Topic: why SIM7600 MQTT return +CMQTTCONNECT: 0,6 ? (Read 684 times) previous topic - next topic
vietbac
Mar 09, 2020, 05:17 am Last Edit: Mar 11, 2020, 10:20 am by vietbac
Hi all,
I used the SIM7600CE and Arduino mega to send, receive message to MQTT.
My process to start MQTT in setup as
1. AT+CMQTTSTART
2. AT+CMQTTACCQ=0,"SIM7600_client"
3. AT+CMQTTCONNECT=0,\"tcp://tailor.cloudmqtt.com:11831\",90,1,\"xxxxxx\",\"yyyyyyyyy\""
4. AT+CMQTTSUBTOPIC
5. subscribe name
6. AT+CMQTTSUB
After that on loop, I send message to broker as process like this
1. AT+CMQTTTOPIC
2. Publish name
3. AT+CMQTTPAYLOAD
4. message
5. AT+CMQTTPUB
my problem is just broker can receive the first time.
if send more, SIM7600 return error 14, mean client busy, and after that return error 11, mean disconnect
Any people can help explain this problem ??
Thanks.
VB
pylon
Post the responses you get from the SIM7600 to the above commands!
vietbac
Hi pylon,
The SIM7600 return after send the AT+CMQTTCONNECT is
OK
+CMQTTCONNECT=0,6
I can't find any document talk about this error code.
Thanks.
VB
pylon
Quote
According to the manual:
Quote
6 - message receive fail.
Post your complete code and the complete output you get!
Did you try to disconnect (AT+CMQTTDISC) before you re-connect?
vietbac
Hi pylon,
yes, I have disconnect before re-connect, and just after turn on power or reset (AT+CRESET), the module also return same.
this is function for start
void startMQTTServer(){
   Serial2.println("Start MQTT server to broker >>");
   Serial2.println("send AT+ATE0 >>");
   sim7600.sendATcommand("ATE0", "OK", 1000);
   printResponceSIM();
   Serial2.println("send AT+CMQTTSTART >>");
   strcpy_P(str_buffer, (char *)pgm_read_word(&(cmd_table[11])));    //start network
   sim7600.sendATcommand(str_buffer, "+CMQTTSTART: 0", 2000);
   printResponceSIM();
//    sim7600.sendATcommand("AT+CMQTTACCQ=0,\"SIM7600_client\"", "OK", 2000);
   Serial2.println("send AT+CMQTTACCQ >>");
   strcpy_P(str_buffer, (char *)pgm_read_word(&(cmd_table[21])));    //issue name of client
   sim7600.sendATcommand(str_buffer, "OK", 2000);
   printResponceSIM();
   Serial2.println("send AT+CMQTTWILLTOPIC >>");
   sim7600.sendATcommand("AT+CMQTTWILLTOPIC=0,10", ">", 2000);
   printResponceSIM();
   Serial2.println("send will topic >>");
   sim7600.sendATcommand("will topic", "OK", 2000);
   printResponceSIM();
   Serial2.println("send AT+CMQTTWILLMSG >>");
   sim7600.sendATcommand("AT+CMQTTWILLMSG=0,56,1", ">", 2000);
   printResponceSIM();
   Serial2.println("send will topic message >>");
   sim7600.sendATcommand("you'd better set will topic before setting will message.", "OK", 2000);
   printResponceSIM();
//    sim7600.sendATcommand(AT+CMQTTCONNECT=0,\"tcp://tailor.cloudmqtt.com:11831\",600,1,\"xxxxxxxx\",\"xxxxxxxxxxxx\"", "OK", 2000);
   Serial2.println("send AT+CMQTTCONNECT >>");
   strcpy_P(str_buffer, (char *)pgm_read_word(&(cmd_table[20])));    //connect MQTT broker
   result = sim7600.sendATcommand(str_buffer, "+CMQTTCONNECT: 0,0", 180000);
   if(result){
       connectFlag=true;      //connect server OK
       Serial2.println("Connect OK !");
   }else Serial2.println("Connect NG !");
   printResponceSIM();
and this is return from SIM7600
send AT+ATE0 >>
OK
OK
+CMQTTSTART: 0
OK
send will topic >>
OK
OK
Connect NG !
OK
+CMQTTCONNECT: 0,6
Start send SUBTOPIC to broker >>
send AT+CMQTTSUBTOPIC >>
+CMQTTSUBTOPIC: 0,11
ERROR
pylon
This is not your complete code and you also forgot the code tags!
meroata
Can you please share the complete code because I need it
juhan5025
Hi, vietbac
did you resolve this?
I've been getting same issue,, so could you share how to fix this?
rykers
Sorry for bumping an old thread here, but I believe I am having this same issue.
I have detailed my problem here: https://forum.arduino.cc/index.php?topic=697539.0
Have spent weeks trying to fix this, even contacted SIMCOM support and attempted to contact one of their engineers... No response.
Did you manage to solve this issue? If so please share you fix with us.
