Topic: error uploading for board Arduino uno (Read 510 times) previous topic - next topic
ayaanakmal
I got an error before  uploading the sketch but after compiling
Iam using an arduino nano and i DONT UNDERstand the error  message , please help
error is;avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.33.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM4
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: ser_open(): can't open device "\\.\COM4": The system cannot find the file specified.
avrdude done.  Thank you.
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
pert
Make sure you have selected the port of your Arduino board from the Tools > Port menu.
If you don't know which port is your Arduino board, you can find it like this:
  • Unplug your Arduino board from the computer.
  • Tools > Port
  • Note the ports, if any, listed in the menu.
  • Close the Tools menu. The ports list is only updated when the Tools menu is re-opened, so this step is essential.
  • Plug your Arduino board into the computer.
  • Tools > Port - The new port listed in the menu is your Arduino board.
ayaanakmal
does not work and got the error;
       Using Port: COM6
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x17
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x17
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x17
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x17
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x17
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x17
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x17
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x17
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x17
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x17
avrdude did.  Thank you.
pert
Select Tools > Processor > ATmega328P (Old Bootloader) and then try uploading again.
15mxcixj
I Used to get the same error message, Make sure the board isn't connected to usb3.0 but is connected to 2.0. Restarting my computer would generally fix the issue, but when I first got the Arduino I had to install some drivers and then it started working and when I got the error message I would restart my computer and it would fix it.
