Topic: Arduino and Grbl (Read 69 times) previous topic - next topic
teomaras
I have an issue in importing the GRBL library:
- I downloaded most recent version from official Github repository (LIBRARIES THAT COULD NOT BE IMPORTED:
[grbl] parse library.properties: library.properties not found) as zip file
- I extracted the file, then (following suggestions in other forums) I created new file library.properties and inserted all the needed arguments as per Arduino library specification (https://arduino.github.io/arduino-cli/library-specification/)
- I compressed again the directory as .zip file
- I tried to import the library as Zip file both with Arduino Online tool and also with offline version Arduino IDE but I always get error:
Am I doing some mistake in the procedure or may anyone copy/paste content of his own library.properties file?
Thanks,
Matteo
ballscrewbob
TOPIC SPLIT
DO NOT HIJACK / NECRO POST !
Some more detail about the IDE you are using may be helpful ?
Also the GRBL library should ideally not be played with unless you are up to speed on how it works.
It works great here from IDE 1.6.5 all the way up to the latest version.
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Bob.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google (who would have thunk it ! ) or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
