Topic: Error: "Selected board depends on 'arduino' core (not installed)." (Read 262 times) previous topic - next topic
roel_ams
I normally would not open a topic for these kind of question, as I always manage to solve my issues searching the internet.
However, after two days of trying to fix the issue, i'm stuck.
I was running Arduino IDE 1.8.12 without any issues for months. However, since two days when trying to build a (any) project it fails with the error message "Selected board depends on 'arduino' core (not installed).".
I have searched this forum, and people with the same issue reported this 5 years ago, and managed to solve it.
I'm using the Arrow / Smart Everything Fox board, for which I have installed the board from the Board Manager. Using the already included boards, I don't get this error message. So the problem is between Arduino IDE and the Smart everything board library.
What I have tried:
- Removed everything: Arduino IDE, ~/.arduino15 directory, ~/Arduino directory.
- Installed different versions of Arduino IDE (1.6.*, 1.8.*)
- Installed different versions of Arrow board library
- Installed different versions of Arduino AVR Boards library
Any tips?
Thanks in advance!
ballscrewbob
After having installed so many versions of the IDE a clean up may be worth a shot also.
Attached a method that has worked for lots of people.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google (who would have thunk it ! ) or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
roel_ams
Thanks, for the document. Although I'm running Linux, I will check if I can get any hints from the document.
Tips from Linux users, still welcome :-)
tf68
Do you have the arduino core that supports the processor on your board installed?
pert
The "Arrow Boards" platform has a dependency on the "Arduino SAMD (32-bits ARM Cortex-M0+)
  • Boards" platform. So you also need to install Arduino SAMD Boards:
  • Tools > Board > Boards Manager
  • Wait for the downloads to finish.
  • From the list of platforms, click on "Arduino SAMD (32-bits ARM Cortex-M0+) Boards".
  • Click the "Install" button.
  • Wait for the installation to finish.
  • Click the "Close" button.
You will now be able to use your Smart Everything Fox board without getting that error about the missing core.
roel_ams
Thanks, this was the solution! Everything works again!
