThread::run() + 847
30  libjvm.dylib                  0x000000010f664937 java_start(Thread*) + 250
31  libsystem_pthread.dylib        0x00007fff66fc1e65 _pthread_start + 148
32  libsystem_pthread.dylib        0x00007fff66fbd83b thread_start + 15
Thread 17 crashed with X86 Thread State (64-bit):
  rax: 0x0000000000000000  rbx: 0x0000700008ec2000  rcx: 0x0000700008ec04c8  rdx: 0x0000000000000000
  rdi: 0x000000000000da13  rsi: 0x0000000000000006  rbp: 0x0000700008ec04f0  rsp: 0x0000700008ec04c8
   r8: 0x0000000000000010   r9: 0x0000700008ec0500  r10: 0x0000700008ec2000  r11: 0x0000000000000246
  r12: 0x000000000000da13  r13: 0x0000700008ec0670  r14: 0x0000000000000006  r15: 0x0000000000000016
  rip: 0x00007fff66f047fa  rfl: 0x0000000000000246  cr2: 0x000000010f084feb
Logical CPU:     0
Error Code:      0x02000148
Trap Number:     133
pert
Thanks for reporting this! Please submit an issue on GitHub to bring this to the Arduino developers' attention:
