Hello team members
I use the Orduino Mega Model 2560
But I did everything I could to transfer a photo file from the system to Orduino and it couldn't be shown.
My screen is TFT and my picture is about 3K in size
From the computer I convert the image to a bitmap and then render it to a byte
But it is not possible to read and read it on the Orduino side
Anyone have any suggestions?
Please post your best effort
What is sending the file from the PC ?
I created a program in C # that made a 3 KB Qrcode file
I converted it to bitmap and then converted it to byte via memory stream
Then I sent it through
PortName = "COM10";
BaudRate = 9600;
DataBits = 8;
Parity = Parity.None;
StopBits = StopBits.One;
serial port
From the Orduino I read this code as follows
#include "Adafruit_GFX.h" // Core graphics library
#include "MCUFRIEND_kbv.h" // Hardware-specific library
MCUFRIEND_kbv tft;
#define BLACK 0x0000
#define RED 0xF800
#define WHITE 0xFFFF
int index = 0;
char Imagebmp[3062];
char x;
uint16_t ID = tft.readID();
if (ID == 0x0D3D3) ID = 0x9481;
tft.begin(ID);
tft.invertDisplay(true);
tft.setRotation(1);
tft.fillScreen(BLACK);
if (Serial.available() > 0)
x = Serial.read();
Imagebmp[index] = x;
Serial.flush();
index++;
What happens when you try ?
Have you tried printing the "bytes" as they are received ?
Do they look as you expect ?
No Exactly the problem here is the information I send
It is called incomplete
for example
After printing the index on the page I realized that this loop was for 317
The load worked and then the connection to receive the information was disconnected from the serial
And that means 317 bytes are sent but we haven't sent the rest and the data is incomplete
Do you think there is a way I can upload a bitmap photo from my computer and display it on the TFT screen after it has been uploaded?
To my knowledge the Mega resets when you open the serial port; you will have to wait a little till the Mega's boot loader has finished before you can send the data from the PC.
I would advise to implement a protocol; e.g. send 64 bytes from PC, wait for a reply from the Mega, send the next 64 bytes, wait for reply and so on. You can expand the protocol (e.g if the image size is not a multiple of 64 bytes you will need a length indication to tell the Mega how many bytes to expect).
I tried this way
I sent the data to 5 bytes and then printed the result on the page again the data was not fully sent and read about 2 bytes and 2 bytes and then no other data was sent and the serial connection was disconnected
When you modify things, you should post your updated code. And this time, please use code tags as described in e.g. How to use this forum - please read. - Installation & Troubleshooting - Arduino Forum.
We will also need to see your C# code that does the setup if the serial port and the transfer of the data.
There is a more suitable section for this on the forum, I will ask a moderator to move it.
Ehsanzamani:
I tried this way
printed result to what page ?
Is this on the C# code or the Arduino code?
sterretje:
Just checked and if the C# port settings that you provided are the only ones that you set, the board will not reset.
Below (over two posts) example code for Arduino and example code for a C# console application that demonstrates the idea of a protocol. I've mostly concentrated on the C# side of things; the Arduino code was quickly hacked together.
Arduino
byte buffer[4096];
byte chunkSize = 32;
pinMode(LED_BUILTIN, OUTPUT);
Serial.begin(57600);
receiveConfirmEcho();
receive data from PC
send a message back every chunkSize (32) bytes
when all data is received, echo the data back to PC
void receiveConfirmEcho()
static uint16_t index;
static uint32_t lastUpdateTime;
// read data if available
while (Serial.available() > 0)
// update the time that a byte was received
lastUpdateTime = millis();
// save in buffer
buffer[index++] = Serial.read();
// confirm
if (index % chunkSize == 0)
Serial.println(index);
// on time out, echo the received data back
if (index != 0 && (millis() - lastUpdateTime > 5000))
for (uint16_t cnt = 0; cnt < 4096; cnt += chunkSize)
Serial.write(&buffer[cnt], chunkSize);
delay(200);
// reset variables
index = 0;
memset(buffer, 0, sizeof(buffer));
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.IO.Ports;
namespace ArduinoProtocol
class Program
static SerialPort _serialPort = new SerialPort();
static int bufferSize = 4096;
static byte chunkSize = 32;
static byte[] dataToSend = new byte[bufferSize];
static byte[] receiveBuffer = new byte[bufferSize];
static Random random = new Random((int)DateTime.Now.Ticks);
static void Main(string[] args)
// create some data
for (int cnt = 0; cnt < dataToSend.Length; cnt++)
//dataToSend[cnt] = (byte)(cnt % 0x100);
dataToSend[cnt] = (byte)random.Next(256);
Console.WriteLine("Opening port");
if (connect("COM19", false) == false)
return;
if (_serialPort.IsOpen == true)
Console.WriteLine("Removing outstanding data");
while (_serialPort.BytesToRead != 0)
_serialPort.Read(receiveBuffer, 0, bufferSize);
Console.WriteLine("Sending data");
if (sendData() == false)
return;
Console.WriteLine("Receiving data back");
if (receiveData() == false)
return;
Console.WriteLine("Comparing data");
compareData();
_serialPort.Close();
/// <summary>
/// Open serial port
/// </summary>
/// <param name="portName">COMxx</param>
/// <param name="reset">reset arduino if true</param>
/// <returns></returns>
static bool connect(string portName, bool reset)
try
_serialPort.PortName = portName;
_serialPort.BaudRate = 57600;
_serialPort.DataBits = 8;
_serialPort.Parity = Parity.None;
_serialPort.StopBits = StopBits.One;
_serialPort.Handshake = Handshake.None;
_serialPort.ReadTimeout = 2000;
_serialPort.DtrEnable = reset;
_serialPort.Open();
Console.WriteLine("{0} opened", portName);
catch (Exception ex)
Console.WriteLine(ex.Message);
return false;
return true;
/// <summary>
/// send data in chuncks of 32 bytes; wait for confirmation after 32 bytes
/// </summary>
/// <returns>false on error, else true</returns>
static bool sendData()
for (int offset = 0; offset < dataToSend.Length; offset += chunkSize)
_serialPort.Write(dataToSend, offset, chunkSize);
try
string message = _serialPort.ReadLine();
Console.WriteLine(message);
catch (TimeoutException tex)
Console.WriteLine(tex.Message);
return false;
return false;
return true;
/// <summary>
/// receive data back from arduino
/// </summary>
static bool receiveData()
int numBytes = 0;
int numTries = 5;
while (numBytes < 4096)
try
int n = _serialPort.Read(receiveBuffer, numBytes, bufferSize - numBytes);
numBytes += n;
Console.WriteLine("numBytes = {0}", numBytes);
numTries--;
if (numTries == 0)
return false;
return false;
return true;
/// <summary>
/// compare outgoing and incoming data
/// </summary>
/// <returns>returns true if match, else false</returns>
static bool compareData()
if (receiveBuffer.SequenceEqual(dataToSend) == true)
Console.WriteLine("Match");
return true;
Console.WriteLine("No match");
return false;
Thanks, I'm testing and announced the result here
If you're just trying to send the bytes of a BMP file from a computer to the arduino, all you need is a software like 'realterm' that literally sends the data byte by byte to your microcontroller via serial connection, there's literally know need for java or c# coding on a PC application, people like to overcomplicate things.
