Topic: Arduino UNO board does not sit flat on plastic base (Read 6700 times) previous topic - next topic
kvoki
Trying to screw the board to the base but the metal bits sticking from the power socket and the USB do not let the board to lay flat. It's up to the point that I cannot even put in the screw that should go next to the power socket.
Am I missing some step here?
UKHeliBob
Use plastic spacers or several plastic washers between the board and the base
pingi_j
I hade the same problem. So I started with the screw close to the power socket, It worked better. I also just screwed them on by hand so as to not break anything, everything felt so fragile.
enrique56
Deseo comprar un kit de inicio con at mega 328p pero quiero preguntarles si existe una mejor alternativa, con algún otro procesador, que sea más útil a futuro y se pueda utilizar en más proyectos,
Que opinan ?
