Topic: Arduino Tank Problem with Motors Not Stopping When Stick Centered (Read 306 times) previous topic - next topic
Tayethin
I have a tank built with wifi controller. When I put the stick forward the motors go in that direction but they don't stop when the stick is centered or you've "let go" of the stick.
Am I blind? What am I missing here... I have 2 twin 3 year olds just DYING to get this going haha
Here's the Receiver Code:
---- Receiver Code ----
Mert Arduino Tutorial & Projects (YouTube)
Please Subscribe for Support
#include <Servo.h>    //the library which helps us to control the servo motor
#include <SPI.h>      //the communication interface with the modem
#include "RF24.h"     //the library which helps us to control the radio modem (nRF24L)
//define our L298N control pins
//Motor A
const int RightMotorForward = 2;    // IN1
const int RightMotorBackward = 3;   // IN2
//Motor B
const int LeftMotorForward = 4;     // IN3
const int LeftMotorBackward = 6;    // IN4
//define the servo name
Servo myServo;
RF24 radio(5,10);     /*This object represents a modem connected to the Arduino.
                      Arguments 5 and 10 are a digital pin numbers to which signals
                      CE and CSN are connected.*/
const uint64_t pipe = 0xE8E8F0F0E1LL; //the address of the modem,that will receive data from the Arduino.
int data[1];
void setup(){
  pinMode(RightMotorForward, OUTPUT);
  pinMode(LeftMotorForward, OUTPUT);
  pinMode(LeftMotorBackward, OUTPUT);
  pinMode(RightMotorBackward, OUTPUT);
  //define the servo input pins
  myServo.attach(14); //A0
  radio.begin();                    //it activates the modem.
  radio.openReadingPipe(1, pipe);   //determines the address of our modem which receive data.
  radio.startListening();           //enable receiving data via modem
void loop(){
  if(radio.available()){
    radio.read(data, 1);
    if(data[0] < 11 && data[0] > 6){
    // This is backward
    // Set a Motor A backward
    digitalWrite(RightMotorForward, LOW);
    digitalWrite(RightMotorBackward, HIGH);
    // Set a Motor B backward
    digitalWrite(LeftMotorForward, LOW);
    digitalWrite(LeftMotorBackward, HIGH);
    if(data[0] > -1 && data[0] < 4){
    // This is forward
    // Set a Motor A forward
    digitalWrite(RightMotorForward, HIGH);
    digitalWrite(RightMotorBackward, LOW);
    // Set a Motor B forward
    digitalWrite(LeftMotorForward, HIGH);
    digitalWrite(LeftMotorBackward, LOW);
    if (data[0] == 5){
    // Stop Motors
    // This is Backward
    // Set a Motor A Backward
    if(data[0] < 21 && data[0] > 16){
    // Set a Motor B Backward
    // Turn Right
    if(data[0] > 10 && data[0] < 14){
    // Turn Left
    if(data[0] == 15){
    // for the servo motor
    if(data[0] < 31 && data[0] > 21){
      int potValue = data[0];
      int potPos = map(potValue, 21, 30, 10, 170);
      myServo.write(potPos);
Here's the Transmitter Code:
---- Transmitter Code ----
//define the input pins
int x_axis = A0;
int y_axis = A1;
int potPin = A2;
//define variable values
int xValue;
int yValue;
int potValue;
int data[1];
RF24 radio(5,10);                     //5 and 10 are a digital pin numbers to which signals CE and CSN are connected.
const uint64_t pipe = 0xE8E8F0F0E1LL; //the address of the modem, that will receive data from Arduino.
void setup(void){
  radio.openWritingPipe(pipe);        //sets the address of the receiver to which the program will send data.
void loop(){
  //Send X-axis data
  xValue = analogRead(x_axis);
  xValue = map(xValue, 0, 1023, 0, 10);
  data[0] = xValue;
  radio.write(data, 1);
  //Send Y-axis data
  yValue = analogRead(y_axis);
  yValue = map(yValue, 0, 1023, 11, 20);
  data[0] = yValue;
  //Send Potentiometer data
  potValue = analogRead(potPin);
  potValue = map(potValue, 0, 1023, 21, 30);
  data[0] = potValue;
zwieblum
De bug code is missing, so add Serial.println() to sender and receiver code and check what is actually sent.
slipstick
Why is data an array with one element i.e. int data[1] instead of just int data?
Do the other controls work correctly e.g. backward, right,  left and the servo?
Have you confirmed that the value 5 is transmitted when the stick is centred?
But basically check your if statements because you have some large gaps e.g. (data[0] < 11 && data[0] > 6) covers only 7 to 10, (data[0] > -1 && data[0] < 4) covers 0 to 3, then 5 is stop. Nothing happens if data is 4 or 6. Did you intend that?
Steve
