Topic: trouble with non-blocking function (Read 2648 times) previous topic - next topic
rcayot
Apr 07, 2020, 09:38 pm Last Edit: Apr 07, 2020, 10:06 pm by rcayot
thanks in advance for any help.
I am trying to write a program to pulse LEDs with PWM, but vary the duty cycle to brighten and dim them each independently.  I have seen something in an advanced forum that used individal times, and maybe that is necessary, but I wanted to try my hand at this using various techniques from this and other forums.
I am using an Adafruit Metro 4 express (SAMD51) and yes tthe pins are PWM, they work properly with some versions of the code.  One, the first function call runs over and over, I was trying to get it to end, and go one to the next function call.
Here is my code.
Code: [Select]
unsigned long StartMillis;
unsigned long CMillis;
const unsigned long fadePeriod = 100;  //fade period
int fadeLedPin[] = {2, 3, 4, 5, 6, 7};    //this LED will fade
int brightness = 0;  //initial brightness of LED
int increment = 17;  //amount to change PWM value at each change
int ledpin;
int led;
int x;
int count;
 Serial.begin(115200);  //start Serial in case we need to print debugging info
 StartMillis = millis();  //start time of fading LED
 // int count = 0;
 CMillis = millis();  //get the current time
 // Serial.println(count);
 fade(fadeLedPin[1]);
 fade(fadeLedPin[0]);
void fade(int led)    //function to fade an LED
 if (CMillis - StartMillis >= fadePeriod) // && (count <= 15))  //test whether the period has elapsed
   analogWrite(led, brightness);  //set the brightness of the LED
   brightness += increment;
   // Serial.println(brightness);
   if (brightness >= 254) {
   brightness = 0;}
   return;
   // Serial.println(CMillis);
   StartMillis = CMillis;  //IMPORTANT to save the start time of the current LED state.
   // count = count + 1;
a couple of things.  The first, and kind of unrelated is that I tried to use a counter ( int count;)  set it to zero (0), when I try to troubleshoot using Serial.println(count) the thing always starts at 10!  I really don't get that for sure!
I have two LEDs hooked up (pins 2, 3) and would just like the function to exit back to the loop with some kind of test, I tried a timer, a break, a continue, etc.  If the function returns it is usually with brightness at max, and both LEDS on max.
Anyway, some help would be great for me, I am in lockdown, and programming is what I have been learning this wither season and it keeps my brain occupied.
Roger
marco_c
#1
Apr 07, 2020, 09:45 pm Last Edit: Apr 07, 2020, 09:47 pm by marco_c
Are pins 2 and 3 actually PWM capable pins on your Arduino board (you don't say which one it is)?
Also, please post code inside code tags so that it will
Code: [Select]
look like this
an auto-format your code using the IDE before posting so that it is easier to read. You can edit a previous post.
Arduino Libraries https://github.com/MajicDesigns?tab=Repositories
Parola for Arduino https://github.com/MajicDesigns/Parola
Arduino++ blog https://arduinoplusplus.wordpress.com
PerryBebbington
#2
Apr 07, 2020, 10:29 pm Last Edit: Apr 07, 2020, 10:31 pm by PerryBebbington
Code: [Select]
Your fade function does not distinguish between one LED and the other. It only has one StartMillis and CMillis but you are expecting it to time 2 or more things with only 1 timer. Each thing you want to time needs its own timer.
Here is the code I occasionally post for debouncing buttons. While it is not what you want have a look at how I do timing using millis for 4 buttons independently inside the debounce function. Take what I have done there and adapt to what you are doing.
