Topic: I can`t connect wifi with my uno wifi rev2 (Read 1 time) previous topic - next topic
elissian
I got a uno wifi rev.2 but I can`t connect this board with my home wifi
I set already firmware updated lastest firmware. I select the example wifinina > ScanNetworks and compile the board and than I open the tool serial moniter to check the wifi connect to "uno wifi rev2"
(I check the firmwareVersion and  check the result is passed)
I set the wifinina the lastest version and check firmware and update lastest version but I can connect the wifi to board..... plz help....
elissian
I solve this problem...
all problem people use cable to computer or laptop;;
in my case I use the laptop so cable voltage convey low volt.
In this case, you need more power like 12 voltage battery and connect to your board.
I think if anyone had a problem with my case buy connecter about battery 12V and connect with your uno rev2
board.
