Topic: Help with Mozzi library (Read 452 times) previous topic - next topic
westrose
I have been playing around with the Mozzi library on a Arduino Nano. When making a four step sequencer I can use the mozziAnalogRead command to change the frequency of each step, but the problem is I would like to use another pot for the tempo of the sequencer. It seems like this library does not use the standard delay type command because it will interrupt the audio. I am new to Mozzi library but not to Arduino. Any help is appreciated. I can post the code if need be.
Thank you
MarkT
#1
Apr 01, 2020, 11:58 am Last Edit: Apr 01, 2020, 12:00 pm by MarkT
Have you seen and understood the BlinkWithoutDelay example sketch?
Also if you read the Mozzi documentation you'll see there's an EventDelay() mechanism to
help with scheduling.
[ I DO NOT respond to personal messages, I WILL delete them unread, use the forum please ]
