En sortie console ça donnait quoi ? les Serial.print() que j'ai ajouté.
Edit: ai oublier de mettre le Serial.begin() dans le setup
ai invesré les valeurs des on_off dans les if(cmd == 2), ....
#include "etherShield.h"
// please modify the following two lines. mac and ip have to be unique
// in your local area network. You can not have the same numbers in
// two devices:
static uint8_t mymac[6] = {0x54,0x55,0x58,0x10,0x00,0x24};
static uint8_t myip[4] = {1,1,1,1};
static char baseurl[]="http://xxxxxxx.dyndns-home.com/";
static uint16_t mywwwport =80; // listen port for tcp/www (max range 1-254)
#define BUFFER_SIZE 500
static uint8_t buf[BUFFER_SIZE+1];
#define STR_BUFFER_SIZE 22
static char strbuf[STR_BUFFER_SIZE+1];
EtherShield es=EtherShield();
// prepare the webpage by writing the data to the tcp send buffer
uint16_t print_webpage(uint8_t *buf, byte on_off, byte on_off2);
int8_t analyse_cmd(char *str);
// LED cathode connects the Pin4, anode to 5V through 1K resistor
#define LED_PIN 4
#define LED_PIN2 5
byte on_off = 1;
byte on_off2 = 1;
void setup(){
/*initialize enc28j60*/
es.ES_enc28j60Init(mymac);
es.ES_enc28j60clkout(2); // change clkout from 6.25MHz to 12.5MHz
delay(10);
/* Magjack leds configuration, see enc28j60 datasheet, page 11 */
// LEDA=greed LEDB=yellow
// 0x880 is PHLCON LEDB=on, LEDA=on
// enc28j60PhyWrite(PHLCON,0b0000 1000 1000 00 00);
es.ES_enc28j60PhyWrite(PHLCON,0x880);
// 0x990 is PHLCON LEDB=off, LEDA=off
// enc28j60PhyWrite(PHLCON,0b0000 1001 1001 00 00);
es.ES_enc28j60PhyWrite(PHLCON,0x990);
// 0x476 is PHLCON LEDA=links status, LEDB=receive/transmit
// enc28j60PhyWrite(PHLCON,0b0000 0100 0111 01 10);
es.ES_enc28j60PhyWrite(PHLCON,0x476);
delay(100);
//init the ethernet/ip layer:
es.ES_init_ip_arp_udp_tcp(mymac,myip,80);
pinMode(LED_PIN, OUTPUT);
digitalWrite(LED_PIN, LOW); // switch on LED
pinMode(LED_PIN2, OUTPUT);
digitalWrite(LED_PIN2, LOW);
void loop(){
uint16_t plen, dat_p;
int8_t cmd;
plen = es.ES_enc28j60PacketReceive(BUFFER_SIZE, buf);
/*plen will ne unequal to zero if there is a valid packet (without crc error) */
if(plen!=0){
// arp is broadcast if unknown but a host may also verify the mac address by sending it to a unicast address.
