Topic: LDR Photoresistor and resistance (Read 1 time) previous topic - next topic
Grumpy_Mike
Quote
But i'm learning on my way,
Given your response to my answers I would question that.
Bjerknez
Whatever...
wolframore
I found an standalone photoresistor that came with the Arduino Kit i bought for several mounth ago. It worked perfectly and now i regret bying a bounch of the LDR modules i have.
But i'm learning on my way, and i did not break the bank, so i will survey :)
It's ok I think we all have plenty of "extra" parts and modules that may be good somewhere one day... :)
Bad Boys Race Our Young Girls But Violet Generally Wins - Get Some Now :) - ELI ICE man
Ron_Blain
Agree, you can never have too many parts.
Ron
Grumpy_Mike
Whatever...
The what ever means that fewer people are going to want to help you in future. ************** you
Bjerknez
No, that means I don't care what you think of me.
I also don't have the time or the desire to discuss with you.
But i really think your nick maybe fits you well :)
Bjerknez
Yes, some day they will be usefull.... maybe :)
TomGeorge
Did you google
ESP32 LDR
Tom... :)
Everything runs on smoke, let the smoke out, it stops running....
Smajdalf
While Grumpy_Mike is often *** he is sometimes right on simple things. Such as here. You are using your module wrong. It has two outputs: you want to use the analog one marked as AO. You are using the "wrong" one (marked as DO). If you have time look at the module again, try to find a schematic and learn how it works. It is simple but useful circuit.
Bjerknez
No, my module has no analog pin. Image i pasted earlier is an image i found on the internet i thought was the same, but is is'nt.
So Grumpy is right, bus the sametime not.....
My fault by the way...
wolframore
:D
I wanna know what *** means
wolframore
Perhaps the pin out will help... most of the pins are analog and digital.
Bjerknez
I have seen it.
It does not helped me. It's much easyer to use an standalone LDR with two legs. Works as a charm, and much cheaper too :)
wolframore
Bjerknes, perhaps there's a communication issue... Grumpy was pointing out that you can't use a digital pin to read analog data.  If it's working now then you have it on an analog pin.  Perhaps its a small language issue.
Bjerknez
Maybe... but i uset the same pin. I just changed the LDR sensor and the second one worket fine. I'm sure it can be fixed with the right code etc. but it's much simplier to use an sensor that works out of the box :)