Code: [Select]
/* Simple button debounce for 4 buttons. Increments a count and sends the updated count to the serial monitor once per button press */
/* Tested on an Uno */
/* Connect simple push to make buttons between 0V and pin 2, 0V and pin 3, 0V and pin 4 and between 0V and pin 5 */
#define noOfButtons 4     //Exactly what it says; must be the same as the number of elements in buttonPins
#define bounceDelay 20    //Minimum delay before regarding a button as being pressed and debounced
#define minButtonPress 3  //Number of times the button has to be detected as pressed before the press is considered to be valid
const int buttonPins[] = {2, 3, 4, 5};      // Input pins to use, connect buttons between these pins and 0V
uint32_t previousMillis[noOfButtons];       // Timers to time out bounce duration for each button
uint8_t pressCount[noOfButtons];            // Counts the number of times the button is detected as pressed, when this count reaches minButtonPress button is regared as debounced
uint8_t testCount[noOfButtons];             //Test count, incremented once per button press
  uint8_t i;
  uint32_t baudrate = 115200;
  Serial.begin(baudrate);
  Serial.println("");
  Serial.print("Serial port connected: ");
  Serial.println(baudrate);
  for (i = 0; i < noOfButtons; ++i) {
    pinMode(buttonPins[i], INPUT_PULLUP);
    Serial.print("Testcount ");
    Serial.print(i);
    Serial.print(" = ");
    Serial.println(testCount[i]);
  debounce();
  delay(10);     //Your other code goes here instead of this delay. DO NOT leave this delay here, it's ONLY for demonstration.
void debounce() {
  uint8_t i;
  uint32_t currentMillis = millis();
    if (digitalRead(buttonPins[i])) {             //Input is high, button not pressed or in the middle of bouncing and happens to be high
        previousMillis[i] = currentMillis;        //Set previousMillis to millis to reset timeout
        pressCount[i] = 0;                        //Set the number of times the button has been detected as pressed to 0
      if (currentMillis - previousMillis[i] > bounceDelay) {
        ++pressCount[i];
        if (pressCount[i] == minButtonPress) {
          doStuff(i);                             //Button has been debounced. Call function to do whatever you want done.
// Function to do whatever you want done once the button has been debounced.
// In this example it increments a counter and send the count to the serial monitor.
// Put your own functions here to do whatever you like.
void doStuff(uint8_t buttonNumber) {
  ++testCount[buttonNumber];
  Serial.print("Button ");
  Serial.print(buttonNumber);
  Serial.print(" testcount = ");
  Serial.println (testCount[buttonNumber]);
rcayot
thank you Perry.
I am working through that code to try to better understand it, I am making progress.
I do have other questions though.
In my code,
Code: [Select]
  if ((CMillis - StartMillis >= fadePeriod) && (pulsecount < 1))   {
I thought that using 'fade(fadeLedPin[]' could pass the LED pin # to the function, and in the function call the 'void fade(int led)' used the proper pin passed in the alalogWrite command.
What I seem to be having a problem with is ending the function call, sending back to the 'loop' portion and passing the next 'fadeLedPin' back to the function.
Roger
noiasca
#4
Apr 08, 2020, 04:29 pm Last Edit: Apr 08, 2020, 04:32 pm by noiasca
if you would like to fade several LEDs, i suggest to use a very basic class for the LED and put all objects in one array, to have easy access to all your LEDs.
Something like that (PWM pins from an UNO)
Code: [Select]
  pulse LED with PWM
  https://forum.arduino.cc/index.php?topic=675980
  by noiasca
class PulseLed
  private :
    const byte ledPin;                       // has to be a GPIO with PWM
    uint8_t interval = 50;                   // the intervall in milliseconds for each change
    uint32_t previousMillis = 0;             // stores the last change
    uint8_t pwm = 0;                         // actual value of PWM
    uint8_t start = 0;                       // range from (lowest PWM value)
    uint8_t end =  255;                      // range to (highest PWM value
  public :
    PulseLed ( byte ledPin) :
      ledPin(ledPin)
    void begin() {
      pinMode(ledPin, OUTPUT);
    void setInterval(byte newInterval)
      interval = newInterval;
    void setRange( byte newStart, byte newEnd)
      if (newEnd > newStart)
        start = newStart;
        end = newEnd;
    void tick() {
      if (millis() - previousMillis > interval)
        previousMillis = millis();
        if (pwm % 2)                       // odd - going upwards
          if (pwm < end -1 ) pwm = pwm + 2;
          else pwm = pwm -1;               // turn direction to downwards
        else                               // even - goint downwards
          if (pwm > start) pwm = pwm - 2;
          else pwm = pwm + 1;              // turn direction to upwards
        analogWrite(ledPin, pwm);
PulseLed pulseLed[] {3, 5, 6, 9, 10, 11};  // UNO PWM pins 3, 5, 6, 9, 10, 11
//PulseLed pulseLed[] {3};                // do tests with just one LED
  Serial.println(F("\nStart"));
  for (auto & i : pulseLed)
    i.begin();
  pulseLed[0].setRange(0, 255);          // set an individuall PWM range from ... to ...
