Topic: TM1637 Library for 3 Digit 7 Segments (Read 241 times) previous topic - next topic
rkaelin
Hi, is there a library for 3 digit 7 segment displays and the TM1637? I only find libraries for 4 digit displays.
Thanks for your help :)
Roman
A 4 digit library may work fine with a 3 digit display, it depends on how the digits and segments are connected.
I have made a library that supports most displays on ebay and aliexpress, you can read about it here: https://lygte-info.dk/project/DisplayDriver%20UK.html
If you are using a display from ebay/aliexpress that is not supported by the library, please send me a link and I will look at implementing it.
Paul__B
I think that should be self-evident.
Had you read the instructions for posting, you should have realised the critical importance of providing a link to the display about which you are asking.
rkaelin
#3
Jan 30, 2020, 01:05 pm Last Edit: Jan 30, 2020, 01:06 pm by rkaelin
Didn't read anything that I am only allowed to ask questions about a product I already have?
Because I don't have a specific display yet. It should be a 0,28". So if you can point me in the right direction regarding library and display that would be great.
PaulRB
#4
Jan 30, 2020, 01:55 pm Last Edit: Jan 30, 2020, 01:55 pm by PaulRB
It sounded like you already had the product, you were quite specific (3 digits, tm1637). Many beginners fail to read the forum guide and don't post a link, assuming we all know exactly what product they have.
Why tm1637? Would you consider other driver chips such as max7219, ht16k33?
rkaelin
I chose the tm1637 because of the size. It will be a display in my coffe machine and I do not have much space. Furthermore, it only needs two pins on the arduino.
But if it's diffucult with the tm1637, I think the max7219 would also be fine since the size of the chip is also quite small. Never considered the ht16k33.
