What is the easiest way to calculate a Median from 7 to 10 Ultra Sonic Sensor Readings? I am kind of new to Arduino code but here is what I have so far (below). I am getting a few readings out of 30 that are clearly outliers. Seems that some of my HC-SR04 sensors are worse than others too.
// define variables:
#include <EEPROM.h> // Initializes EEPROM; pulls in code from Ardiuno library.
int trigPin = 5; // trigger pin on the Ultrasonic Sensor HC-SR04 module is connected to Arduino Nano's pin 5
int echoPin=4; // echo pin on the Ultrasonic Sensor HC-SR04 module is connected to Arduino Nano's pin 4
float distance; // variable to store 'distance' reading
long duration; // variable to store duration time reading (from ultra sonic sound travel out and back from the arrow)
int led = 13
; // LED pin variable, the pin that the 'sight LED' is connected to (D13 with board LED)
int calPin = 6; // the input pin for the calibration push button for initial calibration after installation on bow riser - different for each bow set up. Done only once per bow.
//int arrow = 60; //sets maximum distance of arrow from sensor in millimeters changes depending on the distance is from the arrow to the HC-SR04 Ultrasonic Sensor (now stored in EEPROM)
int val = 0; // variable used to determin if calPin is high or low based on pushbutton (it is LOW if button is depressed, otherwise HIGH)
float arrow = EEPROM.read(0); // assigns the 'arrow' spec as the last distance stored in EEPROM (from HC-SR04 pushbutton calibration)
Serial.begin(9600); // USUALLY USED FOR SET UP REASONS FOR SPEED REASONS -Opens the serial port to communicate at 9600 bits per second on the Monitor
pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output
pinMode(echoPin, INPUT); // Sets the echoPin as an Input
pinMode(led,OUTPUT); // Sets led pin as Output from above
pinMode(calPin, INPUT); // Sets pushbutton as Input
digitalWrite(trigPin, LOW); // Clears the trigPin (low state is 0)
delayMicroseconds(5);
digitalWrite(trigPin, HIGH); // Sets the trigPin to the HIGH state ('1') for 10 micro seconds
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH); // Reads the echoPin, returns the sound wave travel time in microseconds
distance= duration*0.34/2; // Calculating the distance in mm (a fine resolution compared to inches or cm without decimals)
Serial.print("Distance: "); // USUALLY USED FOR SET UP REASONS AND NOT FOR FUNCTION IN THE FIELD FOR SPEED REASONS - Prints the Distance heading on the Serial Monitor
Serial.println(distance); // USUALLY USED FOR SET UP REASONS AND NOT FOR FUNCTION IN THE FIELD FOR SPEED REASONS - Prints the distance on the Serial Monitor
Serial.print("Arrow spec: ");
Serial.println(arrow);
// Arrow In Place
if (distance <= arrow && distance >= 0){ // IF distance is less than or equal to 'arrow' AND greater than or equal to zero (positive), then arrow is 'knocked & in place' (no LED light)
digitalWrite(led,LOW);
delay(1000); // delays about 1.0 seconds after arrow is released so light doesn't bother archer during release follow through.
else {
//No Arrow
digitalWrite(led,HIGH); // blink LED ON
delay(300); // LED on time delay
digitalWrite(led,LOW); // blink LED OFF
delay(300);
// Store to 'arrow' calibration distance to EEPROM
val = digitalRead(calPin); // read state of the calPin normally HIGH '1', else '0' if button is depressed
if (val == HIGH){ // check if the calPin input is HIGH (button released); if HIGH no calibration action is required. If low calibrate per 'Else' below
Serial.println(val); // USUALLY USED FOR SET UP REASONS AND NOT FOR FUNCTION IN THE FIELD FOR SPEED REASONS - Prints val to the Serial Monitor
else {
distance = distance + 30; // adds 30 mm to reading to assure no blinking LED if arrow is loaded but arrow rest has not been raised yet.
EEPROM.write(0,distance); // zero is the location in the EEPROM and 'distance' is the value stored there.
arrow = EEPROM.read(0); // re-establishes distance specification in variable 'arrow' to determine if an arrow is in place.
digitalWrite(calPin, LOW);} // when calPin is LOW ('0' state)
