Topic: [NEWBIE] Testing the Viability of my Circuit (Read 173 times) previous topic - next topic
TokenThinker
Feb 17, 2020, 01:59 am Last Edit: Feb 18, 2020, 05:58 am by TokenThinker Reason: Adding photo
Hello All,
I am a newbie and looking for assistance to see if the viability of my circuit is feasible.
Goal: Use Arduino Nano BLE 33 to control various motors and camera powered by LIPO 3s 2200mAh 30C battery.
Thanks!!
TokenThinker
#1
Feb 17, 2020, 02:20 am Last Edit: Feb 17, 2020, 02:22 am by TokenThinker
Is this is in the right Thread or should it be in Electronics??
Hutkikz
#2
Feb 17, 2020, 02:36 am Last Edit: Feb 17, 2020, 02:40 am by Hutkikz
One issue is that you will need another mosfet for the 3rd motor that does not currently have one.
If you click "Report to Moderator" at the bottom of your original post, you can ask to have the thread moved to the correct forum. DO NOT create another post.
TokenThinker
Thank you, I will report it to change the thread.
For the 3rd Motor - it is a N20 Metal Gear Motor (picture below), because of its size does it still require another mosfet? Can't the Arduino supplement that?
Hutkikz
That arduino board can only supply 15mA current max per pin.
Pretty much any motor will draw considerably more than that.
check the motors data sheet to be sure.
TokenThinker
Thank you for the clarification, I'll go make that adjustment and do some more research.
cherk
the diode from +vBat to the C1 is reverse biased also
wvmarle
Too bad you didn't post an actual schematic - Fritzing has a schematic view - those schematics generally still suck big time but it's a lot better already than these pretty images. Don't waste your time on Fritzing, it's lost time.
A hand drawn schematic (using normal schematic symbols and so) or one drawn with a real schematics drawing program such as KiCAD or Eagle is much more useful than anything you can produce with Fritzing.
The only thing I can say about that image is that you can't power a motor from an Arduino pin. The rest is just too hard to follow/understand and knowing such images may not even represent reality correctly.
Quality of answers is related to the quality of questions. Good questions will get good answers. Useless answers are a sign of a poor question.
TokenThinker
Thank you for all the feedback. I will go back to the drawing board and produce an actual schematic to give better clarity and receive better response.
TokenThinker
I have updated the schematic, I could use some assistance checking if it is correct.
Also I welcome any feedback to my drawing, this is the first time I have done this.