  pulseLed[1].setRange(64, 128);         // this LED never goes off, lowest value 64
  pulseLed[1].setInterval(10);           // set the interval/speed of pulsing
  pulseLed[2].setInterval(20);
    i.tick();                 // tick each led on
I added some setter to show the different fadings.
The basic idea is: let each "LED Object" controll it's pwm rate. Just tick/run/call each LED object frequently. The object knows, if it is time to change anything.
how to react on postings:
- post helped: provide your final sketch, say thank you & give karma.
- post not understood: Ask as long as you understand the post
- post is off topic (or you think it is): Stay to your topic. Ask again.
- else: Ask again.
rcayot
 well that sketch certainly allows varying PWM of separate pins 'simultaneously' so now I know it can be done.
A few questions about the sketch though.  I am not familiar with 'auto'
Code: [Select]
    i.begin();
  pulseLed[1].setRange(0, 255);         // this LED never goes off, lowest value 64
  pulseLed[0].setInterval(10);           // set the interval/speed of pulsing
tick I get is a call.
Roger
noiasca
#6
Apr 08, 2020, 07:29 pm Last Edit: Apr 08, 2020, 07:34 pm by noiasca
long story short:
it iterates through all indexes of pulseLed, assignes a reference called i ('cause of &) and the type is auto. So in this case the type of pulseLed. In the for loop you have access to the method .begin() of your referenced object or on any other (public) method of your class.
You could replace it by a for (byte = 0; i< numberOfPulseLeds; i++) and do a call
Code: [Select]
pulseLed[i].begin().
But than you have to either define a numberOfPulseLeds or calculate the size of it. Therefore, use the newer range based for.
You can google for "range based for c++" and you will find better explanations for shure.
.tick() is just the name of the method. You could name it "do" or "run" or "handle" if you like it better. It's just the method which should be called over and over again during loop.
I like the idea of an analog clock: tick ... tick ... tick ...
- else: Ask again.
PerryBebbington
Quote
I thought that using 'fade(fadeLedPin[]);' could pass the LED pin # to the function
Yes, correct, it does. That isn' the problem with your original code. You original code tries to deal with timing 2 different LEDs with only one timer. I don't believe that's what you want. I believe you want to time the 2 LEDs independently. If that's not correct then my apologies for the misunderstanding.
rcayot
Perry,  Thanks, I see that.  These examples give me lots of things to do and think about.  I am certain I will make progress, and I know if I have any more questions, I will find great help here!
Roger Ayotte
PerryBebbington
++Karma; // You're new here, good to see someone who is new thinking about the advice they have been given and trying to make sense of it. Good luck :-)
rcayot
well, I have managed to utilize your code (noiasca) but it is way more advanced than my stage of learning.  I have tried to review some basic C++ information on classes etc. but with very marginal understanding, I really am a noob.
So, here is what I did.
