Topic: LCD I2C does not work! checklist (Read 2931 times) previous topic - next topic
Feb 18, 2020, 10:00 am Last Edit: Feb 18, 2020, 10:10 am by IoT_hobbyist
  • Make sure that you wire LCD to Arduino correctly.
  • Make sure that you install the correct library.
  • Make sure that your code is correct.
  • Adjust the brightness of LCD by rotating potentiometer in the backside of LCD
  • Depending on manufacturers, the I2C address of LCD may be different. Usually, the default I2C address of LCD is 0x27 or 0x3F. Try these values one by one. If you still failed, run the below code to find the I2C address.
Code: [Select]
// I2C address scanner program
#include <Wire.h>
  Wire.begin();
  Serial.println("I2C Scanner");
  byte error, address;
  int nDevices;
  Serial.println("Scanning...");
  nDevices = 0;
  for(address = 1; address < 127; address++ )
    Wire.beginTransmission(address);
    error = Wire.endTransmission();
    if (error == 0)
      Serial.print("I2C device found at address 0x");
      if (address < 16)
        Serial.print("0");
      Serial.print(address,HEX);
      Serial.println("  !");
      nDevices++;
    else if (error==4)
      Serial.print("Unknown error at address 0x");
      if (address < 16)
        Serial.print("0");
      Serial.println(address,HEX);
  if (nDevices == 0)
    Serial.println("No I2C devices found");
    Serial.println("done");
  delay(5000); // wait 5 seconds for next scan
Learn more about LCD I2C in Arduino - LCD I2C tutorial.
Good luck!
DrAzzy
Trick here: with only power, no data, it should display a row of black and white boxes. Adjust until these are the desired darkness/brightness.
ATTinyCore and megaTinyCore for all ATtiny, DxCore for DA/DB-series! github.com/SpenceKonde
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts, mosfets, awesome prototyping board in my store http://tindie.com/stores/DrAzzy
lastchancename
Quote
You may like to expand on this in your original post...
e.g. 4K7 resistors etc...
Beginners don't know what 'correctly' is.
Experienced responders have a nose for laziness, (they were beginners once)... Sure, there are trolls, chest-beaters, and pretenders - but the help you'll get here is about as good as it gets - if you try to help youself!.
groundFungus
#3
Mar 13, 2020, 11:45 pm Last Edit: Mar 13, 2020, 11:48 pm by groundFungus
For I2C character based LCDs with the hd4478 LCD driver the best current library is the hd44780 library by Bill Perry.  The library will, automatically, detect the I2C address and the I2C backpack to LCD pin mapping.
The library is available for install through the library manager.
You will save everyone's time if you read and follow the forum guidelines.  :)
https://forum.arduino.cc/index.php/topic,148850.0.html
and
https://forum.arduino.cc/index.php?topic=97455.0
jackthomson42
I am trying to find the question in this thread ?
If you want to fly, you need to try .....
jubukraa
#5
May 04, 2020, 07:39 am Last Edit: May 04, 2020, 07:42 am by jubukraa
Read the forum heading...
