Topic: MKR 1400 GSM - connect to network without hanging loop() process (Read 1 time) previous topic - next topic
arduxx
Hello,
What I am trying to achieve is connection process to GSM/GPRS without hanging the loop() process. I tried number of libs and direct approach with millis timers but still cannot get what I need. Possibly because MKRGSM lib is stuffed with delays();
Anybody has found a way to do it?
This is my actual code responsible for the GSM part:
Code: [Select]
GPRS gprs;
GSM gsmAccess;
GSM_SMS sms;
GSMLocation location;
  ConnGsmNetwork();
  location.begin();
  while (!Serial)
  if (tmGsmConnRetry.WhileRepeat(false)) // this is 10s tiimer
    if(!g_gsmConnStatus)
      ConnGsmNetwork();
    if (location.available() == 0)
      location.begin();
bool g_gsmConnStatus = false;
void ConnGsmNetwork()
  if (g_gsmConnStatus)
    return;
  if (gsmAccess.ready() == 0)
  gprs.setTimeout(18000);
  gsmAccess.setTimeout(18000);
  // Start GSM connection
  if (g_gsmConnStatus == false) {
    if (gsmAccess.begin(g_PINNUMBER) == GSM_READY && (gprs.attachGPRS(g_GPRS_APN, g_GPRS_LOGIN, g_GPRS_PASSWORD) == GPRS_READY))
      g_gsmConnStatus = true;
      Serial.println("GSM START SUCCESS!");
      Serial.println("Connection failed");
      //delay(200);
I also tried async mode of gsmAccess.begin with false at third parameter but it did not work well, whenever I called gsmAccess.ready() it hands for short while.
Similar problem is with sms.available(), it slows down entire loop.
Hoping for some solution.
intstarep
Use
GSM gsmAccess(true);
and read the serial monitor to debug and observe
