Topic: ATSam3x8e (Due) PWM pins (Read 203 times) previous topic - next topic
CyberOddity
Hi Guys,
I was hoping someone could confirm which pins support PWM on the Arduio Due (ATSAM3x8e). The official Arduino store says "PWM: Pins 2 to 13" but when referencing the unofficial Due pinout below
http://www.robgray.com/temp/Due-pinout.svg
It list PWM pins as digital pins 6-9, 34-45 and 53. Just wondering which is correct or if the is a correlation between the two that I am missing.
WattsThat
Quote
Huh? Not in the picture I see. Pins 2-13 in pink/rose whatever color you want to call it as shown for the pwm pins.
Vacuum tube guy in a solid state world
CyberOddity
Hi WattsThat, the part that's confusing me is the white labels "SAM3X8E PIN FUNC". They are listing the digital pins 6-9, 34-45 and 53 as PWM pins so I don't know which is correct. Is it that if I'm using a SAM3X8E on a due board I go by the rose labeled pins 2-13, but if I'm using just the SAM3X8E as a standalone micro controller I use digital pins 6-9, 34-45 and 53?
WattsThat
Ah, now I understand. Yes, those are hardware PWM pins... but they are not supported by the Arduino software. If you use the Arduino core, you're stuck with the pins in pink. Of course YMMV if you roll your own software with Atmel Studio but then you wouldn't be posting on the Arduino forum, you'd be hanging out on AVRFreaks. Right?
ard_newbie
You are not stuck with anything with the Arduino IDE.
Search in the DUE sub forum, there are numerous example sketches using direct register programming with the PWM peripheral.
CyberOddity
Thank you again for the Reply, So if I use the SAM3X8E as a stand alone MCU and use the Atmel studio IDE I can use the hardware pines for PWM? I know its completely off topic but does that go for my use of LED as I/O question you replied to as well. By that I mean can I use digital pin 13 as general I/O if I use Atmel studios. I have also bookmarked AVRFreaks as It look like I may be doing some heavy reading there soon, thanks for the site.
