A stepper motor is normally characterised by rated current & coil resistance, not voltage.
In your case that's 330 mA and 32.6Ω. That'd indeed give you some 250 mA after L298N losses. Note: the L298N does NOT regulate current, at all. That's part of the problem of using it for steppers.
alright i understand now thanks
You always need a common ground, and you always have to connect both wires of a power supply to whatever you want to power.
i've done a quick wire diagram, i didnt put the 4 fire from the stepper going to the L293D and the four wire from the L293D going to uno for more clarity purpose.
is my diagram correct if i want to power everything with a wall-wart (a 4 pack battery on the picture because i didnt found a wall-wart picture)
