Topic: Burned a diode near the Arduino Mega's USB port (Read 231 times) previous topic - next topic
rajeshar1995
Mar 26, 2020, 08:32 pm Last Edit: Mar 27, 2020, 01:49 pm by ballscrewbob
I was building a 3D printer on the Arduino Mega+RAMPS 1.4 electronics and had a 5V usb supply connected to the Mega when the printer was running. There was a spark seeing which I switched off the whole machine. I found that a diode next to the usb port was burnt. Is there anyway I can salvage this Mega ?
(mod edit)
ballscrewbob
#1
Mar 27, 2020, 01:52 pm Last Edit: Mar 27, 2020, 01:54 pm by ballscrewbob
Some of the cheaper CNC shields can short on on the USB case.
Usually I place some insulation tape over it to prevent that.
The diode can probably be replaced ( see schematic )
But that does not guarantee a fix if any other items have been damaged.
BTW is that a true Arduino as there should be a RESET button close to that position ?
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google (who would have thunk it ! ) or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
rajeshar1995
Thanks for the update. I'll try replacing the diode and see if works.
I bought this board sometime back, I think it's a clone.
