Hello,
I can't read any GPIO pin with this code adapted from
PWM channel output
Thanks for your HELP !
PMC->PMC_PCER1 |= PMC_PCER1_PID36; // Enable PWM (Power On)
PIOC->PIO_PDR |= PIO_PDR_P3 | PIO_PDR_P2; // DUE Pin 34-35 to PWM Peripheral
PIOC->PIO_ABSR |= PIO_ABSR_P3 | PIO_ABSR_P2; // Setting pins to Peripheral B
PWM->PWM_CLK = PWM_CLK_PREA(0) | PWM_CLK_DIVA(84); // Set PWM clock = 1MHz (84MHz/84)
PWM->PWM_CH_NUM[0].PWM_CMR = PWM_CMR_CPRE_CLKA; // Period is left aligned, clock source is CLKA on Channel 0
PWM->PWM_SCM |= PWM_SCM_SYNC0; // Synchronizing of Channels 0
PWM->PWM_SCM |= PWM_SCM_UPDM_MODE1; // Manual Write of duty-cycle automatic trigger of the update
NVIC_SetPriority(PWM_IRQn, 0); // Set the Nested Vector Interrupt Controller (NVIC) priority for the PWM controller to 0 (highest)
NVIC_EnableIRQ(PWM_IRQn); // Connect PWM Controller to Nested Vector Interrupt Controller (NVIC)
PWM->PWM_IER1 = PWM_IER1_CHID0; // Enable interrupt on PWM channel 0 triggered at end of PWM period
PWM->PWM_CH_NUM[0].PWM_CPRD = 208; // Channel 0 Period f = 1MHz/(2*CPRD) --> T=208 micros
PWM->PWM_CH_NUM[0].PWM_CDTY = 0; // Channel 0 duty-cycle at 0%
PWM->PWM_CH_NUM[1].PWM_CDTY = 0; // Channel 1 duty-cycle at 0%
PWM->PWM_ENA = PWM_ENA_CHID0; // Enable synchronous PWM on Channel 0
PWM->PWM_SCUC = PWM_SCUC_UPDULOCK; // Set the update unlock bit to trigger an update at the end of the next PWM period IMPORTANT
adapted from
https://forum.arduino.cc/index.php?
topic=590202.25;wap
