Hi all
Hopefully an easy one here, but one that's had me scratching my head for a day now.
I have a simple application that does the following 3 things:
1.) Fades an LED up and down, with a 50 millis delay. This will eventually be a status LED.
2.) Captures a bunch of data from various sensors, and sends it over a 433Mhz LoRa radio to a RasPi, with a 10 minute delay.
3.) Test whether the soil moisture of a nearby plant is below a threshold percent, and if so, turn on a relay that controls a water pump. This is on a 1000 millis delay.
Simple enough. However this third function, Pump(), the one that controls the water pump, is causing a hell of a lot of problems. As soon as I call this function in my main loop, the arduino cycles twice and then crashes.
Here's the code with the function commented out:
//Arduino Raspberry Pi wireless Comunnication through LoRa - SX1278
//Sending Soil Moisture values from Arduino through Radio head LoRa without ACK
#include <Wire.h>
#include <SPI.h> //Import SPI library
#include <RH_RF95.h> // RF95 from RadioHead Library
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
#include <avr/wdt.h> // WDT library (added Jan 30)
#define RFM95_CS 10 //CS if Lora connected to pin 10
#define RFM95_RST 9 //RST of Lora connected to pin 9
#define RFM95_INT 2 //INT of Lora connected to pin 2
// Change to 434.0 or other frequency, must match RX's freq!
#define RF95_FREQ 434.0
//set the sea level pressure?
#define SEALEVELPRESSURE_HPA (airPressure + 1)
#define UP 0
#define DOWN 1
Adafruit_BME280 bme;
// Singleton instance of the radio driver
RH_RF95 rf95(RFM95_CS, RFM95_INT);
const byte pwmLED = 3;
int relay = 4;
volatile byte relayState = LOW;
// constants for min and max PWM
const int minPWM = 0;
const int maxPWM = 255;
// State Variable for Fade Direction
byte fadeDirection = UP;
// Global Fade Value
// but be bigger than byte and signed, for rollover
int fadeValue = 0;
// How smooth to fade?
byte fadeIncrement = 5;
int moistureLimit = 40;
int soilMoistureValue; //realtime value from sensor (analog)
int soilMoisturePercent; //digital mapped percent of moisture
int airTemperature; // air temp
int airPressure; // air pressure
int altitude; //altitude
int airHumidity; //air humidity
int lightVal;
int lightPercent;
const int AirValue = 600; //resistance value of the air
const int WaterValue = 310; //resistance value of water
const int BrightSun = 1100; //value of LightVal in a bright day
const int DarkNight = 25; //value of LightVal in a dark room
unsigned long startTime = 0;
unsigned long fadeInterval = 50; //LED Fade Interval
//unsigned long sensorInterval = 15000; //Interval test
unsigned long sensorInterval = 600000; //Interval for sending data to Raspi over Lora
unsigned long pumpInterval = 1000; //Interval between checking soil moisture and turning pump on and off
bool timeFlag = false;
unsigned long previousFadeMillis;
unsigned long previousSensorMillis;
unsigned long previousPumpMillis;
//Initialize Serial Monitor
//wdt reset initialize
wdt_enable(WDTO_1S); //added Jan 30
// Reset LoRa Module
pinMode(RFM95_RST, OUTPUT);
digitalWrite(RFM95_RST, LOW);
delay(10);
digitalWrite(RFM95_RST, HIGH);
delay(10);
analogWrite(pwmLED, fadeValue);
// Pin for relay module set as output
pinMode(relay, OUTPUT);
digitalWrite(relay, HIGH);
//Initialize LoRa Module
while (!rf95.init()) {
Serial.println("LoRa radio init failed");
while (1);
//Set the default frequency 434.0MHz
if (!rf95.setFrequency(RF95_FREQ)) {
Serial.println("setFrequency failed");
while (1);
//Initialize the BME280 temp/pressure/humidity sensor
if (!bme.begin(0x76)) {
Serial.println("Could not find a valid BME280 sensor, check wiring!");
while (1);
rf95.setTxPower(22, false); //Transmission power of the Lora Module
//call Sensor once at 0 seconds
Values();
Sensor();
void Values() {
soilMoistureValue = analogRead(A0); // Soil Moisture Value
soilMoisturePercent = map(soilMoistureValue, AirValue, WaterValue, 0, 100); // Soil Moisture Percent
airTemperature = bme.readTemperature(); // Air Temperature Value
airPressure = bme.readPressure() / 100.0F; // Air Pressure Value
altitude = bme.readAltitude(SEALEVELPRESSURE_HPA); // Approximate Altitude
airHumidity = bme.readHumidity(); // Air Humidity Value
lightVal = analogRead(A1); // Raw Light Sensor
lightPercent = map(lightVal, DarkNight, BrightSun, 0, 100); // Soil Moisture Percent
void Fade(unsigned long thisMillis) {
if (thisMillis - previousFadeMillis >= fadeInterval) {
// yup, it's time!
