Hi everybody,
For a project, I use big 34HS1456 stepper motors (
Datasheet). They were working fine in my setup, but there was an unexpected big load on the motor. Since then the motor lost its holding torque. Normally when energized, I can not move the axis at all. But since the 'accident' the shaft moves when it has to hold a small load still...
Does anyone know what happened with the stepper motor? And is it fixable?
I use two of the same motors in the setup, and the other one works still fine in the same conditions.
EDIT: The driver that I use: ACT DM860 that can handle up to 7.8A. I have it set to give a peak current of 5.7A (which matches the stepper).
Would love to get some responses and thoughts