if(es.ES_eth_type_is_arp_and_my_ip(buf,plen)){
es.ES_make_arp_answer_from_request(buf);
return;
// check if ip packets are for us:
if(es.ES_eth_type_is_ip_and_my_ip(buf,plen)==0){
return;
if(buf[IP_PROTO_P]==IP_PROTO_ICMP_V && buf[ICMP_TYPE_P]==ICMP_TYPE_ECHOREQUEST_V){
es.ES_make_echo_reply_from_request(buf,plen);
return;
// tcp port www start, compare only the lower byte
if (buf[IP_PROTO_P]==IP_PROTO_TCP_V&&buf[TCP_DST_PORT_H_P]==0&&buf[TCP_DST_PORT_L_P]==mywwwport){
if (buf[TCP_FLAGS_P] & TCP_FLAGS_SYN_V){
es.ES_make_tcp_synack_from_syn(buf); // make_tcp_synack_from_syn does already send the syn,ack
return;
if (buf[TCP_FLAGS_P] & TCP_FLAGS_ACK_V){
es.ES_init_len_info(buf); // init some data structures
dat_p=es.ES_get_tcp_data_pointer();
if (dat_p==0){ // we can possibly have no data, just ack:
if (buf[TCP_FLAGS_P] & TCP_FLAGS_FIN_V){
es.ES_make_tcp_ack_from_any(buf);
return;
if (strncmp("GET ",(char *)&(buf[dat_p]),4)!=0){
// head, post and other methods for possible status codes see:
// http://www.w3.org/Protocols/rfc2616/rfc2616-sec10.html
plen=es.ES_fill_tcp_data_p(buf,0,PSTR("HTTP/1.0 200 OK\r\nContent-Type: text/html\r\n\r\n<h1>200 OK</h1>"));
goto SENDTCP;
if (strncmp("/ ",(char *)&(buf[dat_p+4]),2)==0){
plen=print_webpage(buf, on_off, on_off2);
goto SENDTCP;
cmd=analyse_cmd((char *)&(buf[dat_p+5]));
Serial.print("cmd:");
Serial.println(cmd);
Serial.print("on_off:");
Serial.println(on_off);
Serial.print("on_off2:");
Serial.println(on_off2);
if (cmd==2)
Serial.println("cmd2 ok");
on_off=0;
else if (cmd==3)
Serial.println("cmd3 ok");
on_off=1;
digitalWrite(LED_PIN, HIGH); // switch off LED
else if (cmd==4)
Serial.println("cmd4 ok");
on_off2=0;
digitalWrite(LED_PIN2, LOW); // switch on LED
else if (cmd==5)
Serial.println("cmd5 ok");
on_off2=1;
digitalWrite(LED_PIN2, HIGH); // switch off LED
SENDTCP: es.ES_make_tcp_ack_from_any(buf); // send ack for http get
es.ES_make_tcp_ack_with_data(buf,plen); // send data
// The returned value is stored in the global var strbuf
uint8_t find_key_val(char *str,char *key)
uint8_t found=0;
uint8_t i=0;
char *kp;
kp=key;
while(*str && *str!=' ' && found==0){
if (*str == *kp){
kp++;
if (*kp == '\0'){
str++;
kp=key;
if (*str == '='){
found=1;
}else{
kp=key;
str++;
if (found==1){
// copy the value to a buffer and terminate it with '\0'
while(*str && *str!=' ' && *str!='&' && i<STR_BUFFER_SIZE){
strbuf[i]=*str;
i++;
str++;
strbuf[i]='\0';
return(found);
Serial.println("analyse_cmd ...");
int8_t r=-1;
if (find_key_val(str,"cmd")){
if (*strbuf < 0x3a && *strbuf > 0x2f){
// is a ASCII number, return it
r=(*strbuf-0x30);
return r;
uint16_t plen;
plen=es.ES_fill_tcp_data_p(buf,0,PSTR("HTTP/1.0 200 OK\r\nContent-Type: text/html\r\n\r\n"));
plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<body bgcolor=\"#EFECCA\"> "));
plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<center><img src=\"http://i45.servimg.com/u/f45/11/05/63/75/chambr10.png\" >"));
plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<center><a href=\""));
plen=es.ES_fill_tcp_data(buf,plen,baseurl);
if(on_off)
plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("?cmd=2\"><img src=\"http://i45.servimg.com/u/f45/11/05/63/75/on11.png\"></a>"));
plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("?cmd=3\"><img src=\"http://i45.servimg.com/u/f45/11/05/63/75/off12.png\"></a>"));
if(on_off2)
plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("?cmd=4\"><img src=\"http://i45.servimg.com/u/f45/11/05/63/75/on11.png\"></a>"));
plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("?cmd=5\"><img src=\"http://i45.servimg.com/u/f45/11/05/63/75/off12.png\"></a>"));
plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("</body> "));
return(plen);
