Topic: (solved) Arduino ADK Mega2560 Drivers (Read 70466 times) previous topic - next topic
pracas
Jul 21, 2011, 10:13 am Last Edit: Aug 01, 2011, 03:13 pm by Massimo Banzi Reason: 1
I've been trying to break my head on getting 2 of these boards to work. They are not detected as USB serial ports. As soon as i plug it, device manager in windows shows Atmega8u2. Is this how these boards show up by default? aren't they supposed to show as USB Serial ports? What could be wrong? In ubuntu 10.04, 'dmesg' shows high-speed USB Device but no Serial port... My other UNO works fine.
Anybody with a ADK board?
All help welcome...
knox
I received mine today and I can't get it working, either.
There is an updated boards.txt and a driver under
http://arduino.cc/en/Main/ArduinoBoardADK (at the very bottom).
Unfortunately, this does not seem to work for me.
Please keep me posted if you find something
knox
I just received an email from Arduino Shop:
Quote
we made a double check on the stock and we found that some unprogrammed ADK boards were shipped for mistake. We will send you immediately a replacement. Sorry for the disease.
Whatever that's supposed to mean...
pracas
Nothing works... tried programming the Atmega8u2 using another arduino & avrdude... it throws up a verification error towards the end and after this windows does not detect the device....
2 questions i have
1) what are fuse settings for the Atmega8u2 on a normal uno / mega2560? efuse, hfuse, lfuse, lock & unlock
2)How does one get the Atmega8u2 to show as AT90USB82 ? Another bricked uno on a hardware reset(like described in the DFU programming pafe) started showing as a AT90USB82 and it was easy to get it back working with flip
Cheers,
Pracas
shawnf
I managed to get it into a mode where the Arduino app can see it on my Mac, but the ADK demo fails to upload with:
avrdude: stk500_2_ReceiveMessage(): timeout
If you want to try, I downloaded the ATMel Flip program onto a Win7 box, then installed the correct USB drivers by browsing for them in Device Manager.
I then used the SourceForge link to download the Arduino-usbserial-mega.hex file.
I selected the USB device in Flip and then loaded the USBSerial mega hex file and it let me program it with the Run option. At this point I selected the Start Application which switch the Mega 2560 into the USB serial mode rather than DFU mode and the serial drivers appear in the Arduino app on the Mac and I can attempt (and fail) to upload the  demokit.pde from the ADK.
However I see other people complaining about a similar avrdude timeout on the Mac, so it could be I have got it "working" as much as I can on the Mac... trying an ADK download on the Win 7 box as I type this, so fingers crossed.
pracas
What is the device you chose in flip? and can you outline the step by step process... it keeps failing for me... after programming with flip, it still shows as an "Unrecognised USB device"
shawnf
I'll have to remember from memory as once I did the Start Program it switched out of DFU mode and I'm not sure how to switch it back.
I should say I still haven't got past the timeout when uploading, so I might have flashed the wrong .hex file, but it certainly got me further, as the RX light is now flashing and it is set to COM6 on the PC and detected by the Arduino app.
I used Win7 x64. I started with it showing as a Atmega8u2 device without the driver installed (! in Dev Manager).
After installing flip, I installed the driver for the Atmega8u2 by browsing for it on PC in Dev Man.
Then in Flip I think I just selected USB and it un-greyed all the lower screen allowing you to chose things in the Run panel and select a HEX file.
I then selected the .HEX file I had downloaded from SourceForge (using RAW) - note the combined DFU/Serial file won't work, only the SerialUSB.... of course this still could be the wrong HEX file, given my upload issues.
At this point I chose the Start Program button on the bottom right of Flip. This switched the Mega ADK out of DFU mode and a new serial driver appeared in Dev Man (again without a driver).
I installed the driver by browsing PC in Dev Man and at this point it shows up as COM6.
Then back to the Arduino app and I can see it as COM6 in the Tools menu and having done the boards.txt change, I can select it as a Mega ADK.
On the Mac it shows in the dev/tty list and I can select it in the Tools menu.
Now I'm stuck at the timeout after verifying and trying to upload the ADK .PDE (or any built setup):
Still trying to find out where to go next, but it's certainly better than the default ship state :)
pracas
Ok i'm there as well... managed to put the usb-serial firmware on the 8u2 and then put the atmega2560 [atleast a mega2560 is better than a dead board!]  firmware on it and now the same error
both on ubuntu 10.10  & Windows XP
just an observation... left alone the led on pin 13, tx come on every once in a while...looks like the board is resetting
shawnf
I have a nasty feeling that the bootloader hasn't been installed, so you need access to an AVR ISP programmer to install it the first time :(
pracas
there was no bootloader on the atmega2560... avrdude wouldnt intially start without the -B 4800 option.... meaning which the fuses were not set... now i've burnt the bootloader using another duemilanove... everything is successful but still the same error...perhaps someone else can throw some light
knox
I just received a replacement board.
It finally works :)
shawnf
Glad it works :)
I got an AVR programmer and it installed the bootloader from the Arduino but it still won't communicate...
I can change preferences.txt to use the AVR programmer rather than bootloader and then I can install sketches like Blink. Interestingly I added some Serial traces to it and get nothing but corrupted characters in the serial monitor regardless of the baudrate I choose.
My guess is that serial comms are broken and this is why the bootloader isn't working.
knox
Guess I rejoiced too early....
I keep running into an OSCOKIRQ error:
Quote
Error: OSCOKIRQ failed to assert
This happens when I try to connect to the Android Accessory via
Code: [Select]
acc.powerOn();
The Mega ADK board is connected to a Tinkerkit. Moreover, there is an external power supply and USB B to the pc.
Any hints on this?
shawnf
I managed to get my broken board working :)
I flashed the combined DFU and usbserial HEX file using the AVRISP on the other 6 pin header and it turns into a at90usb82. Then I set it to running in Flip (Start button with reset unchecked).
At this point I installed the bootloader via the AVRISP and I can successfully install a Sketch via the bootloader. Turns out the test app I use was putting out too much over the serial port, so I went back to ISP installs rather than bootloader, but I am getting correct serial comms and I managed to install the devkit.pde :)
I had to edit out some of the devkit joystick inits and at this point I can see the error that the USB device doesn't support accessory mode. I am trying CyanogenMod7 on my GalaxyS and with the accessory JAR and permission added, but it still doesn't support accessory mode :(
Roll on a 2.3.4 official build on the Galaxy S... as I'm stuck until either my Xoom (running 3.0.1) or S or even the S2 gets accessory mode support.
pracas
@ Shawnf... can you be a bit more clear... Some questions for you
Which Combined DFU and usbserial HEX did you burn the MEGA-dfu_and_usbserial_combined.hex?
So first you put the above using avrisp and then it shows as AT90usb82 and then you used flip to put the  Arduino-usbserial-mega.hex?
after that it shows up as mega 2560? and the you were able to use the arduino ide to put up the sketch?