Code: [Select]
  pulse LED with PWM
  by noiasca
class PulseLed
  private :
    uint8_t interval = 100;                   // the intervall in milliseconds for each change
  public :
      ledPin(ledPin)
    void begin() {
        start = newStart;
        end = newEnd;
    void tick() {
          if (pwm < end - 1 ) pwm = pwm + 2;
          else pwm = pwm - 1;              // turn direction to downwards
PulseLed pulseLed[] {2, 3, 4, 5, 6, 7}; // UNO PWM pins 2,3,4,5,6,7
    i.begin();
  pulseLed[2].setRange(0, 255);
  pulseLed[2].setInterval(10);
  pulseLed[3].setRange(0, 255);
  pulseLed[3].setInterval(10);
  pulseLed[4].setRange(0, 255);
  pulseLed[4].setInterval(10);
  pulseLed[5].setRange(0, 255);
  pulseLed[5].setInterval(10);
  [code]for (auto & i : pulseLed)
and my six LEDs can use PWM with varying PWM starts and stops.  Here is what I do not seem to be able to do:
take this line, and instead of using a 'for' and iterating through the items, call each one individually, with the ability to:
a. limit the pulse to one cycle.
b. call each LED with 'tick()' for example.
I cannot figure out how to use the i.tick(); with instead of i, either PulseLed, or pulseLed or whatever.  It would really make my day if you could help me move a little bit along.  I have given much effort with not much in terms of results.
Thanks in advance,
Roger
noiasca
Quote
if you don't use the auto ranged based for you could just call the .tick() method for each single object:
Code: [Select]
pulseLed[0].tick();
pulseLed[1].tick();
pulseLed[2].tick();
pulseLed[3].tick();
pulseLed[4].tick();
pulseLed[5].tick();
but in the end there is no reason not to call the .tick() for each method. See next:
Quote
in this case you need to modify the class.
-add a status variable and
- act if you have reached the full cycle stop pulsing within the .tick method, like a finite state machine in the class
- introduce methods to start/stop (to reset the status) again.
but before we go into that more deeply you have to specify
Q: When do you want to start pulsing?
A: Assumption: on program start
Q: When do want to stop pulsing?
A: Assumption: after one full iteration up and down
Q: When do want to restart pulsing?
A: ?
Please correct the assumptions and define the missing one.
PS: regarding your code duplicates
Code: [Select]
if want to have all LEDs pulsing the same range it's enough if you modify the default values in the class:
Code: [Select]
so you can delete your 5 lines of .setRange(0, 255);
- else: Ask again.
rcayot
thank you noiasca,
I thought I had tried 'pulseLed[0].tick();' but apparetnly not as it works.  Now I can use timing, interrupts etc to control the pulses.
I understand the lack of need to use a long list of setups for the leds, but I did it so I could have the control to have them be the same or not.
as far as questions:
"Q: When do you want to start pulsing?
A: Assumption: on program start - yes, or a button push.
A: Assumption: after one full iteration up and down -yes, for now I want one 'pulse' and then move on, wait for another condition to be satisfied for example.
A: this will be conditional, for example after every LED has pulsed one time, start over.
What I am hoping to do is to have one LED begin pulsing, and before it is finished with its one cycle, begin the next, to kind of leave a 'trail' of LEDs.
I have enought to begin using wha tyou have given me, but one part of your code is really vexing me.
   void tick() {
I have tried to use this code in another sketch, but I am having trouble getting it to work, for some reasont millis() useage is not allowing me to stop at just one iteration.  It is okay, just some more noodling on my part will get there.
Thanks again,
Roger Ayotte
noiasca
as mentioned already, if you want to "stop" the pulsing,
define a separate status variable byte isRunning= true;
Set the status  to  true / false if needed.
modify the if and check this variable.
there is no reason to avoid "ticking" the LED. Just set isRunning to false.
