Topic: Trouble when moving IMUAccelerometer (MPU6500) (Read 191 times) previous topic - next topic
anneme
Hi together,
actually I am experimenting with an accelerometer an gyroscope of MPU6500.
I am able to read angluar velocity in LSB/°/s from I2C with the following code:
Code: [Select]
#include<Wire.h>
const int mpu_addr = 0x68;
  Wire.begin();
  Wire.setClock(400000UL); // Set I2C frequency to 400kHz
  Wire.beginTransmission(mpu_addr);
  Wire.write(0x6B);
  Wire.write(0); // wake up the mpu6050
  Wire.endTransmission(true);
  int16_t gx_LSBs = Acc_X();
  int16_t gy_LSBs = Acc_Y();
  int16_t gz_LSBs = Acc_Z();
  double gx = (double)1/16384*gx_LSBs;
  double gy = (double)1/16384*gy_LSBs;
  double gz = (double)1/16384*gz_LSBs;
  int16_t wx_LSBs = Gyro_X();
  int16_t wy_LSBs = Gyro_Y();
  int16_t wz_LSBs = Gyro_Z();
  //delay(500);
  Serial.print("gx:   ");
  Serial.print(gx);
  Serial.print("      gy:   ");
  Serial.print(gy);
  Serial.print("      gz:   ");
  Serial.print(gz);
  Serial.print("              ");
  Serial.print("wx:   ");
  Serial.print(wx_LSBs);
  Serial.print("      wy:   ");
  Serial.print(wy_LSBs);
  Serial.print("      wz:   ");
  Serial.print(wz_LSBs);
  Serial.println("");
// Funktionen Gyroskop
int16_t Gyro_X()
  Wire.write(0x43);
  Wire.endTransmission(false);
  Wire.requestFrom(mpu_addr,2);
  int16_t GyroX = Wire.read()<<8|Wire.read();
  return GyroX;
int16_t Gyro_Y()
  Wire.write(0x45);
  int16_t GyroY = Wire.read();
  GyroY = GyroY<<8|Wire.read();
  return GyroY;
int16_t Gyro_Z()
  Wire.write(0x47);
  int16_t GyroZ = Wire.read()<<8|Wire.read();
  return GyroZ;
// Funktionen Accelerometer
double Acc_X()
  Wire.write(0x3B);
  int16_t AccX=Wire.read()<<8|Wire.read();  // zweimaliges Lesen des I2C
  return AccX;
double Acc_Y()
  Wire.write(0x3D);
  int16_t AccY=Wire.read()<<8|Wire.read();
  return AccY;
double Acc_Z()
  Wire.write(0x3F);
  int16_t AccZ=Wire.read()<<8|Wire.read();
  return AccZ;
I am just wondering that very often the output is getting interrupted and result is:
gx:   0.05      gy:   0.07      gz:   1.00              wx:   -25    wy:   -122      wz:   -53
gx:   0.05      gy:   0.07      gz:   1.01              wx:   2       wy:   -115      wz:   -64
gx:   0.05      gy:   0.07      gz:   1.01              wx:   2       wy:   -82        wz:   -79
gx:   0.05      gy:   0.07      gz:   1.01              wx:   -23    wy:   -113      wz:   -77
gx:   0.05      gy:   0.07      gz:   1.00              wx:   -16    wy:   -114      wz:   -72
gx:   0.05      gy:   0.07      gz:   1.01              wx:   -51    wy:   -142      wz:   -75
gx:   -0.00      gy:   -0.00      gz:   -0.00          wx:   -1      wy:   -1          wz:   -1
Anyone having an idead of the reason for the problem?
Especially when moving the IMU output shows me wx=wz=wy = -1.
I can't imagine but is there maybe an overflow or another behaviour that explains this output?
Thanks a lot!
pylon
Quote
Most probably a wiring failure. Either a broken wire, bad breadboard contact or too long wires.
Idahowalker
Have you considered asking the mpu if it has new data ready before asking for a data read?
For testing try to set up using the mpu interrupt pin to trigger a data read when the mpu has data to see if you are still losing data. After making sure the wiring is not wonky.
anneme
I will configure the INT-Pin and try again.
I figured out that the error occures right after touching the mpu or moving it from the table.
Maybe there is an capacitive error?
Couldn´t find some information in the datahseet or the register map about the previous mentioned behaviour.
Does some of you know if there is a pin on imu that distrubes dataoutput when getting high or low?
Could the INT-Pin be the reason for these problem?
Thanks so far!!!
anneme
I guess I figured out the problem.
AD0 pin is not connected.
If AD0 is getting high, I2C adress is changing from 0x68 to 0x69.