if (fadeDirection == UP) {
fadeValue = fadeValue + fadeIncrement;
if (fadeValue >= maxPWM) {
// At max, limit and change direction
fadeValue = maxPWM;
fadeDirection = DOWN;
//if we aren't going up, we're going down
fadeValue = fadeValue - fadeIncrement;
if (fadeValue <= minPWM) {
// At min, limit and change direction
fadeValue = minPWM;
fadeDirection = UP;
// Only need to update when it changes
// reset millis for the next iteration (fade timer only)
previousFadeMillis = thisMillis;
void Sensor() {
//debugging
Serial.print("Soil Moisture Value: ");
Serial.println(soilMoistureValue);
if (soilMoisturePercent > 100)
Serial.print("Soil Moisture Percentage: ");
Serial.println("100 %");
else if (soilMoisturePercent < 0)
Serial.println("0 %");
else if (soilMoisturePercent > 0 && soilMoisturePercent < 100)
Serial.print(soilMoisturePercent);
Serial.println("%");
Serial.print("Temperature: ");
Serial.print(airTemperature);
Serial.println("*C");
Serial.print("Pressure: ");
Serial.print(airPressure);
Serial.println("hPa");
Serial.print("Approx. Altitude: ");
Serial.print(altitude);
Serial.println("m");
Serial.print("Humidity: ");
Serial.print(airHumidity);
Serial.print("Light Percent: ");
Serial.print(lightPercent);
//end debugging
char buf[80] = {0}; //80 byte message
sprintf(buf, "%d|%d|%d|%d|%d|%d", soilMoisturePercent, airTemperature, airPressure, altitude, airHumidity, lightPercent); //can add in new variables here, but don't forget to add another|%d
rf95.send((uint8_t *)buf, 80); // send integer measured value as C-string, six byte packet
void TimeSensor(unsigned long thisMillis) {
if (thisMillis - previousSensorMillis >= sensorInterval) {
//call sensor function here
Sensor();
// reset millis for the next iteration (sensor timer only)
previousSensorMillis = thisMillis;
void Pump(unsigned long thisMillis) {
if (thisMillis - previousPumpMillis >= pumpInterval) {
//debugging
//end debugging
if (soilMoisturePercent <= moistureLimit) {
startWatering();
stopWatering();
// reset millis for the next iteration (pump timer only)
previousPumpMillis = thisMillis;
void startWatering() {
digitalWrite(relay, LOW);
Serial.println("pumping water now");
delay(100);
void stopWatering() {
Serial.println("stopping pumping water now");
delay(100);
Values();
Fade(currentMillis);
// Pump(currentMillis);
TimeSensor(currentMillis);
wdt_reset(); //wdt reset - added Jan 30
Any ideas on what could be causing this? I'm honestly at a loss for options here!
Cheers
ZF