e.g. switch toggle the pulsing for the the second pin:
Code: [Select]
  by noiasca
class PulseLed
  private :
    uint8_t pwm = 0;
    uint8_t start = 0;
    uint8_t end =  255;
    uint8_t isRunning = true;
  public :
      ledPin(ledPin)
    void begin() {
        start = newStart;
        end = newEnd;
    void setStatus(byte newStatus)
      if (newStatus)
        pwm = start;
        isRunning = true;
        analogWrite(ledPin, 0);
        pwm = start;
        isRunning = false;
    void tick() {
      if (millis() - previousMillis > interval && isRunning)
        Serial.println(pwm);
const byte buttonPin = A1;
void checkButton()
  static byte previousButton = HIGH;
  byte button = !digitalRead(buttonPin);
  static byte toggle;
  if (button && !previousButton)
    toggle = !toggle;
    pulseLed[1].setStatus(toggle);
  previousButton = button;
    i.begin();
  pinMode(buttonPin, INPUT_PULLUP);
  pulseLed[1].setRange(64, 128);         // this led never goes off, lowes value 64
  pulseLed[2].setInterval(10);          // set the interval/speed of pulsing
  pulseLed[3].setInterval(20);
  checkButton();
This works as long as we do not read:
Unfortunately this is a complete new requirement, which changes nearly "everything".
My code was based on "brighten and dim them each independently.". You don't want to pulse independently.
New requirement - new Program ;-(
Treat your LEDs (all your LEDs?) as one object.
Specify: how many LEDs do you have
how many trailing LEDs do you need
How to calculate the PWM of each trailing LED depending on the PWM of the "primary" LED.
If we are talking about "trailing" LEDs, do you also need some "heading" LEDs?
By the way, if you want to code some kind of KITT-LED/Scanner/How ever it is called ... I guess you will find Arduino sketches. If you don't want this effect, what does your effect differently?
- else: Ask again.
rcayot
thank you noiasca,
I am kind of disheartened to hear I may have to start over.  Actually, I made some great progress.
1.  I have introduced a 'pulsecount' parameter into the class, and test for it during the tick();.  It successfully controls the number of pulses for each LED.  (I have 8)
2.  When I call pulseLed[0].tick; the LED pulses one time if I have set that number to 1.
What to do next was to use a timer to determine a time between tick calls.  This was not as simple as it appeared.  See my code, but what happens is that the first LED begins to brighten, the second starts to brighten, the first stops at near full brightness, the second LED continues to brighten and dim and then done.
Yes, I am tryin to do something like the 'Kitt" type of display, but those sketches I saw were very difficult for me to understand.  I am not just trying to build a bunch of LEDs, but to learn a bit how to program using the Arduino IDE.
I was beginning to think that this was going to be a success, then I saw that if I wanted to have them pulse in sequence, I could do that, but they would have to finish the cycle before the next one started.  I was overjoyed when I was able to start the two LED pulses at different times, but the darn first one stopped!
here is the code I have done
Code: [Select]
  pulse LED with PWM
  by noiasca
uint32_t CMillis = 0;
class PulseLed
  private :
    uint8_t interval = 1000;                   // the intervall in milliseconds for each change
    uint8_t pulsecount = 0;
  public :
      ledPin(ledPin)
    void begin()
        start = newStart;
        end = newEnd;
    void setpulsecount(byte newpulsecount)
      pulsecount = newpulsecount;
  void tick()
      if ((millis() - previousMillis > interval) && (pulsecount != 0))
        if (pwm == 0)
        pulsecount = pulsecount - 1;
//  PulseLed pulseLed[] {3};                // do tests with just one LED
    i.begin();
  pulseLed[0].setpulsecount(1);  // set number of times to pulse
  pulseLed[1].setpulsecount(1);
  pulseLed[2].setpulsecount(1);
  pulseLed[3].setpulsecount(1);
  pulseLed[4].setpulsecount(1);
  pulseLed[5].setpulsecount(1);
if (millis() - CMillis <=1500)
pulseLed[0].tick();
if (millis() - CMillis > 500)
pulseLed[1].tick();
I very much appreciate the help you have given me, I am learning a lot on this project, though in an unconventional way.  I tried going through the C++ tutorials on-line throught the 'class' parts and I get lost on the 'namespace' and other things.  The examples are nothing applicable, so I am trying to poke at this myself with help from the forum.
Roger Ayotte
