Topic: Copying all EEPROM send via Serial (Read 500 times) previous topic - next topic
LHSD
Hello!
I need to copy the entire EEPROM from an arduino and send it to another arduino via serial and save the EEPROM sent this second.
In other words, transfer the contents of the entire EEPROM from one arduino to another.
sterretje
Pseudo codes
sender
for each byte in eeprom
  read byte using EEPROM.read
  send read byte
  wait for confirmation from receiver
Note, there is a function or variable that indicates the length of the eeprom; consult the eeprom reference page
receiver
for each received byte
  save to eeprom using EEPROM.update
  send confirmation to transmitter
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
LHSD
Thank you very much friend!
I had already tried something similar, follow the code:
sender:
void exportarEt(){
  Serial.println("exportar etiqueta");
  cont1 = 0;//reinicializa contador do menu principal
  entra = false;//garante que entra não está pressionado
  Serial2.write(0);
  Serial.println("escrevi 0");
  for(int j = 0; j < 1023; j++){
    reenvia:
    Serial2.write(EEPROM[j]);
      t = 0;
      if(Serial2.available()>0){
        t = Serial2.read();
        while(t != 4){
          goto reenvia;
      Serial.println("enviado o byte");
      Serial.println(j);
  Serial.println("certo e desligando");
  asm volatile ("  jmp 0");
receiver:
if(comDados == 0){
        for(int i=0; i < 1023 ; i++){
          t = 0;
          if(Serial.available()>0){
            EEPROM = Serial.read();
            t = 4;
          Serial.println("recebi");
          Serial.write(t);
but it did not work
